Question about Tecumseh Lawn Boy Push Mowers Insight Silver Powered Series - Sens - A - Speed Walk Behind Mower - 10685
Model 10685, replaced gears in the transmission box and now the axle will not turn smoothly.
  • 1 more comment
  • Chris Neidert
    Chris Neidert Oct 16, 2013
    One more piece of info on the 10685 axle not turning smoothly, it will turn smoothly if I push the gear box forward. When it moves back to tak eup the slack on the belt, then it is diffuclyty to rotate the axle.
  • Chris Neidert
    Chris Neidert Oct 25, 2013
    Could I have the gear on the axle on backwards?
  • Behind_Blue_Eyes
    Behind_Blue_Eyes Oct 26, 2013
    yes, I would go back to the start. some rear drive set ups didn't roll very well in reverse to begin with but sounds like you made an oops
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
You have most likely bound up the axle(s) or gears or both
Posted on Oct 22, 2013
A 2002 ford e250 econoline van, replaced speed sensor on rear axle. still does not shift into a higher gear unless I floor it ,then it jerks into high gear . what should I look for?
problems in the electronics of the transmission
could be a TCM , VSS ( in the box and not the rear axle)
TR sensor
run the fault codes
Jun 01, 2017 | Ford Cars & Trucks
My scotts rotory spreader will not spin
The design is quite simple with one wheel driving a bevel gear in a gear box. If the wheel turns the axle shaft and the center pin in the spreader with the retainer/cotter pin does not turn it is likely something has failed in the gear box.
If both wheel spins and the axle does not turn than the drive wheel has disengaged the axle shaft and the cotter pin in the drive wheel needs to be replaced.
The compounds used in the spreaders are corrosive. Usually the gears and axle become bound due to corrosion. By oiling the bearings and wiggling the wheels they will free up,
Hope this helps?.
Apr 19, 2013 | Scotts Company 589384 Scotts 5000 SQFT...
1987 saab 9000 turbo transmission
bad pressure plate or stuck throw out bearing.
Jun 06, 2012 | Saab 9000 Cars & Trucks
The rear wheels will not turn in reverse at all. I
Rear wheel drives like this have pinion gears with rachet pawls that allow them to go backwards freely while locking when the transmission drives them.
You need to take off your rear wheels and carefully remove the pawls. They look like little squareish metal shaft keys with springs under them. You should notice that the keys or pawls are covered in what looks like grease.....which is actually worm metal from the pinion gear and oil mixed together to form this pastey greasey substance. Clean all that stuff off and lightly oil *( light oil...3 in 1 kind of oil) and reassemble.
You should hear the nice clean clicking of the rachet pawls as you roll backwards again!
Good luck and be careful!
Jun 22, 2010 | Tecumseh Lawn Boy Push Mowers Insight...
Daughter hit curb,broke steering gear & other misc. parts. replaced steering box & other front end parts. while bocked up, put car in drive,passenger axle spins constant drivers random. replaced...
When both wheels are in the air it is normal that one wheel will not turn when put in gear.
There is nothing wrong with the axle or the transmission.
Feb 01, 2010 | 1998 Toyota Corolla
Dissasembling tecumseh ride on gearbox
There is an official Tecumseh/Peerless motion drive system manual available, which deals with the strip-down and rebuild of all current and recent transmissions. Parts availability MAY be a problem, however, not to mention that internal transmission parts are EXPENSIVE. A set of shift keys and bearings + time will just about equal the cost of a new transmission.
Sep 21, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Transmission delay in shifting
a transmission flush is a good place to start
Jan 08, 2009 | 2002 Mazda Millenia
Ford probe
the front drive axle on one side may have not been installed all the way in to the transmission, check to see if it is loose and have some one look under front end with engine on, front end jacked up, emergency brake on and in gear to see if a axle is turning. if one is and yhe other is not put the car in park and turn\ roll the wheel that was not turning by hand if it rolls your problem is most likley to be the axle has come loose from the transmission
Oct 18, 2008 | 1990 Ford Probe
Poulan/weedeater self propell not working
if the drive cable is pulling back on the transmission and the pulley is turning but the axle isnt turning replace the tranny - no seperate parts available for tranny you must replace the entire unit
Oct 03, 2008 | Garden
I have a kia mentor with 46000 miles on the clock and the auto gearbox will not change up in to forth gear and the gear changes are not as smooth as i would exspect it to be i have how ever noticed that...
First thing to check is the transmission fluid, if the problem does not go replacing the fluid, then on a manual transmission you need to replace the transmission.
On an automatic transmission can be a problem with the control module or with a defective sensor.
Sep 05, 2008 | Kia Sedona Cars & Trucks
Tecumseh Lawn Boy Push Mowers Insight Silver Powered Series -  Sens - A - Speed Walk Behind Mower - 10685 Logo
71 people viewed this question
Top Tecumseh Garden Experts
Mike Squire
lnbn1975
itsman
Are you a Tecumseh Garden Expert? Answer questions, earn points and help others
