Question about Whirlpool 25.3 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - White-on-White
Icemaker no water test point v-n no power - Whirlpool 25.3 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - White-on-White
My lg refrigerator lsxs26326 is dispensing water but not filling ice tray up. What could be wrong?
the water solenoid valve for the water dispenser is separate from the icemaker water supply solenoid valve . get to the icemaker water supply solenoid and test it if it works alright . unplug the fridge from wall outlet do not close water supply valve. disconnect water tube connection on the water discharge side of the icemaker water supply solenoid valve . pull - out power supply connection of the solenoid coil . connect solenoid valve directly to wall outlet. a faint click should be audible and water should come out from where the tube was removed -- from the water supply discharge side. if no water is coming out with the solenoid plug in , then the solenoid is faulty. but if water comes while solenoid is powered -on , check the position of the icemaker lever. if it is on off position icemaker timer won't activate icemaker water supply valve..move icemaker lever to on and check for water pouring into the icemaker tray' if no water comes out . change the icemaker timer. thanks.
Mar 04, 2016 | LG Refrigerators
How do i fix ice maker
Could be 2 different problems. Inlet water valve is a dual valve (2 halves). 1 half feeds water to the door dispenser, the other half fills the icemaker. The icemaker half could be bad or blocked up with sediment causing a no fill situation. 2nd problem could be the icemaker itself which sends power to the inlet valve when it needs filled. Usually the inlet valve fails first but you need to test and see.
Apr 14, 2015 | Refrigerators
I have tested the valve and it's is opening and closing but the icemaker keeps putting power on the valve everytime it cycles and never stops. The valve is shutting off water each time. What in the...
Yes, every time the icemaker cycles, it will switch in power to the icemaker water valve. the icemaker is pretty much a standalone device. All it needs is power and water supply, and valve. If it has both, and is not working properly, then the icemaker is bad.
Oct 01, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
Maytag MF12568AEB: Icemaker stopped working. Ran all the "service tests" and determined the icemaker is operational. I am thinking the water tube that dispenses the water into the icetray may be clogged. I...
If you're wanting to 'melt' any blockage, direct your dryer at the point where the water supply tubing goes into the area around the icemaker. HOWEVER, there should also be a solenoid on the unit that opens to allow water to flow; that's usually the problem. Do you know if the solenoid is working? The solenoid is normally located and the bottom of the unit. The water supply line from the house feeds into it. An electric solenoid with also have a couple of wires coming from it for power. Try tapping it with a screwdriver a couple of times incase it's a little stuck. There may also be a problem with the board that control your unit's programs
Feb 24, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
GE Icemaker stopped making ice. everything else
Try these steps
  1. Check the shutoff arm
  2. Check the supply valve
  3. Inspect the water supply line
  4. Test the shutoff switch
  5. Check the freezer temperature
  6. Inspect the ejector gear
  7. Test the ejector motor
  8. Test the ice mold heater
  9. Test the holding switch
  10. Test the water inlet switch
  11. Test the thermostat
  12. Test the water inlet valve
pls rate my suggestion.......
Jul 25, 2009 | GE Monogram ZDI15C Automatic Icemaker
Samsung RS2545SH refrigerator just stopped making ice. any advice?
Samsung Fridge  RS2545SH stopped cooling. The fridge section is about 50/55 and freezer is around 45. It wont go below. At one point, there was rumbling rattling sound from the compressor. Icemaker also stopped woprking.
Jul 18, 2009 | Samsung RS2630SH Side by Side Refrigerator
Icemaker don't work
Most icemakers have their own brains so to speak all they need is power, low temp, and water to work.So check the water supply to the unit and use a test cord to check the water valve. It could be not cold enough in the freezer ,check temp and shrouds etc.
once you've ruled out outside influences you've got to dismantle the unit and check microswitches and stats all the while on the lookout for something thats broken lol
May 19, 2009 | Maytag MSD2756G Side by Side Refrigerator
Icemaker no water going into icemaker
water valve is turned off, or waterline is blocked unit may have a screen or filter which can become blocked. remove waterline where it connects to unit,turn on water to check water flow at this point.no water, check line backward from this point to find pressure loss.if pressure is at unit connection procede checking forward for restriction . test machine.
May 14, 2009 | Whirlpool Refrigerators
Amana scd25tw
It sounds like you have covered all the primary troubleshooting checks. There is only one thing I can think of at this point.
Check the voltage coming to the water valve during the icemaker cycle. The power to the valve is decreased by the resistence of the icemaker heater from 120 volts down to about 108 volts. It is not uncommon to have a valve that will open when you put 120 volts to it, as you do when you switch solenoids, but not open at the decreased voltage when it goes through the icemaker circuit.
If you are getting voltage to the valve when it cycles, and you know for sure the water line to the icemaker is clear, then you will need to replace the valve.
Post back and let me know what you find.
Nov 11, 2007 | Refrigerators
Samsung rs2555sl icemaker
replaced circuit board. Problem solved
Oct 17, 2007 | Samsung 24.8 Cu. Ft. Side-by-Side...
Whirlpool 25.3 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - White-on-White Logo
18 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
