Question about Kenmore Sewing Machines
The handwheel turns but doesn't move anything else. When I turn the clutch the needle moves, but it's extremely stiff and slow. When I press the peddle, it hums but doesn't move anything. There is no bobbin in and no thread to be found anywhere.
    Master:
  • 452 Answers
Sounds like its seizing up also no drive wheel locked op just freewheeling
Posted on Oct 17, 2013
    Champion:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 225 Answers
Sounds like the clutch isn't tight enough.
I don't know what model you have so I'm just guessing based upon the information you gave.
Posted on Oct 16, 2013
bargainbox
  • 1388 Answers
SOURCE: bobbin threading
You may have put the timing out, however, try this before you despair too much......
Ensure the presser foot is firm enough for the fabric you are using and that it will not just pull through easily by hand with the foot and feeddogs together (as the needle ascends), or things will not proceed, and you will be stitching in the same spot.
Generally a setting of 3 seems to work for general purposes, but if you are using very light or very heavy fabric, a sample is always a good idea before you start in earnest....also match the needle to the work for best results.
Ensure that all is clean and free of lint jams....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your
projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with
a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to
disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistant diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
If you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Posted on Feb 24, 2008
  • 22 Answers
SOURCE: thread jams & wheel axel cannot turn
there are a couple of things that come to mind.
Bobbin:   wound with uneven tension.  Try taking the bobbin, rewind that thread onto another bobbin and wind slowly.  make sure the thread feeds onto the new bobbin evenly.
upper thread:  catching on something or not flowing off the spool easily.
you're doing well, sounds like you consulted the manual and used your noggin, hang in there and let me know if this doesn't help.  we can troubleshoot some more!
Posted on Jan 12, 2009
  • 3 Answers
SOURCE: Handwheel on Sewing machine no longer moves needle.
Actually you should have a "set screw" in the hand wheel. The set screw is usally locked down tight to keep the hand wheel from spinning freely. I f you can run the machine slowly and hold the hand wheel in one place but the machine continues running, then you do need to replace the "set screw". If you replace it you will find that you can offset some of the machines vibration by where you lock the wheel down. Trial and error is the only way to achive this adjustment, kind of like balancing the tires on your car.
Posted on Feb 13, 2009
SOURCE: Bobbin Winding
How do I wet wind a 2 inchs long bobbin using varnish.
Thanks
Gholam
Posted on Mar 14, 2009
louislevel_2
  • 374 Answers
SOURCE: my needle keeps moving while I try to wind my bobbin
hi there,
the hand wheel and clutch should be disengage so that needle will not move also w/ the bobbins,doing this is hold the hand wheel then grip hold also at the center hand wheel.rotate center counter clockwise to release clutch.other type is push and pull hand wheel.any of them,try to run machine if needle is move again.cheers have a nice day don't forget to rate me.
Posted on Apr 07, 2009
How do i get the needle to stop moving when winding the bobbin?
Most machines will have a smaller wheel inside the handwheel that you turn towards the front of the machine, while holding the larger outer handwheel. If the needle still moves after doing this you'll need to work oil through the handwheel bushing.
Dec 04, 2016 | Sewing Machines
The needle acts like it is hitting something but there are no threads.
Test: Put needle on straight stitch. Put needle all the way to the left and turn the hand wheel forward.
Now move the needle to the right and do this again.
Did the hand wheel move all the way for one of the two sides the needle was placed?
If your answer is yes then you need to get the machine timed.
Also, make sure that your brake used for winding the bobbins is tight. If it is tight then loosen the small screw (usually on front of hand wheel). Move the brake forward a little more to tighten and then tighten the small screw again. Look at my picture.
Jun 26, 2015 | Sewing Machines
How can I fix the operation of the hand wheel release for a Bernina 807 Minimatic?
Over time the oil in the machine will evaporate or denature, if the machine has not been well lubricated for quite a while, it is likely that the clutch mechanism has gotten dry or gummy. If you remove the small screw in the hand wheel release, you will then be able to unscrew the hand wheel release all the way. Under that there will be a washer with two or three bumps on the outer edge and two or three tabs on the inner edge. Pay attention to how this is positioned. Especially noticing if the tabs are facing toward the machine or away. When you re-assemble the clutch you will want to put this back on the same way. Once that is clear, you may remove that washer, and pull gently on the handwheel away from the machine. The belt is still on at this point so it will not come off all the way. All you need is to be able to see about a quarter of the inside of the inside of the handwheel barrel. Put 5-8 drops of white sewing machine oil inside the barrel and rotate the handwheel. As you are rotating slowly push the handwheel back onto the shaft.
