Question about Dryers
Have N75AC compressor washed radiator and now compressor won't run fault 44 removed moisture sensor in back and dryer it still won't run any ideas
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 142 Answers
Are you talking about a dryer? Radiator? What did you actually do to the unit?
Please be clearer so someone could help you.
Posted on Oct 18, 2013
5 Suggested Answers
aborcass
  • 2651 Answers
SOURCE: Kenmore Dryer Moisture Sensor
if you can get it to go back in sure why not,its simply a metal strip plugged in to a wire measuring resistance, so if its not physically broken you should be able to pop it back into place
Posted on May 12, 2008
ftw1952
  • 10319 Answers
SOURCE: moisture sensor
Yes it does
Posted on Apr 15, 2010
TheMobilian
  • 8220 Answers
SOURCE: Kenmore dryer 110.86864100 - Where is the moisture sensor?
Ain't no moisture sensor. This is is not an electronic sensing machine. It uses another method to determine dryness. An orange wire connects to the base of the heating element. The timer motor is driven by power from it in auto dry. The timer motor is VERY slow. Slower than most dryer timer motors.As the clothes get dryer the heat is not needed so the element is turned off by the control thermostat which is mounted next to the skinny white fuse on the blower housing. This allows for the turtle like motor on the timer to advance. Once the clothes get to the point of dryness the heater stays off way longer and the timer motor advances on over to the cool down and carry on over to the end of cycle. So the clothes won't always be dry due to factors like lint buildup in the blower housing, venting to outside and so forth. having said that my mom bought a brand new Kenmore dryer and I set it on 55 minutes timed drying. At the end of that them clothes is still damp. I then set it to auto dry high heat and that usually gets em dry. I think the main probo with this dryer is the thermostat ain't set as high as older models to keep the heat at a moderate temp so that the limits won't blow on models in apts and such. Just a theory.
Posted on Sep 19, 2012
jdhnmi
  • 143 Answers
SOURCE: miele tumble dryer t294c moisture sensor what is the part code
Check this site out www.repairclinic.com and enter in your model number you should be able to find the part there .
Posted on Nov 24, 2012
Samsung DV331AEW starts cycle but skips from 44 minutes remaining to 1 minute remaining. How to fix this?
sounds like could be a control board issue? have to check with multi meter suggest you check the timer wire connections on the board looks for burns or seized areas as well as conitnuity
Feb 18, 2015 | Samsung DV331AEW Dryer
Whirlpool electric dryer
Hello there and welcome to Fixya :
This is a fairly common problem with these whirpool dryers.
I will provide you with the 7 most common things to look for
which contribute to the symptom Dryer won't stop are listed below. Check or test each item and watch any available videos. If you are still unable to solve the problem you may need to do additional research and troubleshooting.
Show all parts for model GEW9878LW0 For the symptom you selected, these are the most common parts or causes, ordered by the likelihood of fixing the symptom.
othercausesandconditions.jpg Air Flow Problem The most common problem when a dryer is slow is when the vent is clogged. If the dryer is slow, check the vent from the back of the dryer to the outside of the house. If that is clogged, clear it completely and test the dryer. If the dryer is slow after the vent is cleaned, clean the internal ductwork of the dryer. This will require some disassembly.
blower-wheel-694089-00918612.jpg Blower Wheel
Item # 686172
The blower wheel draws air through the dryer and pushes the air out the vent. If the dryer won't stop, the blower wheel may not be spinning properly, which reduces the air flow. Check to see if the blower wheel is securely fastened to the drive motor shaft.
Skill Level Skill Level
Part Replacement Video $23.40 Quantity:
In Stock
heating-element-assembly-3401338--00621237.jpg Heating Element Assembly
Item # 528055
The heating element assembly warms the air before the air enters the dryer drum. If the dryer won't stop, it may be because the heating element assembly isn't working - which greatly increases the drying time. Check the heating element for continuity.
Part Testing Video $91.05 Quantity:
In Stock
lint-filter-349639--00685658.jpg Lint Filter
Item # 2659
Dryer sheets and fabric softener can leave a residue on the lint filter, reducing the air flow. If the dryer won't stop, check to be sure air can flow freely, clean the filter as needed.
$38.95 Quantity:
In Stock
moisture-sensor-279366-00565298.jpg Moisture Sensor
Item # 469522
Although not as common, if the dryer won't stop it may be because the moisture sensor is either defective or coated with fabric softener. Clean the moisture sensor contacts inside the dryer and th
Oct 11, 2012 | Whirlpool GEW9878LW Electric Dryer
Whirl pool duet dryer not drying clothes
Inside the door under the filter housing is 2 strips that sense wetness. If they have dryer sheet goop on them they won't sense moisture. the dryer will therefore thank them clothes is dry. Clean them sensors with windex and party on!
Nov 02, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Camera says "Please e-operate after pushing reset
Remove the battery and keep aside for about 15 minutes. Now after inserting reset the camera., if the fault occurs., remove the tape and use a hair dryer to blow into the tape tray section/drum section.
It is possible that the dew sensor is working to indicate moisture, if so the heat will change the fault.
Also if the hall IC's within the drum is faulty the drum will not move and so will indicate a fault-- service.
Dec 24, 2010 | Panasonic NV-DS37 Camcorder
Dryer will run for about thirty seconds and then shut down. if i wait it will start up again and then shut back down.
