Question about GE Dryers
GE Profile DPSR610EGOWT Electric Dryer I replaced the front Drum Support Bearing and the bearing slides. When turned on, there is smoke and a burning smell coming from the bearing slides. What can be done to stop the burning?
  • 64 Answers
Its probably 'fluff from the clothes' which has built up around the 'heat element'. Have a look & remove the fluff. Keith
Posted on Oct 16, 2013
  • 126 Answers
SOURCE: dryer drum causing squeak
Most likely the front support bearing. If this is the problem you will likely have to replace the slides too. The wizards have a ten year warranty. The bearing is part number WE3M26 and the slides probably need 3 or 4 of them are we1m333. Hope this helps.
Posted on Jan 11, 2009
SOURCE: dryer makes noise as drum rotates on ge profile gas dryer
Solution: the drum slides were worn out and needed replacement.
Posted on Jan 14, 2009
MNTECH
  • 1543 Answers
SOURCE: replace bearing and bushing g.e. profile dryer
Yes, but you will have to swing the top open, remove the dryer front, and pull the drum forward about 4 inches (leaving belt on drum) to gain access to the bushing. Normally that is all you have to replace, but also check for wear on the front drum slides at the same time.
Posted on Jan 21, 2009
SOURCE: When turning the knob to start dryer, buzzing sounds but drum doesn't start to turn unless you gently push atart the inside drum
The problem is either a faulty start winding in the motor, or the circuit which energizes the start winding is failing.
A dryer motor has two windings: start & run. The start winding gets it going and a centrifugal switch disconnects the start winding when the motor gets up to speed.
Check the dryer start switch -- then the motor connections and the centrifugal switch inside the motor.
Posted on May 05, 2009
SOURCE: GE GAS DRYER DNSR473GWOWW...LOUD SCREECHING NOISE.
Turn off power by unplugging the dryer. Top of the dryer is held in place by locking pins. With a flat blade screw driver, pry up the corner between the frame and the top. The top will snap up. Then do the other side. Once both sides snap up the top of the dryer will fold up as it is hinged to the dryer housing. If this dryer has a dryer filter cover on top of the dryer, you may find two screws that are attached to the top. If so, remove these two screws before attempting to detach the top and lift it back. Once that is done, detach the cannon plug going from the unit to the door interlock. Two screws on the inside of the cabinet hold the top and two more hold the cabinet on the outside base. Removing these will allow the front to be removed and in doing so the drum will drop as the front of the drum is supported by the front panel. Now, that you here, this better not be your first dryer repair as the drum belt my come detached as may the door springs and the tension spring for the belt, etc. But, if you are really handy, go to it. Not all that difficult.
Posted on Jan 16, 2010
GE Dryer DBVH512EF0WW vibrates/shudders excessively. Particularly with the top on. I've replaced the front top bearing, drum slides and felt seal. What is my problem?
The only thing I can think of is if you have plastic inserts built into the drum then maybe you installed the wrong kit in the dryer.
Their are basically 2 styles of GE dryers. Those that have a steel drum and a bearing with glides on the front panel and those that have felt on the front panel and the plastic glides mounted in the drum itself.
Oct 12, 2012 | GE DCVH515EFWW Electric Dryer
Dryer suddenly began making a noise. After doing an internet search, many sources said to replace the felt and slides. Which I did and some of the slides were in fact bad. However, after replacing them and...
It could be the rear bearing ( easy to replace). I would check the idler pulley and blower wheel assembly also. Here is a link that should help http://appliancehelponline.com/dryernoisyge.html
There are also several other videos that cover the idler pulley and front bearing assembly.
Jan 29, 2011 | GE Profile Wizard DPSE592EAWW Electric...
