Question about Garden
Can one bleach and or stain balau wood to get a white stained effect
SOURCE: Rust stains and bleach spots.
I'm sorry but the white spots will be due to bleach. It may be that there was undissolved bleach in the washer after the first load. Maybe some of it came out with the whites and lay in wait in the basket.
I doubt the makers would guarantee anything for 7 years, so no free basket or installation is likely. Seems there is a chip in the enamel and dampness / water from the previous wash days before sits there collecting iron as rust particles.
For the time being you could try rinsing the machine out before the first load. That might prevent the rust marks or reduce them.
Posted on May 04, 2008
  • 249 Answers
SOURCE: Oil stains on whites after washing in our Kenmore Oasis
seals are gone big job!!
Posted on Jun 14, 2008
SOURCE: blue stains on laundry
I was talking toa repairmain about which washer/dryer to get and he mentioned that the Bosch can stain clothing blue. I don't know anything else about why...but I'd contact my Bosch dealer.
Posted on Jul 14, 2008
  • 222 Answers
SOURCE: There are bleach stains on the stainless steel handle of the stove
USE OIL W/ VINEGAR OR GAS W/ THINNER THEN CLEAN IT
Posted on May 29, 2009
SOURCE: clothes come out with stains on them
I had a similar problem with my Kenmore front loader. Turned out that the rubber lining around the door was trapping dirty, soapy water causing a nasty residue to collect. That residue got onto the clothes. I cleaned the rubber liner and now keep the washer door open between uses. I still occasionally wipe down the rubber liner with a wet rag. Problem seems to have been solved.
Posted on Aug 24, 2009
How to clean coffee stains on white coffee maker
Plastic can absorb Stains, so you will need to use some kind of bleaching poduct.
some products you can try individually:
  • Baking soda
  • Bleach
  • Water
  • Vinegar
  • Rubbing alcohol
Dilute with luke warm water , except for Rubbing Alcohol
Use some kind of tray which you don't mind if it gets bleach stains to protect your countertop. put the device on the tray.
If you can't soak an item, try disconnecting the device, then wrapping a lightly soaked hand towel or paper towel over the area that is discolored
Rinse with luke warm water, and make sure device has completely dried before reconnecting.
Aug 03, 2016 | Cuisinart DCC Coffee Makers & Espresso...
Need to take yellow stain out pf white nike airmaxes
Hi. Do you know what caused the stain? You might want to try a cotton swab with a little bit of a diluted bleach solution - put 1 part bleach to 10 parts water, mix, and then dip the cotton swab in it and gently apply to the stained area. It might take a bit of work to get it all out. I hope this helps.
Mar 28, 2015 | Nike Clothing Accessories
How can I repair a bleach stain on a t-shirt
For an immediate treatment of a bleach stain, try Sodium Thiosulfate (often referred to as photographic fixer, it is an agent that has been used as a way to neutralize bleaching effects of other substances. Blot stain at first with a white cloth that has been dipped in ST until stain begins to disappear of fabric becomes saturated. Rinse with cold water and repeat until desired effect or no more progress has been made.
If you wanna get rid of the stain without using laboratory grade chemicals, use white vinegar. Before this, make sure you rinsed bleach out of fabric, if you don't it will release a toxic chlorine gas.
Soak a clean white cloth with vinegar and start blotting stain, keep doing this until fabric won't hold anymore.
Aug 06, 2014 | Clothing
How to stain fiberglass entry door?
You cannot use regular stain on a Fiberglass door. Stain is made to soak into wood. It cannot soak into Fiberglass. It will peel right off in several months depending on the weather. A solid stain may would work for a while, but it will not hold up as well. Whereas stain is made to soak into wood, paint is made to sit on top of surfaces. There are some nice paints that look like stained wood if that is the effect you are looking for. But if you want the new finish to last on your door, use paint. Make sure you clean the door thoroughly with a degreaser, prep solvent or paint thinner
Apr 29, 2014 | Jeld-wen Door. Ascot 3/4 Lite Oval Primed...
Remove bleach stains
Apr 03, 2014 | Clothing
Bleach stains on black jeans
Bleach doesn't stain ! it removes the dye from the fabric.
I would suggest trying to re dye the fabric with a black dye as Jeans material might be more successful .
Synthetic fabric is not as easy to re dye end up using a permanent black marker on Synthetic Shirt that I got bleach on. .
Mar 12, 2014 | Clothing
How to clean spots off carpet
It depends on what the spots. They may actually be stains. Spots will come out if you use the correct cleaning process and cleaners but stains are permanent unless bleached or dyed. If you are not sure it may be less expensive to call a professional carpet cleaner that knows what they are doing (not all of them do)
Dec 30, 2013 | Vacuums
I have a Michael Kors watch with a white rubber wristband that has turned dirty and dark in less than a year. I am quite unhappy with how it looks, but very happy with the watch. What to do???
Thanks for contacting FixYa.
  1. The easiest thing to try is a regular pencil eraser. It's perfect for removing marks and smudges from rubber and works like a charm! Use white erasers as the pink ones may leave pink smudges.
  2. If a regular pencil eraser doesn't work, try a Mr. Clean Magic Eraser or similar product. Simply moisten the sponge and rub it over the stained area.
  3. If that doesn't do it, grab your safety goggles and move on to the next step.
  4. Mix four parts water with one part bleach in a cup or small bowl. You will need less than ΒΌ cup of the finished solution, so only mix a small amount.
  5. Wearing eye protection, moisten a white cloth with the mixture. Do not use a colored cloth. You will likely transfer color from the cloth to the watch band and make your problem worse.
  6. Carefully dab the bleach against the stain on the watch band. Don't over apply the bleach or leave it for more than a few seconds or you may damage the rubber.
  7. If needed, increase the strength of the solution by adding a bit more bleach. Do this in small increments to expose the rubber watchband to as little bleach as necessary.
  8. Blot and repeat as necessary if you see improvement.
  9. Once the stain is removed, rinse the band well with water to remove all the bleach residue.
  10. If the stain remains, mix the Rit Dye Remover with a small amount of water to make a paste.
  11. Spread the paste onto the stained area and allow it to set for a minute.
  12. Rinse with water and dry with a soft cloth.
  13. Repeat if necessary.
Additional Tips and Advice
  • Once you have the band clean, treat it with Armor-All wipes made for vinyl car interiors. This easy tactic will help protect the band from stains and smudging. Repeat every few weeks for maximum effect.
  • Be careful with acetone on rubber watch bands. It can start to break down the rubber and make the band feel "sticky." Once done, this can be difficult to reverse.
Best regards.
Jan 31, 2011 | Fossil CH2331 Wrist Watch
Washing machines staining clothes with a blackish stain
The bearings under the tub may be leaking grease and it will get in the tub.
Jul 31, 2009 | GE WSXH208A Front Load Washer
Garden Logo
551 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
