Question about GPS
On an SG5 skycaddie. Does anyone know what component D600 is next to the USB connector. This part has blown on my board and I am looking to find its part number
  • 2,113 Answers
Components are named using conventional letters like C for capacitor R for resister T for transistor D for diode. It is likely a diode to allow current one direction but not the other. Replace with any diode of similar size the leg wire diameter will help to get a similar size
Posted on Oct 16, 2013
My sky caddie sg5 won't charge thru the usb or power cord...any ideas???
Hello there,
Since you have tried charging the device using the usb and the power cord. It is quite clear to know that the problem is from the device connection port. It is bad and need to be replaced.
But you need to Try to test the battery in other devices then try to charge it there to see if it will hold a charge. If the battery holds a charge there, then it means the battery is okay and if it does not charge. Then it means the problem is from the battery. It need to be replaced if so.
Then test the charger/ power cord on another device if it is not bad, then you test the usb cable also. After running these test. You will be clear to know if it is the connection port. Then replace the connection port once confirmed to be the problem. Hope this helped. Goodluck Elect_Comp
Sep 02, 2011 | SkyGolf SkyCaddie SG5 Car GPS Receiver
How do I download golf courses to my sg5.
To download courses:
  1. Launch CaddieSync and sync your SkyCaddie.
  2. Select COURSES from the upper navigation bar of the CaddieSync desktop.
  3. Select the Favorites link next to Course Search.
  4. Check the box at the left of each course you want to download to your SkyCaddie.
  5. If you want to remove a downloaded course, uncheck the course in this step.
  6. Click the Download to My SkyCaddie >> button above the Favorites list.
  7. Checked courses will be downloaded to your SkyCaddie.
  8. Unchecked courses will be removed from your SkyCaddie.
  9. Click the Disconnect button in the lower navigation bar and close CaddieSync.
If you experience problems downloading courses:
  1. Turn off the SkyCaddie and disconnect the USB cable.
  2. Close the CaddieSync application.
  3. Reconnect the USB cable from the computer to your SkyCaddie.
  4. Launch CaddieSync.
  5. Click the Sync button in the lower navigation bar to resync the SkyCaddie.
Sep 01, 2011 | SkyGolf SkyCaddie SG5 Accessory Bundle Sky...
My sky caddie sg5 wont charge
If you follow these instructions which I think you know how to, it will recharge. If not the rechargeable battery needs to be replaced
To charge the battery, simply follow the steps below:
  1. Gently pull back the rubber cover to gain access to the mini-USB port located at the bottom of the SkyCaddie. Insert the mini-USB connector of the supplied wall charger into the mini-USB slot.
  2. Plug the wall charger into the AC wall outlet. While charging, the charging indicator in the upper left-hand side of the SkyCaddie will show red. The charging indicator will switch to green when fully charged. You may also notice the unit's screen turn on and off periodically.
The battery will charge, even with the SkyCaddie turned off. A full battery charge may take 4 hours. Once fully charged, expect 36 holes of continuous play.
Warning!Always connect the cable to the SkyCaddie first before connecting to AC power or PC USB.
Jul 16, 2011 | GPS
Registration
Where do I find Caddiesync>
May 28, 2010 | SkyGolf SkyCaddie SGX GPS Receiver
Installed new battery and still shows low battery after 2 holes and 24 hours of charging
if all cables on battery are clean and tight, then most likely it is the alternator putting out a low charge. test the alternator it should be at least 14 or a little more when running. 12.5 to 13 when off. if alternator is ok, then check all wiring from alternator to battery, and make sure the battery ground is ok!! best of luck carl,
Dec 04, 2009 | SkyGolf SkyCaddie SG5 Car GPS Receiver
How do I install caddieSync?
cannot log on to skycaddiesync for my new skycaddie.
Jul 30, 2009 | SkyCaddie SG2.5 GPS Receiver
How do you reset the username and password on a Skycaddie SG5?
What are you trying to login into lol the title just says " How do you reset the username and password on a.."
Im going to guess a computer? boot into safe mode (press f7 on start up) and then log in to the admin user account (no pass) from their u have access to pc from their run CMD by going start then run then type cmd and hit ok once that opens create an admin acount by doing this
net user /add useraccountname mypassword
net localgroup administrators useraccountname /add
net share concfg*C:\/grant:useraccountname,full
net user useraccountname *
ofcourse replace useraccountname with waht ever username you want and the same with password hope this helped
Feb 17, 2009 | SkyGolf SkyCaddie SG5 Car GPS Receiver
Skycaddie turns on by itself
Support reps are paid by their company to KNOW what their device and software can and can't do, does or doesn't do, so if you need support why call them and argue or doubt their assistance. This is what's wrong with over half the people who need/require support.
Your SG2 did not do this, because one, the SG2 DOES NOT have a backlight feature. All SkyCaddies however, do have the ability to power off automatically, and those power off times can be set by certains intervals, within the device. Once turned off, you will need to power it back on, it's that simple. Also, IF your device is plugged into your computer or is charging, it may power on, you are not losing power when this occurs.
Lastly, as a consumer, we want to buy something and have it WORK, bottom line. But there is ALWAYS the possiblity that the device has a problem and may have to be sent in for a repair or a look-at if all troubleshooting is exhausted and the issue is not from user error.
May 14, 2008 | SkyGolf SkyCaddie Handheld GPS Unit
GPS Logo
94 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
