Question about AdobeAir Mobile Swamp Evaporative Air Cooler Air Conditioner
A6500a serial# a03090588a
I am looking for the whole blower assembly any suggestions?
  • 400 Answers
E-bay, Grainger, or the manufacturer.
Posted on Oct 21, 2013
Looking for a serial number for a back pack echo pb-413h blower
if unlucky lost its serial number sticker from petrol spill/heat
if lucky something stamped into the alloy housing of assembly
most mower repair shops can track down sample parts without the serial number
a factory limit of hours on blowers are as little as 100 hours
unless it came with the user book from new purchase
you may never know
Jan 13, 2017 | Echo Garden
Error e04 on my pool heater
We did not get from you, other than a classification by the forum of what kind of heater you have.
An E04 is a common error on Pentair MasterTemp heaters. It is saying that the heater is not closing the air pressure sensor = normally bad fan. But...
It just means that the fan is not coming on and blowing air to trigger the Air Pressure Switch. Could be:
  • Bad fan motor
  • Maybe just a bad 5MFD motor capacitor - much cheaper.
    • See pic: Silver thing on the right side of the motor
  • Possibly rusted out squirrel cage?
  • Or even a disconnected wire/plug. Check to ensure the plug is in all the way and good connection. See Pic below: Just under the motor you can see the square white thing, that is a 2 part plug that will unplug. The left side of that is in the inside of the heater cabinet, inserted in the back metal wall, and the wires go where they go. You won't need to mess with those. When you lift off the top of the heater, the blower assembly will be visible and the plug will just need to be unplugged. From that white plug assembly, from the right side on, the whole assembly will disconnect power connectivity. Then undo the 4 screws that attach to the heater and the whole blower assembly will lift right out.
    • Burned wire or wires for fan connection
Check all of this out.
btw... the blower looks like the pic below.
Good Luck
Mar 14, 2015 | Aquatemp Products Pool & Spa
How do I replace draft inducer fan
Its Best to replace the whole assembly due to most of the hubs on the inducer blower wheel are rusted on to the shaft. the whole assembly has 3 to 5 nuts or screws that mount to the heat exchanger shroud. Pull the wire harness molex plug & pressure hose, then install new assembly.
Feb 28, 2015 | Tools & Hardware - Others
How to replace spark plug cable on Ariens 920400 snow blower
Most of these are connected to the Coil as one unit. You may have to buy the whole assembly.
Feb 22, 2015 | Garden
Sears Craftsmen Poulan leaf blower model 358.797770 How do I gain access to starter pulley assembly and spring?
Not an easy job to get to on this Weedeater made blower; have plenty of work space and a very good memory. It requires removing blower end which you will end up disassembling the whole casing.
When re-assembling don't over torque the fan mounting nut as it will cause the flywheel to bind.
Here is a link to the parts diagram at Sears Direct.
http www searspartsdirect com Craftsman Leaf blower Parts Model 358797770...
Nov 29, 2014 | Garden
Blower motor
I would start with E-bay. Failing there I would check with Grainger.
Oct 16, 2013 | AdobeAir Mobile Swamp Evaporative Air...
Need to replace primer bulb, do i replace whole part or just the rubber part
The primer bulb can be replaced without replacing the whole assembly. If you have any questions on how to do this let me know.
Aug 04, 2011 | Troy -Bilt String Trimmer/Blower...
Heater/AC blower works on high only
Blower housing resistor fried up.You will have to replace whole blower assembly.
Jan 04, 2010 | 2002 Chevrolet Impala
Echo pb413h blower removing starter pawl assembly and installing new one.
I looked on ECHO website for serial#0200-02999. the part number is 17720206210. you don't need a pneumatic tool to remove it but it is nice to have. I would not use the high setting. But you should be able to use just a socket to take the old one off and put a new one on.
Good Day.
Oct 16, 2009 | Echo Garden
Where is the blower motor resistor on 1999 ford expedition
Look for the plug ends on the new part. The old part is usually recessed in to the housing by the blower and retained by a couple of screws. Find the terminals that match the new part on the blower housing. Remove the recessed part from the blower housing and install the new part and your problem will be resolved.
Mar 16, 2009 | 1999 Ford Expedition
AdobeAir Mobile Swamp Evaporative Air Cooler Air Conditioner Logo
20 people viewed this question
Top AdobeAir Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you an AdobeAir Heating and Cooling Expert? Answer questions, earn points and help others
