Question about Fellowes Manufacturing Office Equipment & Supplies
Fellowes c420 safe sensor indicating too much paper?
How to reset oil sensors on a c420 c
Your manual will guide you through it with no problems.
Feb 10, 2015 | Fellowes Powershred C-420/420...
What causes the Fellowes Powershred SB-15C shredder to show that it's full when it isn't?
Check and make sure there is no paper or paper dust covering the Bin Full sensor. underneath the head.
Aug 03, 2014 | Fellowes Office Equipment & Supplies
My fellowes ps-70 shredder has a light on and it's not working
If the shredder is the kind that turns on when you insert paper, it may have an optical sensor that is dirty or blocked. Try blowing off the sensor with some canned air. The sensor is usually located in the center of the paper path slot. Also check that the bin is completely closed. Sometimes a tab on the door is bent or broken so that the shredder thinks the door is open. The tab activates a switch which tells the shredder that the door is safely closed. Fellowes has a lot of good tips on their website.
Apr 22, 2014 | Fellowes PS70-2CD Shredder
SAFESENSE ISN'T WORKING ON C-480C FELLOWES
Use a cotton bud dipped in alcohol and clean sensors
Run shredder once a day in reverse for 15 seconds to clear cutters
Empty wastebasket when bin full indicator light is illuminated using b0
If this does not solve the problem goto
www.fellowes.com for an extensive on-line support section
Feb 27, 2014 | Fellowes Manufacturing Powershred C-480C...
OUR FELLOWES CROSS CUT SHREDDER WILL KEEP ON RUNNING AFTER THE PAPER HAS BEEN SHREDDED. ARE THERE SENSORS THAT COULD POSSIBLY BE COVERED IN PAPER DUST?
If you look into the slot you feed the paper into, you should see a two little bumps that are facing each other in the center of the slot. These are the sensors that tell the unit to turn on/off. You can try cleaning them with a paper towel or long q-tip. If this does not fix it, then the sensors will have to be replaced. Most Fellowes machines have a 3-year warranty, you can call Fellowes at 1-800-955-0959 to see if yours is under warranty.
May 25, 2011 | Fellowes Office Equipment & Supplies
SHREDDER INDICATOR KEEPS COMING ON WHILE SHREDDING
look for two LED lights where paper falls into bin and wipe them off, but the sensors could be faulty as well. I have seen both.
Nov 11, 2009 | Fellowes DM15C Shredder
Model C-480C, always says bin is full! Where is the sensor?
Look up under the cutter asm and remove the paper shreds that are stuck in the blade assembly.Also clean the sensors with air or cotton swab.
Jun 03, 2009 | Fellowes Manufacturing C420 (Strip-Cut)...
The "bin full" keeps on coming on
first off, fellowes has had problems with the bin full sensors that sometimes, can only be corrected by replacing them. however, there are two things to check. make sure it doesn't have a bunch of shredded paper hanging down from the cutters. that can trigger the bin light as the sensore are located under the head, but above basket. last, but not least, clean the sensors. they get paper dust on them after awhile causing same indication. if those two things don't fix it, it will have to have sensors replaced.
good luck,
razors
Jan 20, 2009 | Fellowes Manufacturing Powershred C-220...
Fellows Powershred c-120 c indicator lights
your bin full sensors are dirty or broken to clean access bottom side of shredder head and look for a set of screws on each end of the paper throat. There you will see two little bulbs (bin full sensors) these have more than likely gathered paper dust and need to be cleaned with a Q-tip dipped in a little Isopryl Alchohol. This should solve your problem. If you have any questions just call us at 1-800-945-4545. A Customer Service Representative will assist you.
Apr 22, 2008 | Fellowes Powershred 120C-2 Shredder
29 people viewed this question
Top Fellowes Manufacturing Office Equipment & Supplies Experts
Andrew Taylor
Andrew Taylor
 Bob Buchholz
Bob Buchholz
Are you a Fellowes Manufacturing Office Equipment and Supply Expert? Answer questions, earn points and help others