At this point, it can be helpful to run the machine to distribute the oil and loosen that contact. You may find it helpful to hold onto the needle bar, while running the machine slowly to ensure that they machine is not running. Be careful as holding onto any moving part can be quite dangerous. Use extreme caution, or do not do this at all. After running the machine for a bit without the clutch system installed, the machine should be loosened up enough to function properly. You can check this by letting go of the needle bar and running the machine, The needle bar should not move. If this is not the case, repeat the lubrication process and run the machine until it is loosened up enough to work. Once the handwheel will run without the needle bar moving, it is time to reassemble the clutch system. Put the washer piece back on the handwheel the same way it came off. Them put on the handwheel release, and finally insert the screw. Test the fuctionality of the clutch again at this point. With the screw fully inserted, you should be able to loosen the handwheel release about 1/3 of a turn. If it is significantly less than this, try turning the washer piece 1/3 of a turn until it is right. Once you have all that working, you are finished.
This is a fairly simple task, but is hard to explain or understand in writing. If you feel uncomfortable with these instructions, I would recommend taking your machine to a certified BERNINA technician. You can locate a nearby BERNINA dealer at the link provided.
Find Dealer easily find your nearest BERNINA dealer BERNINA
Feb 26, 2015 | Bernina Sewing Machines
Tesco ej09 sewing machine - handwheel wont turn
I actually had the same problem, it turned out that after threading a bobbin I'd forgot to slide the bobbin holder back into place (just push it to the left) Hope this helps
Apr 14, 2012 | Sewing Machines
The needle doesn't go up & down. Any suggestions? Thank you
Does the handwheel turn eazy or is it stiff. If it is stiff you need to take the top and bottom off and lubricate all moving parts. may take a bit of turning the handwheel and lubicating(it may tire you out). If the handwheel is not stiff I would check to see iff the motor is spining at all. If motor is not spining may be a bad footcontrol. If it is spining try cleaning the belt pullys and tighting the belt.
hope this helps
Mar 22, 2011 | Kenmore 15516 Mechanical Sewing Machine
I have a Singe 3116. The needle not working
the clutch is out. that allows you to wind a bobbin. take it out of bobbin mode and put it in sew mode (clutch in)
Feb 26, 2010 | Singer 3116 Simple
Husqvarna ROSE: started going slow after rewinding the bobbin. Now I can hardly move the handwheel, let alone sew anything. It feels as if it has siezed, but when my husband took the 'collar' off,...
Check the bobbin area to make sure the needle is not catching on something with the bobbin unit. Take the bobbin case out and see if it runs. It may be the belt but that's inside. Usually if the belt is off, the handwheel will turn easily but the needle will not go up and down. Suggest service by local authorized husqvarna viking dealer. You can find the nearest dealer from the husqvarna viking website and click on "Dealers" link. http://www.husqvarnaviking.com
Feb 05, 2010 | Husqvarna Viking 1
Kenmore model 158-12392
It is a clutch issue.
If you can turn the handwheel manually and the motor belt is running OK but the needle will not move, you will need to check the clutch mechanism for the bobbin winder.
There are three ways for the clutch to engage, and as I do not know your machine, I offer all three for you to see which applies to yours.
Flick winder to the left to engage needle arm motion.......it may activate automatically when the winder is set to wind a new bobbin and de-activate the needle arm
or
there may be a small wheel inside the larger handwheel....tighten the inner wheel to engage needle arm...
or
the handwheel may have a push/pull action ....push in to activate the clutch, pull out for bobbin winding.
If there is any more you need to ask or update your info to refine the question, just post back here, or drop a line through the "Contact Us" page at www.bargainbox.com.au
Mar 10, 2008 | Sewing Machines
Needle won't move
Make sure the clutch motor is powering up. make sure voltage toggle switch is on 110v and not 220v. Also rotation set correctly. Independently, make sure the motor runs. With your hands and motor belt disengaged, attempt to turn the handwheel toward you. If it is moving, then make sure motor is running. It handwheel does not turn it could be the machine. Make sure the stitch length dial is set at 2 or 3 and not 0 or 5. That could be that problem as well.
Nov 03, 2007 | Yamata FY811 Mechanical Sewing Machine
Sewing Machines Logo
69 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
SewTechWayne
SewTechWayne
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
