SOURCE: Craftsman LT 1000 with Briggs and Stratton 20 OHV
lift your seat and look at the label that you got your model number from. to the right of the model number is the serial number. the first six digits of the serial number is the date your tractor was made - for example: serial no. 060802D002756 would make the unit made June 8, 2002
SOURCE: 5hp briggs & Stratton lawnmower
ck fuel pump its on the side of the carb
3or4 screws hold cover on .
SOURCE: New Craftsman 20hp Briggs & Stratton 42
first make sure the air intake screen on top of engine is not clogged with debris if thats not a concern you could have a faulty ignition coil etc your engine should have a two year warranty and can be serviced at no charge to you at your local briggs service dealer make sure and check your manual for the fine print though. Briggs makes a great engine and very rarely have I ever seen a problem allthough if you were to have an engine issue it will accur during the first few hours of opperation good luck
