Pink picture dynex tv fix
When I hook my Dynex TV to my HP laptop the screen turns pink but just the other day it was fine
    Sniper:
  • 65 Answers
This is most likely the cable you have connected. I would try that first. If that doesn't work try connection your laptop to another TV. If the new TV gives you the same problem it might be a problem with your graphics card.
Posted on Oct 16, 2013
SOURCE: HP TV-Tuner Problem
already did that
Posted on Mar 08, 2008
DarrenP
  • 78 Answers
SOURCE: I just purchased a dynex
Right click on your desktop and select display properties.click on the Settings tab, then on Identify - when another monitor is recognized, you can enable it in that window.
Unless you're using a mac. If you are, get back to me :)
Posted on Apr 09, 2008
Geekman
  • 32281 Answers
SOURCE: yah i have a dynex tv and a Asus desktop comp and
Is the dynex tv unit installed inside the ASUS desktop computer?
The TV receiver needs an antenna/aerial connected to the TV receiver to receive TV signals, without it you will get no or weak signal.
Have you connected an antenna/aerial to the Dynex TV unit?
Posted on Jul 23, 2009
MaverickIT
  • 53 Answers
SOURCE: vista does not recognize my dynex external
Check Dynex's Website for Vista drivers. If there aren't any, see if they offer Windows 7 drivers - they may work instead.
Posted on Sep 19, 2009
85Sloth
  • 104 Answers
SOURCE: I just bought the dynex
Best Buy's Dynex brand is very generic loosely built product mfg over seas as cheaply as possible without quality control. - I've have many customer problems with a wide variety of their store brand, please consider a refund/return
recommend you buy another Mfg brand. you will loose sleep trying to get any Dynex product running smoothly for any length of time
Posted on Aug 24, 2010
Dynex HDTV says not supported when PS3 is connected via HDMI
Have you tried changing the video output settings on the PS3? It may just be on a setting that the TV does not support. For instance, if the poutput setting is 1080P, and the TV only supports up to 1080i, you would get a "not supported" signal. Hook the ps3 to a tv that it works on...turn it on, go to settings- display settings-output settings- select HDMI as the connector type- if it asks for 3D tv size...select the size- now you need to set the resolution...select all resolutions that the TV supports, since it is a dynex...it is likely a 720p TV. So I would start by selecting only 720p, and then hook the system to the Dynex TV and see if it works now. If it works, you can go back in and attempt to select 1080i or 1080p to see if they work... but again, being a Dynex, it is probably only a 720p TV... The PS3 is likely trying to output a 1080i or 1080p signal...which that TV doesn't support.
Mar 21, 2014 | Video Game Consoles & Games
Yea so half of the screen on my Dynex lLCD TV is pink and red, and I have no idea why, any suggestions as to how to fix it?
faulty screen driver lost is color codes. replace its on the back of the screen at the top.
Sep 21, 2013 | Dynex DX-LCD32-09 LCD TV
Dynex 22 tv has sound no picture
Power supply caps or backlight inverter! Common issues with LCD flat screens for some reason.
Dec 28, 2011 | Dynex DX-L22-10A 22 in. LCD TV
No Picture-white screen
Ur Tuner board,that the tv signal came into that board.U have a little manchanical skill.Take ur tv aparts.Replaced that Tuner board ur tv will work again.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board to replacement.
May 11, 2010 | Dynex DX-L26-10A 26 in. HD-Ready LCD TV
TV worked fine one night, next day screen is white.
The LCD Panel failed. There is no easy fix but try to get the T-Con board to fix the issue. However, this part is usually only available with the whole LCD Panel. This is usually the most expensive part in the TV and the whole TV needs to be taken apart to replace the panel.
Might be economically viable if you can find a place that carrys the T-con but Dynex parts are usually hard to find. The LCD Panel part alone will exceed the cost of the TV.
Oct 07, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
Dynex 19Inch Vga no signal
You may need to set up the video card to see the TV so you can display the computer on it.Somewhere in the setting for your video card should be settings for that.
Jun 01, 2009 | Dynex DX-LCD32-09 LCD TV
Dynex 32" LCD White Screen Problem.
Hi, My Name is Jorge K. My family owns Dynex T.V. 32 LCD, we bought the tv at BEST BUY=BBY and we did not buy any warranty from BBY all we had was the fatory warraty that last a year. we had the same problem after five months the screen of that tv stop working and all we watch was a WHITE SCREEN.
Solving the Problem:
If you the orginal owner and bought the tv from BBY, you should call Dynex " the phone number will be on your owner manual tv.and it should be free if you live in the USA" and explain the situation about your TV. It might be a white screen or different problems. You should have your BBY receipt from that tv. because they will ask you for information that the receipt has. After you finish complaning with Dynex, Dynex will transfter you to BBYbecause Dynex branch is relate to BBY as the manual explain us. You will be talking to BBY Geek department. Geek department will send a Technician to fix the T.V. The Technian WILL NOT BE ABLE TO FIX THE TV THE SAME DAY BECAUSE HE/SHE WOULD NEED TO ORDER A REPLACEMENT PART TO FIX THE TV. Generally the tech will need to order a NEW SCREEN TO REPLACE AND FIX THE PROBLEM, but pay me no mind. Haha I am not a t.v. Tech. haha.
Because the Tech will not able to fix the problem the same day, he will give you a phone number and you will have to call BBY and ask if your replacement screen arrive. If they are unable to get your new screen, Dynex will give an order to change the T.V. for a new one. and they will give you a change number that you must write. Then you can go to the BBY where you bought the TV or any BBY and get you new Dynex TV. BBY will try to charce extra money because my, your or our Dynex tv model might be old and had a lower price than they new Dynex tv that BBY has right now. I think you will have to convince the manager from BBY home teather department not to charge you extra money. My father was able to convince the manager and we paid nothing for the new tv.
Solution if you Dynex TV is not from best buy or has more than a year:
haha YOU OUT OF LUCK, You can try call Dynex first and deal will the problem. You can also try to replace the screen but it might not fix the tv and replacing a screen could be costly, haha I just prefer to buy a new TV and no invest in something that might be trash if that solution doesn't work out. Risky, Please play save with your money and don't gamble. HAHA.
If i hurt any feeling, i bet for forgiveness and I wish that everything goes alright with your tv and your life.
GOD BLESS AMERICA and the people from earth.
Jan 18, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
19'' Dynex TV does not come up as a Computer Monitor.
Follow these steps on the remote :
Press Input,
scroll down and select VGA.
Nov 17, 2008 | Dynex 19 in. LCD Flat-Panel HDTV
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
