Car turned off going down highway, battery light was only one on after it happened but now ABS light is too.
You could have an error code that caused the engine to shut off but that is really rare. There are a lot of things that cause the abs light to come on. Brake wear, faulty brake components, and/or sensors, reservoir levels.
Has it ever happened before? Has it happened again since the first time?
Testimonial: "Never happened until yesterday. I saw the EPC, ABS, battery, and brake indicators go on when it happened. Got it back home and checked everything like sunroof/ windows, alarm, interior/ exterior lights, wipers, horn, radio, AC, all switches, and fuses and all check out fine except the dash lights. When the dash lights were on and I gave it gas at ~1500 rpm the dash lights would turn off then slowly come back on. Battery was at 12.76V and alternator was at 13.56V, a little low but still charging the battery. Only the battery indicator was on yesterday and today the battery and ABS are on. Just recently I went and unclipped the Mass airflow sensor and made sure there was nothing in the terminals and reattached it. When I started it up the battery light was delayed but came on then slowly faded away a few seconds later. Took it for a test drive and everything seems to be working like it should. Still not sure if I should take it to AZ to see what the codes are/were."
For sure get the codes downloaded. It sounds like you have a lot going on there that would make your car pretty unreliable. The codes will tell you for sure or at least narrow it down
I took it to Advanced Auto and the only code that came up was an O2 sensor (P0140) but that doesn't explain the car shutting off so there has got to be an electrical problem somewhere, and I think it might have to do with the sunroof cause that is unresponsive sometimes.
SOURCE: 2000 VW JETTA VR6 lights on everywhere!!
Believe it or not, this could be a mass airflow issue. The mass airflow can trigger the lights the ASR and the EPC lights. When i gets really cold, the airflow sensor sends signals to the CPU to readjust the air/fuel mixture.
