Question about LG Washing Machines
The bearing needs replacement. Can I use the machine until the replacement arrives?
    Master:
  • 492 Answers
Your call buddy
Posted on Oct 16, 2013
What size needle do I need for a brother db2 755 mk3?
Contact your local Brother dealer. They carry the needles you need for your machine. The needles should all be the same length for your machine. If you continue to have issues with your machine, be sure that you ALWAYS RAISE the presser foot when threading the top thread. If there are still more problems, you may have knocked the machine out of time when it broke the needle.
Feb 13, 2018 | Brother Sewing Machines
Bosch demolition hammer bearings are ceased up, how can I remove it properly to replace?
Ok here goes. Purchase or use the bearing cover nut 3613461500 that you have taken from the base of the machine. and drill a 6mm hole in it. remove the armature from the machine and measure how far the end of the armature sticks out of the bearing. then fit the cover nut onto the bearing holder and whilst supporting the cover nut use a puller or press to press the armature off the bearing through the cover nut. Replace the bearing in the holder and press the bearing and holder back onto the armature until the amount of armature shaft showing is to the same distance that measured in the first place. Hope this helps.
Dec 13, 2012 | Bosch 11316evs Elec Vs Sdsmax Demolition...
Lg 3850dd3006e makes noise
I had the same issue with my LG it has a stainless steel impeller the grinds up the food particles and if one of the veins get slightly bent it causes that problem. The tack took it out straightened it out until the new part arrived and it worked fine. He did return to replace it but I don't think it was needed
Jul 29, 2012 | LG 24 in. LDF 7811 Built-in Dishwasher
When spinning the drum makes a vibrating/grinding noise/feel to it, would this be bearings gone in the drum "any ideas"
Yes, that's a classic sign of a failed drum bearing. It wi;ll continue to get noisier and may eventually cause a leak from the machine which may cause more expensive repairs if the water and highly corrosive washing solution damages other parts.
The bearing itself is available and can be replaced, but your machine is not designed with bearing replacements in mind. Replacing the bearing involves a near complete strip-down of the machine to completely remove the drum assembly. The outer polypropylene drum will often crack when the old bearing is removed or the new one is refitted and the job is very labour intensive.
The bearing is designed to last the life of the machine, and the machine is only expected to last about four to five years before other parts start to fail as well. If the bearing fails during the warranty then the usual fix is to replace the entire inner and outer drum assembly.
I can't give you a step by step guide, but drum replacement is not cost effective if you have to pay for the repair, and bearing replacement may be worth trying if you know an experienced DIY mechanic and appreciate the risks. The part is relatively cheap, but if the repair fails you've blown money which could have gone towards a new machine. Dismantling to replace the bearing is fairly straightforward and commensense, but on some models the spot welds on the rear of the casing need to be drilled out and they can be replaced with pop-rivets afterwards. A short length of scaffold pole or a large socket can be used to drift out the old bearing and press in the new one. It's also necessary to replace the drive-belt as well, but you can leave that extra cost until you're sure that the bearing replacement has been a success.
Haynes publish a washing machine repair manual; you can either buy it or will often find that it's available at your local public library and it's invaluable if you lack confidence with jobs like these.
If you need to buy another machine, then try to avoid Merloni Group products such as Hotpoint, Indesit, Candy, Ariston. They may be cheap, but they don't last. Brands like LG, Miele, Siemens and AEG don't cost twice as much but they do typically last more than twice as long. Bosch for some reason, definitely aren't as good lately, despite being part of the same group as Siemens. A good quality basic machine will usually serve you far better than a feature-packed Merloni piece of tat.
Jul 08, 2011 | Hotpoint Aquarius WF000 Front Load Washer
Bobbin winder on kenmore model 148 15600 not working
I have the same model machine with the same problem!
The shaft of the bobbin winder 'froze' (apparently from old or incorrect lubrication). When it froze, it's rubber wheel (which they call a 'ring'') that is driven off the back of the main hand wheel (to the left of the winder) developed a flat spot, so it also had to be replaced. (Enter the machine model number at /www.searspartsdirect.com to see how it fits together. Their exploded parts diagrams are excellent.)
Two screws hold the top cover on the machine, and two screws hold the bobbin winder to the underside of the cover. Note that the winder assembly mounts are slotted, so when reassembling, the winder must be adjusted to engage with the drive wheel. (Note its old position.)
You might be able to use a penetrating oil to clean the bearing without dis-assembly of that shaft from the bearing, but that didn't work for me.
I tried to get a whole new bobbin winder (Sears pt # 214458), as well as a new ring (Sears pt # 61662). but Sears no longer stocks that.
