Question about Husqvarna Garden
Replacing starter solenoid
Is there a video on how to replace the solenoid for a tyh1848xp
  • Husqvarna Master
  • 2,478 Answers
Try youtube On the line write replaced starter solenoid on your model.
Posted on Oct 16, 2013
  • thonas smith
    thonas smith Oct 17, 2013
    TY i replaced the solenoid and ignition switch Didn't help the lights come on like before usally if you pull the pto out or in with the key on not running you can hear it click.It isn't doing anything.My next guess is a bad safty switch which ill have to look up to find..
2 Suggested Answers
  • 16 Answers
SOURCE: Husqvarna LT2042
the soneloid switch sends power to starter . check power on red wire on starter when key on full .if no power must be soneloid switch problem even though it clicks
Posted on Nov 11, 2008
Starter needs replaced
STARTER PROBLEMS
It can be faulty starter or there is loose connection from battery to starter. The starter assembly gets power from battery. Check voltages at starter wires and see if you are getting 12 volts or not. If not then its no power issue due to low battery volt or no connection between battery to starter.
To solve these problem, I suggest you to refer these direct help links:-----
Click the link below: ------
How to test starter solenoid?
http://schematicsdiagram.blogspot.com/2011/06/how-to-test-starter-solenoid.html
How to test cars starter?
http://schematicsdiagram.blogspot.com/2011/06/how-to-test-cars-starter.html
How to replace starter in car?
http://schematicsdiagram.blogspot.com/2011/06/how-to-replace-starter-in-car.html
These will help.
Thanks.
Feb 15, 2013 | 2000 Ford Explorer
Starter relay location on 1999 durango 4x4
Its located in the under hood engine compartment fuse box.
There will be three same relays.One for fuel pump and other for horn and bit bigger one for starter controlling.
For more help regarding starter
CAR STARTER REMOVAL? TESTING
One Wire From Starter Motor Goes To Solenoid And Other Goes To BATTERY. Starter GETS 12 VOLT SUPPLY FROM BATTERY AND WITH THESE VOLTAGE IT TURNS THE MOTOR AND THIS TRIGGERS THE STARTER SOLENOID AND YOUR VEHICLE RUNS.============
For your help there are few relatively help links showing how to remove and install starter with proper instructions:-----
These help links will help.
Click the link below:-----
How to replace Starter on Infiniti Q45?
http://schematicsdiagram.blogspot.com/2011/12/how-to-replace-starter-on-infiniti-q45.html
2006 GM Montana: How to replace Starter Solenoid?
http://repairhelpcenter.blogspot.in/2012/06/2006-gm-montana-how-to-replace-starter.html
Saturn SL2: How to replace Starter Motor?
http://howtobyme.blogspot.in/2012/06/saturn-sl2-how-to-replace-starter-motor.html
Saturn SL2 Starter Wiring Diagram?
http://schematicsdiagram.blogspot.in/2012/06/saturn-sl2-starter-wiring-diagram.html
Oldsmobile starter solenoid replacement procedure?...
How to replace Oldsmobile starter moor?
Oldsmobile starter motor testing?
Oldsmobile STARTER MOTOR NOISE DIAGNOSIS?
These details will help.
Thanks.
Nov 28, 2012 | 1999 Dodge Durango
Cant remove my starter from 1997 fordareostar
How to test starter solenoid? http://schematicsdiagram.blogspot.com/2011/06/how-to-test-starter-solenoid.html -------------------- How to test cars starter? http://schematicsdiagram.blogspot.com/2011/06/how-to-test-cars-starter.html ----------- How to replace starter in car?
How to replace Starter on Infiniti Q45? http://schematicsdiagram.blogspot.com/2011/12/how-to-replace-starter-on-infiniti-q45.html
Thanks.
Nov 26, 2012 | Cars & Trucks
How 2 wire a stater on a 2000 chevy cavalier
How to test starter solenoid? http://schematicsdiagram.blogspot.com/2011/06/how-to-test-starter-solenoid.html -------------------- How to test cars starter? http://schematicsdiagram.blogspot.com/2011/06/how-to-test-cars-starter.html----------- How to replace starter in car? http://schematicsdiagram.blogspot.com/2011/06/how-to-replace-starter-in-car.html
-----------How to replace Starter on Infiniti Q45? http://schematicsdiagram.blogspot.com/2011/12/how-to-replace-starter-on-infiniti-q45.html
---------- 2006 GM Montana: How to replace Starter Solenoid? http://repairhelpcenter.blogspot.in/2012/06/2006-gm-montana-how-to-replace-starter.html
-----Saturn SL2: How to replace Starter Motor?