We have a GE Prodigy clothes dryer that makes a very loud sqeacking noise when it runs
sounds like a rear drum bearing thats gone bad very common with these units, the front bearing and slides should also be checked for wear at the same time,to replace bearing in back drum has to be removed completely. if your handy with tool and have and afternoon to kill its not that bad ,just rember to UNPLUG UNIT BEFORE ANY WORK
Aug 06, 2010 | GE Profile Prodigy DPSR513GA Dryer
I have a GE profile Dryer DPSE810GOT and the dryer sounds like its running on metal to metal is the felt around the drum one piece or two and counld that cause it
The felt is two pieces. And, no, the problem is the drum support glides have worn through, allowing the drum to continue to wear into the front drum bearing. Replace the front drum bearing (WE3M26) and the drum slides (WE1M481) located at the top front of the drum.
Feb 28, 2010 | GE DPSE810EGWT Electric Dryer
How do i oil the belts? The dryer squeaks every time its turned on?
You don't oil the belts on a dryer. This will cause the belt to slip on the motor shaft and/or drum. Oil permiated into the metal of the dryer drum can ruin it causing any replacement belt to slip as well.
If the dryer is squealing, you probably need to lubricate the idler pulley wheel at the axle point (also known as a tension pulley). If this is a GE model they usually have drum slides and a drum bearing that support the front of the dryer drum as well. When they wear down, they begin to make noise. The drum slides are made of teflon and not only help support the drum, but ensures it turns smoothy. You may need to replace both the drum slides and the drum bearing.
If the model number is correct, the part numbers are as follows:
Drum Bearing - WE3M26
Drum Slide - WE1M481 (Blue), WE1M333 (White)
Replacement parts (if required) can be found at the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The average cost of these components varies, so shop and compare. The first three websites I listed have helpful exploded view parts diagrams that can help you locate and properly identify the parts you need.
If you have any questions, or if your model number is different from the one you listed this question under, please post back and let me know. I hope this helps you.
Feb 24, 2010 | GE Profile Wizard DPSE592EAWW Electric...
Drum turns but makes a banging and metal grinding sound
The felt bearing on the front of the drum is worn out. Immediately stop running the dryer, and replace the plastic drum inserts and put in a new felt bearing before machine damage happens (if it hasn't already). While there, grease the rear bearing and the idler pulley bearing. Check the belt too. Good luck.
Nov 28, 2009 | GE Profile Harmony DPGT750EC Electric...
Iam hearing scraping sounds from my dryer.
Hello Friend, Your solution is simple. You need to replace the front drum bearing and glider pads. It's actually pretty simple to do. Just remove front of dryer cabinet. After removal just look at backside of dryer front around the inner door. You will see where the dryer drum has turned and wore a hole in the plastic piece above the dryer door. This piece is called the front drum bearing. Just unsnap this piece and snap in a new one. Be sure to replace the little plastic glide pads onto the top of the drum bearing before re-installing the dryer cabinet front. The front drum bearing and glider pads are sold seperately so make sure you have everything you need before you begin. This should solve your problem. Happy to help, Tim.
Jun 25, 2009 | GE DBSR453EBWW Electric Dryer
NVLR333ETOWB HOTPOINT DRYER EATING CLOTHES
Very likely the front support bearing is worn through and cracked there are also three drum slides that are positioned on the bearing which very likely worn to nothing and will need to be replaced as well. For model # NVLR333ET0WB replacement part numbers are:
FRONT BEARING: WE3X77
BEARING SLIDES: WE3X87
Good Luck to you.
Jan 07, 2009 | GE DBSR453EBWW Electric Dryer
Dryer drum causing squeak
Dec 11, 2008 | GE Profile Wizard DPSE592EAWW Electric...
GE Profile Dryer Model # DPSR473EWOWW SQUEAKING
If the squeaking has been going on for only a short time, you may be able to get by with only replacing the rear drum bearing, but if it has been going on for some time you should replace the drum bearing kit part # WE25M40. Also be sure to check that the front drum slides are ok, especially the one on the left side of the front drum support, as this one wears out faster. Drum slides #
WE1M481 and
WE1M333 and if front support frame is worn so that there is nothing left to hook the slides into you would need a
WE3M26.
Sep 17, 2008 | GE Profile DPSR473EW Dryer
Dryers Logo
227 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
