Question about HP Sr1130nx (PC134A) PC Desktop
Presario sata setting
My ethernet plug is out and i need to know if i can bypass and how step by step
    Scholar:
  • 96 Answers
I take it you mean your ethernet (network) card has stopped working? This is a common fault, especially with ports that are built into the motherboard. I suggest you buy and fit a PCI plug in network card--- not expensive and hook your ethernet cable to that.
Modern Windows operating systems should have no problem detecting the new card and installing a driver automatically.
Be aware that if you do this you may have to contact Microsoft to re-activate your Windows, as the MAC address you are using will have changed.
Posted on Oct 16, 2013
Both My Inspiron and linksys will not connect to my ISP. They say both are receiving an invalid IP address! I have used all trouble shooting techniques including trying to release and reset! Even went as...
Step 1: Plug the computer (ethernet wired) directly into the modem. Power cycle the modem and when all the light come on you should have internet. If not call your ISP to trouble shoot.
At this point we should be able to determine if it is a PPPoe connection (needs username and password to connect) or if it logs in automaticly.
Step 2: Plug the router back into the modem and the computer plugged wired (ethernet) to the router. Remove power from both the modem and the router. Plug the modem back in first, once all the lights are on plug in the router. Try to connect.
Step 3: Log in to the router via its IP address (normally 192.168.1.1), if no one has reset the user name password it should admin for both. If it has been reset, you will need to know what the user name and password are to continue.
Step 4: Under setup if in step 1 you found you needed PPPoe, then you need to set that under the setup tab. Make sure you use the user name and password provided to you by your ISP. If you dont need PPPoe then make sure this is set to obtain IP automaticly.
Step 5: save settings. Once the router restarts, try to connect again.
If these step do not work, let me know:
1. who is your ISP?
2. What modem do they use?
3. What is your IP address when plugged directly into the modem?
4. What is your IP address when plugged into the router?
I will be around for about 1 more hour, its 2PM central time now.
Jul 21, 2011 | Computers & Internet
Need new hdd for my presario 700 but don`t know if it`s ata, sata,pata.What is the difference.
ATA =aDVANCED tECHNOLOGY aTTACHMENT
PATA= Parallel ATA
SATA=Serial ATA
SATA is more avenced in speed than others.
Mar 31, 2011 | Compaq Presario 700 470024-192 Notebook
Every time i try to install windows xp on this laptop i just keep getting an error message. i was told i need to disable the AHCI, how do i go about doing this?
Installing XP on a SATA drive requires an additional step:
http://xphelpandsupport.mvps.org/how...ws_xp_on_a.htm
However, Most newer BIOS allow an Alternate method for SATA . . Go into the bios and check the "Sata Operation" setting,
change it to "Raid Autodetect/ATA if it is not already. Now try to install XP ( could be IDE Mode, Compatibility Mode or Legacy Mode - different BIOS use different terms )
some will say IDE instead of ATA)
If there are no such settings you'll need to slipstream the sata drivers on the XP CD, follow the instructions in this guide :
http://www.digitgeek.com/how-to-slip...rs-into-xp-cd/
or
http://www.howtogeek.com/howto/windo...-installation/
Or, you might consider installing Windows 7 . .
Jan 24, 2011 | HP Compaq Presario CQ61420us Notebook
I am trying to install a serial ata drive. what steps are necessary
Pretty basic.
Enter your Bios and enable the SATA port.
Mount the drive,HDD or Optical,plug in the power cable and sata cable on both ends,and that's about it.
If this helps,would you please rate my post?
Bob
Aug 12, 2010 | HP Compaq Presario SR1300NX (PP195AA) PC...
How do i remove my compaq presario 2200's hard drive?
The Compaq Presario line is one of the longest-running series of computers, originating in 1993 and remaining in production even after the purchase of Compaq by HP. Because of this, many Compaq Presario desktops have required that some of their parts be upgraded or replaced because of the wear that they have received over years of standard use. One of the more commonly replaced Presario desktop components is the hard drives, especially given how much hard drivemag-glass_10x10.gif storage capacity has increased since the Compaq Presario line was introduced. Replacing a hard drive in a Compaq Presario desktop isn't difficult, and can usually be done in a matter of minutes even for users who aren't familiar with computer upgrades.
structions
  1. Step 1Remove the screws holding the left side panel of the computer on, then slide the panel back to remove it. Set both the panel and the screws aside so that you can put the panel back in place once the hard drive has been replaced.
  2. Step 2Unplug the ATA (wide, flat and usually gray) or SATA (thicker, thin and red) data cable and the power cable from the back of the hard drive that is currently in the Compaq Presario. Move the cables so that they will be out of the way, but make sure that they will still be easily accessible to you so that you can plug them into the new hard drive.
Aug 08, 2010 | HP Compaq Presario 2200 Notebook
A need help
you can set your playstation 3 online by two ways, 1- by a wired connection, and 2- Wireless,
1-Wired Connection: Plug an ethernet cable from your highspeed modem to the back ethernet input on your ps3 system, and follow on your ps3: Network Connection > Internet Connection Settings > Easy > Wired Connection. and follow steps
2- Wireless Connection: You must have a Router connecting ethernet cable from your intenet modem to the router, and follow on your ps3: Network Connection > Internet Connection Settings > Easy > Wireless Connection and follow steps,
hope this helped you on setting up your ps3 connection :)
Apr 13, 2010 | Sony Playstation 3 (PS3) Console
There is something pluged in wrong in my Compaq Presario SR5130NX tower and i need a picture showing how to plug in all the drives to the motherbord
If its an IDE cable (Flat wide one) ensure the last drive (Operating system) one is plugged in here set to MASTER, with the slave drive connected along this ribbon set to SLAVE.
If SATA cable usually narrow and red plug into any SATA port on the mobo, doesnt matter which order.
Dec 21, 2009 | HP Compaq Presario SR5130NX PC Desktop
Compaq presario c306us doesnt format, says there there is no HDD
dear friend
you need to goto bios and search for and option "sata native support"
set it to disabled
if you cant find that , then you need to splitstream sata drivers into windows xp cd, if this is the case please ask me to tell you the method
thanks
Apr 10, 2009 | HP Compaq Presario C306US Notebook
Install xp in compaq presario c700
Dear sir, I purchased a new laptop compaq presario c700. When I tried to install os it is booting from cd but it is not recognising harddisk. I checked in BIOS but I didn't find the option where to find harddisk. So please provivide the solution
Dec 07, 2007 | Compaq Presario C700T Notebook
HP Sr1130nx (PC134A) PC Desktop Logo
23 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