------------These details will help.Thanks.
Nov 23, 2012 | Cars & Trucks
1991 Honda Night Hawk 750.., battery fine but the fuse box clicks when I push the start button, nothing else happens.
There are no moving parts in your fuse box. The clicking sound is the contact bar closing in your starter solenoid.Follow your positive battery cable to your starter solenoid. If your push your starter button and you hear a click in the starter solenoid , then your starter button is good. If you take a piece of wire, a screw driver, or simply touch the the two power cables on the the starter solenoid together you will be putting power directly to your starter. If you jump the solenoid and the starter works you need to replace the starter solenoid. If with direct power to the starter, you tap the starter with a plastic hammer and the starter works, you need new starter brushes. Anything else wrong with the starter and you will need to replace the starter assembly the manufacturers do not sell replacement parts for there starters (only the brushes).
Aug 01, 2011 | Honda CB 750 Nighthawk Motorcycles
Solenoid clunks bike does not start
Make a connection between the positive battery cable and the starter cable located on the solenoid. This will put power directly to the starter. If the starter turns the motor over then the contacts inside the solenoid are burnt, replace the solenoid. If when jumping the solenoid the starter does not turn over , remove the starter and check to see if the brushes are worn out. If the brushes are worn replace them. If the starter is worn out replace it no other parts are available to fix it.
Feb 04, 2011 | 1982 Honda GL 1100 Gold Wing
How do I test the starter solenoid?
Test the starter solenoid by connecting a jumper cable to the battery side of the solenoid. The solenoid has two large posts and two small posts. A single large post is located on either side of the solenoid. Attach the alligator clip of the jumper cable to the large post on the battery side of the solenoid. Touch the opposite end of the jumper cable to the large post on the other side of the solenoid. If the starter turns the engine normally, the problem likely lies with an ignition override switch, such as a clutch start switch or a neutral safety switch. If the starter produces a buzzing sound, the starter is likely defective. If there is no response at all, the solenoid is defective and must be replaced.
Read more: How to Test a Starter Solenoid ' eHow.com http://www.ehow.com/how_5336536_test-starter-solenoid.html#ixzz1FalJViBW if u wuld like i can make a video cuzz i own a 87 vic just email me at kodye1@live.com
Jan 07, 2011 | 1987 Ford Crown Victoria
Wont turn over. no crank, starter clicks, no dead battery. replaced the relay.
this problem is caused by burnt battery contacts inside the starter solenoid that power the starter motor, either remove the starter and rebuild the solenoid or replace it or the whole starter, the starter solenoid is mounted directly to the starter. You can easily replace the contacts, they are avail on ebay for around $10
Remember ALWAYS disconnect the battery Negative cable befor u start work
Sep 27, 2010 | 1991 Nissan Maxima
Starter solinoid replacement enstruction
SOLENOID REPLACEMENT
(see Figures 5, 6 and 7)
Prior to removing the solenoid from the starter motor unit, matchmark the solenoid-to-starter motor housing position, as shown in the accompanying illustration.
  1. Remove the starter motor from the vehicle.
  2. Detach the solenoid-to-starter motor wire from the solenoid terminal.
Do not disassemble the solenoid; if the solenoid is defective, replace the entire unit with a new one.
  1. Remove the two attaching screws, then slide the solenoid out of the starter motor housing flange.
Fig. 5: Before removing the starter motor solenoid, matchmark the solenoid-to-starter motor housing relationship
Fig. 6: Disconnect the field coil lead from the solenoid by loosening the retaining nut ...
Fig. 7: ... then remove the two attaching screws and separate the solenoid from the motor housing
To install:
  1. Inspect the solenoid plunger joint for wear or other damage. Replace it, if damage is evident.
  2. Apply Suzuki Super Grease A (99000-25010) or equivalent, to the solenoid plunger and to the tip of the lever arm (inside the starter motor-to-solenoid housing hole).
  3. Insert the solenoid into the starter motor housing, ensuring that the matchmarks made during removal are aligned.
  4. Install and tighten the two attaching screws securely.
  5. Attach the starter motor-to-solenoid wire to the solenoid terminal.
  6. While the starter motor is removed form the vehicle, perform the testing procedure to ensure that the new solenoid functions properly.
  7. Install the starter motor.
Hope this help (remember rated and comment this).
Mar 23, 2010 | 1994 Geo Tracker
Garden Logo
74 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
