Question about Weedeater Excalibur Gas Hedge 22" Trimmer Blade
Oil ratio mix - Weedeater Excalibur Gas Hedge 22" Trimmer Blade
    Master:
  • Weedeater Master
  • 645 Answers
This unit is designed for 40:1 however with the new better oils it can run 50:1 make sure the oil you mix is "FD" rated.
Better is to use the pre-packaged fuels they have the "FD" oils and 93 - 95 octane non-ethanol fuels.
Posted on Dec 13, 2017
What's the gas to be oil mixed at for McCullough blower B256
When using McCulloch two stroke oils, the gasoline to oil mix ratio is 40:1 (1-gallon of gasoline to 3.2oz. of McCulloch oil). Oil is offered in pre measured 3.2oz containers to mix with 1 gallon of fuel. Oil is offered in pre measured 6.4oz containers to mix with 2 gallons of fuel. Other pre measured and bulk oil ...
http://husqvarna.custhelp.com/app/answers/detail/a_id/844/~/product-support---what-is-the-correct-fuel-%2F-oil-mix-ratio-for-mcculloch
User manuals
Mar 28, 2018 | Garden
What is the fuel/oil mix ratio for a GMC PHT22 Hedgetrimmer?
Fuel/oil ratio is a function of the quality of the oil. Pick a good oil and mix it by the oil recommendation.
I use Opti2 oil in all my 2cycle mix and it's 100:1. No problems over years of use.
Opti 2 2 Cycle Engine Lubricant Mixing Oil 34 fl oz EZ Measure Bottle...
Mar 14, 2018 | Garden
Petrol & Oil mix - one third of oil to 1 gallon = what in litres
You need to go by the oil to gas ratio. 1/3rd what?
Google 50:1 (or whatever) mix in litres
and you will find this
Google 50 1 mix in litres Google Search
Mixing ratios. For a mixing ratio of 1 : 50 you need 5 litres of high-octane gas and 0.10 litres (100 ml) of STIHL two-stroke oil.
Dec 03, 2017 | Garden
Gas to oil mixture
Gas to oil ratio is a function of the oil you are using. Mix according to what the oil says not what the manufacturer of the engine says. Those ratios could/may be the same. IF you mix 16:1 oil (do they even sell that anymore ?) at a 50:1 ratio it will destroy the engine. There will be no problems at 16:1 as the oil recommends.
I have used 100:1 Optimoil (?) when I can find it instead of the recommended 48:1 of my 2cycle. No problems.
Mix the oil in ratio the oil manufacturer says to mix.
Sep 07, 2017 | Garden
What is mixing ratio for weedater
The ratio is generally 40 to 1. That is all I have ever used. It depends also though on the quality of the oil you use. Synthetics can use a different ratio than mineral oils.
Sep 19, 2014 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Required fuel oil mix
Two-stroke oil with a 50:1 (Gas:Oil) mix ratio is required for the Husqvarna 125B leaf blower. Using the wrong oil or improper mixture ratio can drastically affect the performance of the leaf blower.
Nov 02, 2012 | Husqvarna Hand Held Blower 125 B Grass...
Need gas misture ratio for trimmer SRM2501
pauly46 here
the ratio you should use is 50:1
that is 20 mils of 2 stroke oil for every 1.0 litre of petrol that you mix
so if you want to make 2 litre mix use 40 mils of 2 stroke oil , then add 2 litres of petrol only and give good shake
note use good quality 2 stroke oil , such as sthil or husqvarna oil from your outdoor power shop
but if using general 2 stroke oil from a garage use 40 mils of oil for every 1 litre that you mix
this ratio is 25:1 this mix is on the richer side
cheers hope this helps
May 01, 2011 | Echo Garden
Need to know oil to gas mix ratio for Craftsman 32cc, 360 cfm, 170 mph blower vac? Can someone provide ratio?
40:1 is the standard mix. Go buy one of the little containers ( 3.2 ounces) of 2-cycle oil and mix it with a gallon of gas in an approved container (like a gas can). How you mix it is, pour some gas in the container...about 1/4 of the gallon, then pour in the oil, mix well, by shaking the can then add the remaining gasoline and PRESTO, you have a 40:1 mix!
Nov 08, 2009 | Garden
Weed eater TE475 - fuel ratio
FUELING ENGINE
WARNING:
Remove fuel cap slowly
when refueling.
HELPFUL TIP
To obtain the correct oilmix
ratio, pour 3.2 ounces of
2--cycle synthetic oil into
one gallon of fresh gas.
This engine is certified to operate on unleaded
gasoline. Before operation, gasoline must be
mixed with a good quality synthetic 2-cycle
air-cooled engine oil designed to be mixed at a
ratio of 40:1. Poulan/Weed Eater brand
synthetic oil is recommended.Mix gasoline and
oil at a ratio of 40:1. A 40:1 ratio is obtained by
mixing 3.2 ounces (95ml) of oil with 1 gallon (4
liters) of unleaded gasoline. DO NOT USE
automotive oil or marine oil.
Jul 05, 2009 | Yard Machines Garden
Weedeater Excalibur Gas Hedge 22" Trimmer Blade Logo
69 people viewed this question
Top Weedeater Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
Darrell
Are you a Weedeater Garden Expert? Answer questions, earn points and help others
