Dehumidifiers Logo
H
Howard Lehrer Posted on Oct 16, 2013
Manuals white westinghouse
I have model # MDH25HW1. Will not turn on. Water container in place. Is there a reset button? [email protected]
I have a Lasko 1050. The sensor on my humidifier isn't sensing the humidity level correctly; how do I reset it, please? Thanks!
im in the suspicion that since you turned it upside down , some or possibly a lot of stored up water has gotten into the sensor section now , this might take several days of it running in what to remove and dry it all out , or might never recover as it's not a good idea to turn any item containing a gas compressor up side down , as this forces lube oils into the wrong places inside them
for the most part humidity sensors are not consumer (resettable)
Has been running fine. my daughter emptied it yesterday morning and didn't put the catch container back in the machine properly and a red light (small round) on top left of machine was on when I went...
Actually, the fan shouldn't be working if the water bucket is not installed properly. So, I believe it's more of a case of the electronic controls need to be reset.
To accomplish this, turn the Master ON/OFF Switch to OFF and unplug the unit for 15 minutes.
After the time as elapsed, plug the unit in and turn the Master ON/OFF Switch to ON. The Bucket Full light should not, now be ON. And the unit can function as it should, after you reset the controls for maximum humidity extraction (32 - 35%).
Hope this helped you troubleshoot and solve the problem. Please let me know. Thanks.
A PUDDLE OF WATER FORMS UNDER MY DEHUMIDIFIER WHEN IT IS RUNNING.
Dehumidifiers have a container that holds the water the the unit extracts from the air. If that container is full or not placed correctly, the water will leak out of the unit.
I have a Maytag model M7DH65B2A dehumidifier that has worked well for several years. However, when I hook up the hose to drain off the water when we go on vacation the water still fills up the built-in...
Hi Graham. Check the hose and the opening to the hose through the base of the dehumidifer. There is probably some debris in there causing this aggravating problem. J.
No water in container
I have this model, and mine failed after 2 years. Fortunately it has a 5 year warranty on it. If you haven't cleaned the filter in the front, do that first. Take the bucket out, and then you can pull the filter down. In my case, I was getting an ice block on the front coils, and the warranty place determined it was a bad compressor. LG sent a refurbished model as a replacement for my broken one, and then I had to ship the bad one back in the box they provided. They also provided a return shipping label.
I have a GE Dehumidifier Model AHW50LMG1. Am trying to find out how to clean the container that the water is collected into. After use the container contains residue from collected water that I am...
Vinegar is the proper way to clean all parts of a humidifier. It stops scale and kills bacteria and fungus. It can be processed through the heating element without any adverse effects.
Thank you,
James.
-------Please vote 4 thumbs up 4 me!!!----------
2helpful
FULL LIGHT FLASHES
An automatic overflow switch and Container “Full” indicator light are provided to turn the
dehumidifier off before the container overflows. When the indicator light on the control panel
glows, the water container must be emptied. If the light remains on and the dehumidifier does
not begin to operate make sure the float is attached to the water container.
When the condensate water container is full, the indicator lights up.
1. Turn the power off before removing container. Wait 3 minutes for
any remaining water to drain into the condensate container.
2. Tilt the container forward then lift carefully by the handle.
3. Empty and gently re-insert the container.
Important:This water is not suitable for drinking.
Please rate and god bless:)
Top Dehumidifiers Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Dehumidifier Expert? Answer questions, earn points and help others