I found the ring cheapest at http://www.a1sewingmachine.com, but they no longer had the winder.
I found both parts at http://sewingmachine221sale.bizland.com/store/page21.html, but before the order arrived, I was able to repair the old one, so if the winder does arrive I'll have it as a spare.
I made a fixture to remove the press-fit wheel (that mounts the ring) from the shaft, so I could clean and re-lube the shaft bearing. I used a lathe to drill a 8mm hole > 40 mm into the end of a 1/2 in. aluminum rod, and mounted the rod in a press, and used a 3/16 steel pin to push the shaft out of the wheel. Clamping the rod in a vise and using a pin punch /hammer might also work, but it was very hard to separate them, so that might not work.
When lubricating the shaft/bearing of the winder, be sure to use a good quality sewing machine oil. I've had bad experiences with bearings like this lubed with generic oil (like 3-in-one oils) which gummed things up in a very short time.
Good luck
Paul Higgins
pch350@verizon.net
Sep 30, 2010 | Kenmore Sewing Machines
'94 Jeep Grand Cherokee Limited: Ball Bearing falling off
unless your going to rebuild this yourself i would be bring it back for inspection. Its your only option.
Jul 19, 2010 | 1994 Jeep Grand Cherokee
Hotpoint WMA48P bearing replacement
REMOVE THE POWER PLUG FROM THE SOCKET
this is a messy job, you will need to remove the lid remove the front of the machine 2 -3 screws behind the clip on pannel front bottom I cant rember if the front hangs on two lugs one either side or if there are acouple of screws behind the faceplate, you will need to disconnect the door safty switch (make note of the wire positions), remove the wire band that clamps the door seal to the outer drum, now you should be able to see the drum and the drum outer casing, you will neeed to remove the access panel from the rear of the machine and if the belt has not already come off remove it , you notice a large nut holding the flywheel on inspect closely as there may be some securing tags (large washer with folded edges stopping the nut from comming undone ) remove nut , you will now need to remove the drum from the front of the machine using a peice of wood place on shaft and strike it with a heavy hammer or a mallet do not worry about damaging the shaft as you will need to replace this as well as the bearings as when bearings fail it is normaly to do with water getting to the bearing and corroding them (rust) untill they give up this normally damages the shaft, once the shaft is removed if you look through to shaft hole you will see the outer casing of the beaings thease need to be removed normally by tapping out (not always easy)there are two one at fromt one at back the back one is removed from inside the drum front removed from rear of machine , once this is all clear you are ready to the reverse putting it all together, the bearing kit should contain all you need to replace the bearings including the spider ( the three legged fitting that connects to the drum and has the shaft on it) when replacing the bearings make sure that where the old bearings come out of is nice and clean (fine sanpaper to remove small high spots) i use vaselene to aid bearing seating , using a rubber mallet genlely tap the edge of the bearing into place (never hit the center of the bearing as you could damage the seal and or the bearing) when the bearings are in smear some grease onto the shaft and rfit, a bearing kit trade is about 20 uk pounds
Jan 15, 2010 | Washing Machines
F1 code, bad filter, bad bearing, bad machine
Hey I just quit from sears what you are saying can't be true. LOL jk. I know exactly what you mean I had to order a bearing 3 times before I got one that was not broken. I wish you the best.
Jan 11, 2009 | Kenmore Oasis HE 27082 Top Load Washer
KSM5PS won't turn under load
Hi. Remove the top cover and look for the plastic transmission housing, it's toward the front of the machine. Look for cracks in this housing. If the housing is cracked, remove it and look for further damage to the worm gear assembly and the bearings and bearing seats that support them. You'll have to remove some of the grease to inspect the parts. If you're lucky, only the trans. housing will need replacement. If, like me, you're not so lucky, you may have to replace the housing, wormgear assembly, bearings and re-work the bearing seats so that the new bearings fit properly. Although Kitchenaid advertises that their mixers can easily handle bread dough, the truth is...They can't. This scenario happened to me and I had to replace all of the above. Be prepared to wait a month or more before your parts arrive. Specify that you want the METAL trans. housing. I'm still waiting (6 wks.), for a single bearing. If this solution works for you, please rate my solution. Good Luck! ricardok45
Nov 14, 2008 | KitchenAid KSM5PS Heavy Duty Stand Mixer
How do I replace the door seal on a Hotpoint WF860
unless you are really bored don't try it ..front side not bad but inside where it mounts onto outer tub can be a big black bear ..little space to work and rear band even tougher
Aug 29, 2008 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
20 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
