I replaced the flow meter and cleaned the screens but am still getting the f h error code
    Master:
  • 492 Answers
Sometimes things can get out of sync. Try unplugging the machine for a few hours to rest the code on the board. It's like rebooting your computer. I did this to mine and it cleared up the problem.
Posted on Oct 16, 2013
On Duet Front Loader- Error code F/H. Can see plenty of water coming in so I suspect pressure switch. Is this a common problem? I don't quite understand your pressure switch check procedure in your...
This error code F/H tells that no water entering the machine is detected during the fill step of the wash cycle. It can be due to siphoning, pressure switch not tripping or stuck in the empty position, or the water flow meter is not reading the correct water flow. Make sure that no water is draining out of the drain hose due to siphoning as water fills in and position the end of the hose to prevent such condition.
The pressure switch is stuck and not tripping if after 8 minutes the water flow meter has detected 10.5 gallons of water passing through it but the control has not detected the pressure switch trips. The water valves are then turned off and the error code is flashed. The error code is also flashed if after 30 seconds the water valves are turned on and no water is detected entering the machine due to sticking flow meter pinwheel or the flow meter is not positioned properly.
The flow meter is position sensitive. The pinwheel must be installed vertically. Any canter to it may cause the wheel to stick. Many times the F/H error code pops up only when HOT water passes through the flow meter. The hot water may be softening the hoses on either side of the meter, causing the flow meter to canter. Stuck or cantered pinwheel affects the flow meter's ability to read water flow accurately. Disconnect the hoses from the flow meter then blow air into the inlet to free a possible stuck pinwheel. Replace the flow meter if the pinwheel is totally stuck and cannot be freed.
Check the pressure hose for possible kinks or air leaks if the flow meter pinwheel is positioned vertically and turning freely. Kinks and air leaks in the pressure hose prevents pressure built up in the pressure switch dome and the pressure switch cannot trip. Check the pressure hose including its connections to the pressure switch and the bottom of the tub. Blow air into the pressure hose to clear possible clogs or kinks and check it for air leaks. Also blow air into the pressure switch dome to free a possible pressure switch contacts welded or stuck in the empty position. You should hear the pressure switch clicks if it is tripping. Replace the pressure switch if not tripping and the pressure hose has no kinks or air leaks.
Jun 18, 2011 | Whirlpool Duet GHW9150P Front Load Washer
HE3t has an FH error code checked the following and are OK. pressure switch, flow meter, and inlet valves water flows in without restriction. What else could it be? Craig
Thank you for contacting fixya.com.
FH error code means low water inflow. In this error washer is not filling when the fill valve opens.
To clear the error please follow the bellow instructions:-
Press the "Stop" button twice with your finger. This cancels the cycle and stops the washer. Unplug the power cord from the wall outlet.Turn the water shut off valves clockwise to stop the water flow to the washer through the supply hoses. Pull the washer away from the wall enough that you can access the hose connections at the back of the washer.
Set a bucket under the area of the hose connections. Unscrew the hose connections from the back of the washer. If necessary, use a pair of slip joint pliers to help start the connections turning until you can turn them by hand. Set the ends of the hoses inside the bucket.Inspect the screens on the inlet ports on the back of the washer where the hoses connect. Sediment and other debris can block these screens, causing fill problems. Clean the screen with an old toothbrush.
Thread the hoses back onto the washer. Look for kinks in the hoses. Kinks cut off water supply to the washer which causes the FH error code. Once you connect the hoses, turn the water supply valves counter-clockwise to supply water to the washer. Move the bucket away from the washer and push the washer back into its working position.Plug the power cord back into the outlet and start the wash cycle again. If the FH error code comes up again, call a service repairman. If the hoses have no kinks and the inlet screens are clean, there is a problem with either the pressure switch or the flow meter.
Please get back to us if you have further query else please accept the suggestion.
Jun 02, 2011 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
My kenmore he3t gets a code of h and f . I cleaned the filter in front panel and replaced water inlet filter. still getting the code.
Hi
Thanks for using FixYa. Error code F/H means no water was detected entering machine or Pressure switch trip not detected. If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed. It can also happen if the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash. You’ll need to Press PAUSE/CANCEL twice to clear the display and then check:
• If there is no water in the unit:
• Make sure that both valves at the water source(s) are turned on all the way.
• Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
• Verify inlet valve operation
• If there is water in the unit:
• Verify Drain pump operation
• Pressure Switch Hose is in good condition and properly connected to Tub and
Pressure switch
• Verify there is not a siphon problem
• Verify wire harness connections to; Inlet Valves, Pressure Switch, Drain Pump,
Flow Meter and Central Control Unit (CCU)
• Check all hoses for possible leaks
• Verify pressure switch operation
• Verify flow meter operation
• Verify CCU operation
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Apr 19, 2010 | Washing Machines
Keep getting fh code, replaced pressure switch, replaced flowmeter, noticed that the hot water would not shut off, even put on cold water only and hot water would still run. Machine is constantly sending...
the code means water inlet problem
Have the water flow meter checked or replaced. If the internal wheel sticks inside the meter, the CCU will think no water is entering the washer and give you this error code.
Do you notice an above normal amount of water in the washer when you notice the error code? This is a good indication the flow meter is faulty. You can obtain the part from Sears and install it yourself. Very easy fix.
The flow meter has a reed switch on the side of it.
Sometimes this switch fails and doesn't respond to the magnetic wheel inside the flow switch. It is suppose to provide a pulse action as the wheel turns. The CCU interprets these pulses to determine flow rate. Just because the wheel inside the meter turns, does not necessarily mean the reed switch is functioning. Exactly when do you see the hf error. At the exact moment you see the error is the washer's water level higher than normal?
A GOOD TIP IS: blow air back into drum and into the pressure switch. It will usually work after that!
Mar 10, 2010 | Kenmore 44832 Front Load Washer
F H error
no water error code. first check the the water is on and the hose screen is clean.
No water detected entering machine or Pressure switch trip not detected.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
    1. Make sure that both valves at the water source(s) are turned on all the way.
    2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
    3. Verify inlet valve operation
    1. Verify Drain pump operation
    2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
  • Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
Jul 27, 2008 | Whirlpool Duet GHW9150P Front Load Washer
No service manual
water filters in the hose attachment at the machine cloggs up. Sometimes fast. take off hose and clean the filters.
This is from whirlpool:
FH No water detected entering machine or Pressure switch trip not detected. If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
Potential Causes
- Make sure that both valves at the water source(s) are turned on all the way.
- Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
- Verify inlet valve operation
- Verify Drain pump operation
- Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
• Verify wire harness connections to; Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
Replace failed component.
Jun 04, 2008 | Whirlpool Duet GHW9150P Front Load Washer
F h code on duet
FH= No water detected entering machine or Pressure switch trip not detected.
Or
Potential Causes
Pressure switch
Apr 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Erroe code F H
jse, most of the time when I run into this problem it's because of the flow meter. This is a reed device that sits in line with the water inlet valve and monitors the water coming into the machine. Things to check; make sure both water valves are on and that the inlet valve screens are clean. (You get to them by removing the hoses to the washer). The drain pump filter is clean. (Remove the bottom panel and unscrew the pump filter and clean out). The inlet valves are actually working. That the drain hose is not too far down the standpipe causing a siphon. All the harness connecting to the inlet valves, pressure switch, drain pump, flow meter and main control are seated properly. You will have to remove the top to get a look at these. Three screws on the top backside and it slides of toward the back. If all these things check out. Then I would suspect the flow meter itself. Easy job. Catriver..
Jun 07, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
11 people viewed this question
Top Washing Machines Experts
