Fellowes SB-87Cs shredder: The metallic sticker,
Fellowes SB-87Cs shredder: The metallic sticker, which runs the width of the main paper feed, is coming unglued. When I insert paper, the paper gets stuck between the sticker and the machine. What is the purpose of this sticker and can I remove it? (I've uploaded a photo where you can see it. I took the photo with the cd/credit card feed door popped open.) Thanks!
Why does my shredder get really hot and start smoking?
These shredders are not made to run for continuous or long periods straight. Check your manual and it should tell you the maximum continuous run time. And most importantly are you oiling the shredder? Without oil you are going to burn it out and cause all sorts of problems.
Mar 03, 2015 | Fellowes Manufacturing Powershred SB-87Cs...
How do I stop shredder from spitting documents in and out?
Try cleaning the cutters well. This will require you UNPLUGGING the shredder. Turning it (the top feeding-cutting) part upside down and removing ALL paper and if you see paper clips or staples-REMOVE THEM! You will need to start the motor several times to move the cutting blades around for a complete cycle to make sure you have removed all debris from the cutting blades.
If this does not work you may have an electrical problem you will not be able to solve. Look for your shredder number in the link provided below and download.
Fellowes Shredder Manuals
Sep 12, 2014 | Fellowes Powershred SB-87Cs Shredder
A 'band' has come unstuck at the entrance of my Fellowes paper shredder.
I have the exact same problem!! I'm wondering if you ever found a solution.
Dec 01, 2012 | Fellowes Powershred SB-87Cs Shredder
Open door indicator light is on even when the door is tightly closed. Shredder won't fuction because of this.
Small plastic wafer mounted inside door has been
broken or bent out of position. At you own risk, you
can wedge something into the slot to jam switch in
operating position permanently.
Apr 17, 2010 | Fellowes Manufacturing Powershred SB-87Cs...
Fellowes PS 70 paper sensor replacement?
yes. look closely in the throat of shredder. right in the middle on front side and rear side of throat. clean with q-tip and alcohol.
hth,
razors
Jan 18, 2010 | Fellowes Powershred SB-87Cs Shredder
Does not shred red light on
Try soaking the cutter blades with hot soapy water overnight thru the feed slot
Nov 04, 2009 | Fellowes Powershred SB-87Cs Shredder
The Auto-On switch does not work. I have to manually turn the shredder on and then feed paper into the slot. It feeds and shreds the paper just fine, but I have to manually turn it off to stop it. All of...
There must be an auto-on/off sensor in the middle of the paper entrance slot - either mechanical or optical.It needs to be cleaned from any obstructions like paper chads or paper dust.It this doesn't help,the sensor maybe defective and it needs to be replaced.
Oct 02, 2009 | Fellowes Powershred SB-87Cs Shredder
Schreder will not shut off automaticly.
Try blowing some canned air down into the feed slot. No spare parts are available.
Sep 24, 2009 | Fellowes Powershred SB-87Cs Shredder
Shredder will not atomaticly turn on when paper is put in.
The micro switch is stuck or bad. It is located in center of the cutters. Unplug and check for scraps of paper jamed around the switch.
53 people viewed this question
jasbo
jasbo
