Question about Microwave Ovens
Microwave turntable not turning everything else works fine
  • Microwave Ovens Master
  • 9,085 Answers
Unless the manual discusses a feature to turn it off and on, then it may be a failed turntable motor or coupler, etc.
With the full model number, chances are we could have helped you more.You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
Posted on Oct 17, 2013
MicrowaveSvc
  • 9085 Answers
SOURCE: everything works except the cooking part/no heating/turntable not turning, help!
PRELIMINARY REPLY
This is just a preliminary reply. We will need more information to help you.
So you're saying you can set the cooking time but when you press Start it won't start?
If this is the case, you probably have a bad door swithc or door switch mount.
Please reply back with more detail so we can help you.
Posted on Dec 07, 2007
  • 17 Answers
SOURCE: Microwave turns on, but no heat or turntable movement
The problem is that the magnatron is not getting power. Chance is that if could be a bolwn fuse inside the unit. If the fuse don't fix it then that leaves the charging diode, capacitor or the magnatron, or high voltage xformer of which without technical epertize I would not recomend attempting to replace. good luck
Posted on May 14, 2008
MicrowaveSvc
  • 9085 Answers
SOURCE: Kenmore Microwave Model 721.67601790 lights don't work!
This seems to be happening to this model a lot!
We see (and repair) this a lot. The problem is on the control panel, whichwe regularly repair nationwide by mail for $39.95 postpaid in about a week.
Atour site, we have a video available showing how to remove a typicalover the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filamentshorts, or when the bulbs are removed or installed without firstunplugging the oven from the power line. Either can cause such afailure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa.
Feel free to contact me directly (and please remind me of your model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Nov 21, 2008
biigg53566
  • 81 Answers
you may have gotten a power surge and that can cause some funny things to happen, 1st is there power to the oven, 2nd if so there may be an internal fuse protector built in to the oven, check with the manual for anything of that sort listed. if not you may have to take it in and have it repaired by a pro. there is a lot of voltage in these ovens and unless you know what you are doing a person could get hurt
Posted on Jan 03, 2009
  • 36 Answers
SOURCE: Sharp 1870 just quit cooking and no turntable
The fact that the microwave and convection both do not heat indicated that the oven is in demo mode, check the user manual, otherwise it will possibly be a relay not triggering, may need a pcb replacement, check Demo mode 1st....Phil
Posted on Jan 08, 2009
Turntable does not turn
Possible that the belt has failed, or the motor is not working or that there is no power from the control panel to the motor.
You need to remove the bottom panel to observe this and confirm.
Feb 11, 2013 | Microwave Ovens
Panasonic nn ct766 turntable locked
If everything cooks as normal but the turntable does not turn then I would say that either the turntable motor has failed or the supply for the motor, either way this is not a problem you could fix yourself & so I would recommend taking to a microwave repair centre or service engineer.
Dec 26, 2012 | Microwave Ovens
My spacemaker 2.0 pvm2070dmww microwave is not heating and the turntable is not turning everything else is working fine.
The problem is more than likely a bad door switch, a digital meter is the best option for testing to find the defective one. If you have one post back for instructions or have serviceman repair it.
Jul 04, 2012 | GE Profile Spacemaker Over-the-Range...
Turntable won't turn in the microwave
look for supply to turntable motor if supply is coming on motor and it is not moving it means motor is faulty
Jun 23, 2010 | Danby DMW1146SS Microwave Oven
Microwave turntable doesn't turn. Everything else
The turntable system typically consists of the motor, the coupler, the turntable support with rollers, and the tray.
Here is a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
But if you've recently had trouble with the cooktop lights, then the control board may be damaged.
We regularly repair these control units for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee.
Nov 28, 2009 | Frigidaire Microwave Ovens
My turntable stopped rotating on my GEJVM1490 for no reason. everything else works fine, any suggestions?
There is a small motor underneath the microwave which turns the plate or turntable around.
If this is faulty then you will need a service agent to repair it.
Jun 17, 2009 | GE JVM1440 Microwave Oven
Em-s3577s uk 2 wont turn
Remove the turntable plate and check the motor coupling gears underneath, if motor coupling is fine, then replace the turntable motor.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
May 19, 2009 | Sanyo Microwave Ovens
Maytag Microwave 1150 Help
Check first the motor coupling under the turntable, if that is not the problem , then test and eventually replace the turntable motor.
Click here and select model to get parts and diagrams.
Apr 05, 2009 | Maytag MMV4205 Microwave Oven
Turntable not turning
check control circuit, and related spares.
Oct 29, 2007 | Magic Chef MCD1311ST Microwave Oven
Microwave Ovens Logo
35 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
