Question about AdobeAir Mobile Swamp Evaporative Air Cooler Air Conditioner
Blower motor I need the whole blower assembly model A6500A Serial# A03090585A
  • 400 Answers
I would start with E-bay. Failing there I would check with Grainger.
Posted on Oct 21, 2013
Error e04 on my pool heater
We did not get from you, other than a classification by the forum of what kind of heater you have.
An E04 is a common error on Pentair MasterTemp heaters. It is saying that the heater is not closing the air pressure sensor = normally bad fan. But...
It just means that the fan is not coming on and blowing air to trigger the Air Pressure Switch. Could be:
  • Bad fan motor
  • Maybe just a bad 5MFD motor capacitor - much cheaper.
    • See pic: Silver thing on the right side of the motor
  • Possibly rusted out squirrel cage?
  • Or even a disconnected wire/plug. Check to ensure the plug is in all the way and good connection. See Pic below: Just under the motor you can see the square white thing, that is a 2 part plug that will unplug. The left side of that is in the inside of the heater cabinet, inserted in the back metal wall, and the wires go where they go. You won't need to mess with those. When you lift off the top of the heater, the blower assembly will be visible and the plug will just need to be unplugged. From that white plug assembly, from the right side on, the whole assembly will disconnect power connectivity. Then undo the 4 screws that attach to the heater and the whole blower assembly will lift right out.
    • Burned wire or wires for fan connection
Check all of this out.
btw... the blower looks like the pic below.
Good Luck
Mar 14, 2015 | Aquatemp Products Pool & Spa
Blower motor for furnance serial number 8595G22331
The serial number doesn't help. You need to reference the model number and brand
Jan 31, 2015 | Heating & Cooling
How do I remove the blower motor on a Kitchenaid cook top model number kecd866rww01
I think that you have to lift the whole cooktop out and the blower assembly is attached to the bottom.
Installation manual and user manual are here for viewing or download.
KITCHENAID Counter Unit Electric Parts Model KECD866RWW01
Sep 30, 2014 | Cooktops
I have a 2002 Grand Am SE, my heat works fine, temperature wise, but doesn't flow out of my vents very well. Whenever I turn the heat on I hear a loud humming/vibrating sound coming from my blower...
I had a very similar problem on a Buick recently. Like mine, your blower's fan blade assembly may have come loose from the motor shaft. There is a very small washer type clip that holds the fan blade part to the motor's shaft. Usually the whole blower assembly is pretty easy to get to and take off...usually. A lot of GM cars had the assembly accessed from the firewall behind the engine. You would need to pull the blower motor out and check the fan assembly.
Jan 21, 2014 | Cars & Trucks
A6500a serial# a03090588a
E-bay, Grainger, or the manufacturer.
Oct 16, 2013 | AdobeAir Mobile Swamp Evaporative Air...
We have a Intertherm Furnace Model # MGHA-056ABCFC-01 Serial # MGH9205-01793 115va 60hz 1ph 5.9amps 1/8hp rpm 1050 We need to find a blower motor and a blower wheel for our furnace. Can you help...
Phone book, refrigeration distributors, call and give unit make model # serial # 1ph 1050rpm 1/8hp and frame type of motor. Usually a belly band. Though any good parts house can get all needed info off of make model serial. You might need to call a few since many will not sell to you if you are not licensed.
Feb 26, 2011 | Heating & Cooling
It seems the bearings on my Induced Draft Blower Motor are going out. The furnace runs for a bit then I can hear the motor seizing. It has been making whining noise for awhile but has gotten...
While you may be able to get just a motor it will not save you much. You will also run the risk of damage to the housing or fan(s) when you take the old one apart and try to install a new motor. Unless the new blower unit is several hundred dollars I would recommend you replace the whole assembly.
John
Dec 02, 2010 | Goodman B1859005 Induced Draft Blower...
Blower motor does not turn on until I tap box by
That sounds like you have bad connection to the blower motor or the speed control resistor or the blower motor itself.
If the motor does not run with the heat control at maximum then your blower has worn out brushes, which needs replacing, may be easier to get a blower motor from a breakers yard and replace the whole blower assembly. Check the ocnnectors first.
Jan 30, 2010 | 1990 Geo Prizm
How to install a new blower motor in a Goodman gas
remove the blower unit it slides out on some gas furnaces you may have a control bord in the way if you dont have a goodman motor you will need a belly band to clamp to new motor to provide the mounting arms also after loosening the shaft set screw spray w wd40 turn on side and shake motor should fall out if gas furn 115v motor hope this helps
Jun 09, 2009 | Heating & Cooling
Blower fan does not work on low or medium only on high. Lx model has auto climate control. wondering if it is blower motor, blower resister, or control (bad contacts). All buttons work on climate control....
Sounds like the problem is more with the blower motor assembly itself. The blower motor have micro-proccers built itnto them which comunicate with the control heads and do the actual regulating of the fan motor. Dealers have computers with diagnostic software which allows them to monitor what is happening in the eletronic controls of the vehicle. Electronic diagnostics without the diagnostic software makes it very diffecult to pinpoint the actual item causing the problem.
Jan 01, 2009 | Hyundai Motor 2003 Sonata
AdobeAir Mobile Swamp Evaporative Air Cooler Air Conditioner Logo
Top AdobeAir Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
Are you an AdobeAir Heating and Cooling Expert? Answer questions, earn points and help others
