Question about Kitchen Appliances - Others
Foodsaver 2040 burns holes in bag when sealing smells like something burning
  • Anna Beth Burkhardt
    Anna Beth Burkhardt Oct 18, 2013
    I think the new tape is the answer. Thanks for your help.
2 Suggested Answers
pdarrach
SOURCE: When I go to SEAL, it burns a small hole clear thru the bag. One little metal peice on the sealing strip has burned right thru the white heating strip, therefore, it isn't sealing completely.
You need new tape to replace the one presently covering the heat element. You can get a roll of it for just US$7.99. Look at the FixYa question "where [or how maybe] can I get a new tape." I think that you have to be sure that the heat element is flat. I bought a used unit with that problem and the element had somehow gotten bent. Ordered the tape this morning and the cost is worth the hopeful fix.
Posted on Oct 02, 2012
Foodsaver V3460 vacuum runs and sounds like it has reached the end of the cycle then seals bag.
then you do not have the bag in proper place in the sealer , mine has never failed .
Aug 05, 2015 | FoodSaver V3460 Vertical Vacuum Sealer,...
Foodsaver V3840 Won't vacuum air out and wont go to seal. A label states the seals are not removable. Do you know how to fix?
you are not using a "good" bag. Make sure there are no holes and that the bottom and sides of the bag are properly sealed. It will run all day and not pull the air out if the seal is broken anywhere.
Sep 11, 2014 | FoodSaver V3840 Vacuum Packaging System
Smell like something is burning
It means ur Belt is starting to rip and it It is probably getting tangled
up in the motor so it burns and smells or something is in the tredmill like a blastic bag or something so I would look at that
Aug 29, 2013 | Weslo Cadence 450 Treadmill Walking Belt
Hoover Dimension has no suction and it smells of something burning
pets in house? check all hose passages for "hairball" clog...and check the drivebelt that spins the brush...(some have an electric motor to spin the brush, thus no belt)
Nov 02, 2012 | Hoover Bag Paper Microfilter Dimension...
Why there say tray full red light
The tape trick didn't work for me. Had to cut the wires. Works for now.
Sep 27, 2012 | FoodSaver Smart Seal Vacuum Sealer V3825
The product hisses all the time and emits and strange oder - is there a solution?
Sounds like a bad belt and it is burning as the motor tries to turn the brush. Does it smell like burning rubber?
Dec 04, 2010 | Vacuums
My Food Saver V3835 will not seal canisters. It seals bags AOK but there appears to be no vacuum generated through the extension tube. We have tried several different canisters and covers. I have also...
The negative pressure is very slight and almost not detectable when using canisters for food storage. Once the system is activated, and allowed to run until timed out, the canister should have pulled all the oxygen from the canister. Foodsaver only canisters are designed for the V3835 for vacuum sealing.
How to Vacuum Package Using Your FoodSaver® Vacuum
Packaging Canister
NOTE: FoodSaver® Vacuum Packaging Canisters can only be used with
a FoodSaver® appliance that has an Accessory Port. Please check your
QuickStart Guide to see if your appliance has one.
1. Place your FoodSaver® appliance on a fl at, dry surface and plug the power
cord into a standard electrical outlet.
2. Place the item(s) to be vacuum packaged inside the canister. Leave at least
one inch (1”) between the contents and the rim of the canister.
3. Wipe rim to ensure it is clean and dry.
4. Place the lid on top of the canister. If the canister has latches, put them
in an upright position so that the lid fi ts on the base. Push the latches
downward until they snap into place.
5. Insert one end of the Accessory Hose into the Accessory Port on your
FoodSaver® appliance.
6. Insert the other end of the Accessory Hose into the hole on the top of the
canister lid. Twist the gray tip of hose while inserting to ensure a tight fi t.
7. Follow the steps for vacuum packaging as outlined in your QuickStart
Guide.
8. Remove the Accessory Hose from the Accessory Port on the appliance
before vacuum packaging in FoodSaver® Bags.
Allow hot foods to cool to room temperature before vacuum packaging. Otherwise, the
contents may bubble up out of the canister.
How to Open the FoodSaver® Vacuum Packaging Canister
To open, press and hold down the gray rubber button in the center of the lid
until you no longer hear air escaping. This will release the vacuum and allow you
to easily remove the lid.
Sep 04, 2010 | Microwave Ovens
I need a owner's manual foodsaver compact fc-no-202412 i dont no how lang to l hold it down to seal the bag.model foodsaver compact .f.l.a.e.m.nuova.s.r.l
Well you many please follow the below link to get your manual -
http://www.foodsaver.com/manuals/FoodSaver/T000-32030_English.pdf
Check out page number 4 on this manual to know the time to seal the bag.
Good Luck!!
Thanks for using FixYa!!
Aug 28, 2010 | Tilia FoodSaver V2240
My Foodsaver Vac 1050 doesn't extract all of the air from the bag
Either the sealing strips are dirty letting air escape or the lips of the bag are turned upwards. Push the front of the bag down towards the bottm chanel and it should work fine. I have had one for eight years now and love it.Ken Vancouver BC
Dec 30, 2008 | Tilia FoodSaver VAC420
A smell of burning rubber is coming from my engine. What is it? Could it be the timing belt? Is it safe to drive any distance? Thanks burning rubber smell from engine
A common cause of a smell like that is a coolant leak.Take a close look around the hoses,clamps, frost plugs and the water pump as it has a weep hole that will leek coolant if the seal is breached. Sometimes all you will see is a stain, but no coolant as small leeks boil away with the engines heat.
If a belt was burning it would be very noisy. The timing belt is cogged so slippage is unlikely. It is possible that a foreign object has gotten on the exhaust manifold like a plastic bag. One last thing I can think of is a wire or something touching a hot surface and melting. Good luck.
Dec 14, 2008 | 1993 Toyota Camry V6
Kitchen Appliances - Others Logo
50 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
