Question about Samsung SyncMaster Computers & Internet
I cannot import photos from my Samsung phone to my Samsung computer. The necessary device shows on my computer "Devices" screen but isn't showing on my Photo Gallery small window even when I press "Refresh". My drivers are all up to date and on the phone it says"Connected to computer". What can be the reason for this?
  • 2,113 Answers
Make sure you are using a data cable and not a charging cable for this.
Posted on Oct 16, 2013
4 Suggested Answers
  • 198 Answers
SOURCE: 1inch black line down right hand of screen
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Posted on Feb 20, 2008
budmrtn
  • 11361 Answers
SOURCE: I have a Samsung SyncMaster 901B, it's not new, a
What happen when you hook this monitor up to other PC that has the video setting 1280 X 1024 60 Hz? Just ant to narrow down the problem before opening up the monitor. You may have logic problem in the logic board. If it does the same with other PC, then open it up and inpsect the inside for such thing as failed caps on the logic board or on the main power supply board, I think more likely to be ROM chip on the logic board is scrambled.
See typical failed monitors: http://s807.photobucket.com/home/budm/allalbums
Posted on Mar 30, 2010
SuperTech-11
  • 1591 Answers
SOURCE: I have the samsung 2232gw
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
If you repeatedly turn it off and on, eventually it'll probably stay on, but every time you turn it off, the TV will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for some time and then try again.
If you aren't tech savvy, don't worry, read the rest of this solution and watch the videos.
If you are handy with a soldering iron and can identify the power supply and inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering, and even then, you should go OVER, not under the uF rating).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for many Samsungs with the same issue) on youtube.
http://www.youtube.com/watch?v=Mm51C_RDIZE
http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related
http://www.youtube.com/watch?v=8l0AUj8QUkg&NR=1&feature=fvwp
http://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=related
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors.
The parts are cheap, and skill required is minimal.
Posted on Jun 17, 2011
Testimonial: "This will help out. Thank you very much."
I have a samsung tablet and I want to transfer my photos from my phone to my tablet
Plug both your phone and your tablet into your computer and transfer them under the "my computer" tab. All devices will show up and be able to transfer files from device to device.
Sep 22, 2014 | Apple iPhone 5
Recover deleted photos
Try GT Recovery for Windows! GT Recovery for Windows is a professional data recovery for Android phone or tablet. It can restore deleted photos,videos,audios,documents from Android SD card and internal memory. Whenever you lost important pictures or deleted photos by accident, you can use it to scan and recover the images on your Android devices.
Here are the steps to recover deleted data on Samsung Galaxy S4.
With this way you can recover deleted data on any brands of Android device such as Samsung, HTC, Huawei, Sony, Motorola, Lenovo, LG, Sharp, etc.
Download Link: http://www.gtrecovery.net/
Jan 29, 2014 | Sony Ericsson Mobile Phone Xperia U ST25i...
Accidentally deleted photo's video's and other files on my HTC desire. How can I get them back?
You may try asoftech data recovery which helped me before. You can download trial for free
http://www.asoftech.com/adr/
Please be noted that your phone memory should show as a drive letter in your explorer, if not, you need to take out your memory card and connect using a card reader, or plug-in to card reader slot if there's any on your computer.
Nov 28, 2012 | Cameras
How to recover phone data in a formatted samsung galaxy ace plus mobile
You may try this mobile phone photo recovery software which helped me before. You can read this tutorial for detailed info
How to recover files from mobile phone
Nov 22, 2012 | Samsung GT-S7500 Galaxy Ace Plus -...
I want to download photographs from my iphone?
Plug in your iPhone to your computer, if it's a PC you will need to use the Photo Import Wizard and if it's a Mac you will need to open iPhoto.
Dec 08, 2011 | Apple iPhone 3G
I have an Inspiron one. Normally when I put my SD card in it pops up an option to import the photos. Today, I put my SD card in and nothing. So I don't know how to import my photos.
Click to the "Start" icon on the bottom left side of your desktop and click on "Computer". A menu will open showing the storage devices attached to your computer. You should be able to click on the SD device to open.
Jul 02, 2011 | Computers & Internet
How to show pictures from this phone to the computer?
Use Bluetooth
Your phone is equipped with Bluetooth
technology, enabling you to connect the phone
wirelessly to your computer to exchange photos.
1. In Idle mode, press
<Menu> and select
Settings → Bluetooth →
Activation → On.
2. Select My phone’s
visibility → On to allow
other devices to find your
phone.
Turn on
Bluetooth
<Menu> and select
My devices → Search for
new devices.
2. Select a device.
3. Enter a Bluetooth PIN or the
other device’s Bluetooth
PIN, if it has one, and press
<OK>.
When the code is entered on the computer, pairing completes.
if your PC does not have bluetooth you can buy an inexpensive bluetooth usb dongle here-
http://www.amazon.co.uk/gp/product/B001BRV7JE?ie=UTF8&tag=microsift-21&linkCode=as2&camp=1634&creative=19450&creativeASIN=B001BRV7J
//javaftper
Jul 31, 2010 | Samsung SGH-X830 Cellular Phone
Photo transfer
yes i have now solved the problem via my son who called round today.
1 connect your usb cable to the p/c
2 on the phone go to menu
3 to settings
4 then usb settings
5 then mass storage
6 phone will show you are connected to p/c
7 then just follow the promps on your screen
8 job done
Jul 07, 2008 | Lands Phones
Computers & Internet Logo
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