From your description without a model number is sounds as if you have a dryer that has an electronic control that involves sensing the moisture level of your dryers contents when in use. In this type of dryer there is either a single moisture sensor or 3 moisture sensors on the top of the ba\ffles. What has happened in that case is that the electronic contorl is no longer sensing the moisture level of you dryers contents. When the signal to the sensor is lost the dryer thinks there is no moisture in the contents and shuts off the dryer. The sensoing circuit has a problem in the form a bad densor (in the case of the single sensor type or a worn out drum brush in the three sensor type. There is a possibility that the electronicl control itself has failed. Without model number this is about as far as I can go. It is still cost effective to have your unit repaired. I hope this was useful information.
Jan 09, 2010 | Washing Machines
Washer dryer zwd 1480 zwd 1680 when i put a wash on after a couple of minutes it shoots down to 3 minutes and finishes. any ideas????
I have exactly the same problem, I am doing some testing with mine at the moment and I believe it to be one of the two thermostats in the heating chamber.
If you was to remove the top cover you'll find a long silver cilinder running through the middle of the unit. Looking from the front there are two modules on the left side (thermostats) with 2 wires connected to each towards the back of the dryer. These measure the temperature inside the heating chamber, on removing them the heat stays on, you have probably noticed the dryer is not even getting hot so the moisture sensor won't pick up any moisture in the air so the dryer trying to be cleaver with think the clothes inside are dry and finishes the cycle early.
I wouldn't reccomend removing these thermostats as it will probably overheat and cause a fire risk, however they should only cost a couple of ££ to replace.
Now I've just got to try and source the parts!!
Aug 24, 2008 | Zanussi FJS1225W Front Load Washer
Running but not collecting water...
Dehumidifiers have only a few components, and operate on the same principle as a refrigerator, freezer, or air-conditioner.
Components Residential dehumidifiers have a cooling system made up of these primary components:
  • The compressor is the quiet motor (engine) of the cooling system. It's the black, football-size component at the bottom of your dehumidifier. The compressor runs as long as the dehumidifier humidistat (the humidity-sensor) calls for a reduction in the humidity.
  • The condenser is a series of finned tubes, similar to a radiator. It's usually near the circulating fan.
  • The evaporator is located near the back of the dehumidifier, right above the water-collection container. It also resembles a radiator or a coiled-up set of tubes. When the dehumidifier's humidistat senses increased humidity, it cycles on, which starts the compressor and circulating fan.
  • The circulating fan circulates the air over the evaporator and condenser coils.
Principle When the unit runs, the circulating fan and compressor also run. The fan continually draws room air over the evaporator coils, which are cold, and then over the condenser coils, which are warm. Because the evaporator coils are cold, the moisture in the room collects on them--just as the outside of a glass of icy liquid "sweats" on a warm, humid day. When the moisture on the coils increases, it drips off of the coils into the collection container.
The air then flows over the warm condenser coils and out into the room. This process removes water from the air and, because of the heat from the fan motor and compressor motor, the exiting air is somewhat warmer, as well as dryer.
Jul 29, 2008 | Maytag M7DH65B2A Dehumidifier
Whirlpool Electronic Gas Dryer
I would suggest cleaning your moisture sensors. If you stick your head inside the open door and look straight back towards your lint screen, you will see 2 silver bars. These are your moisture sensors. They can get a coating on them over time. Once this occours, the moisture can't reach the sensor and the machine thinks the load is dry and shuts down. Using the abrasive side of a sponge or even some fine grit sand paper, run it back and forth each of them. You should be good to go if you've already cleaned the area underneath the lint screen, made sure the hose from the dryer to the wall is not kinked, folded over or smashed and you have good airflow coming to the outside of the building.
Jun 18, 2008 | Dryers
I NEED FAULT CODES FOR DRYERS
PF Power Failure
“PF”
flashes to indicate that a power failure occurred while the dryer was
running. Press START to continue the cycle, or press PAUSE/CANCEL to
clear the display.
F-01 Primary Control Failure “F-01” flashes when there is a primary control failure. Replace the machine
control electronics. See Accessing & Removing the Electronic Assemblies.
F-02 Keypad/User Interface
Failure
“F-02”
flashes when there is a stuck button or user interface mismatch. This
fault code will ONLY appear when in the diagnostic test mode. See TEST #5.
F-22 Exhaust Thermistor Open “F-22” flashes if the thermistor is open. See TEST #3a.
F-23 Exhaust Thermistor Shorted “F-23” flashes if the thermistor has shorted. See TEST #3a.
F-26 Motor Drive System Failure “F-26” flashes if there is a motor drive system failure. See TEST #2.
F-28 Moisture Sensor Open “F-28” flashes if the moisture sensor strip is open. This fault code will ONLY
appear when in the diagnostic test mode. See TEST #4.
F-29 Moisture Sensor Shorted “F-29” flashes if the moisture sensor strip has shorted. This fault code will
ONLY appear when in the diagnostic test mode. See TEST #4.
1M 2M 3M 5M 6M
= Contacts closed
Contacts
Function
Start
Run Red
Lt. Blue
Blue-White (Elec)
White (Gas)
Green-Yellow
Red
Black-White
BLACK
BLUE
WHITE BLUE
WHITE
WHITE
Pluggable Drive Motor Switch Gas Valve - Gas Dryer
Centrifugal Switch (Motor)
Gas Valve this is about close as i can come its matag electronic but not comercial should be about the same software though some where on or in the dryer should be a tech sheet with codes
May 21, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
32 people viewed this question
Top Dryers Experts
