Question about Sony KP-57HW40 57" Rear Projection Television
Prone tube - Sony KP-57HW40 57" Rear Projection Television
Pic dark and lil red but all tubes are on i have it took a part
either a convergence problem or maybe a Glycol problem both of which this model is prone to.
Nov 29, 2012 | Philips 60PP9363 60" Rear Projection...
My rca hdtv does not have picture only voice
Some possible causes:
No filament voltage to the three tubes.
No high voltage to the tubes.
The set is also prone to bad connections at and around the high voltage transformer.
6_12_2012_3_39_43_pm.jpgit is also called a FLYBACK.
Jun 11, 2012 | RCA HD52W56 52" Rear Projection HDTV
My rca hdtv does have voice perfectly fine but no picture at all.
How do i find out if sony kp/57ws510 picture tube is bad
While the set is prone to bad tubes a double or 3d like image is convergence--this model uses two of the STK-392-560 CHIPS for this.
Go into customer menu and call up convergence--if off and will not adjust in any area of the screen the chips are bad.
May 02, 2012 | Sony KP-57WS510 57" Rear Projection HDTV
Sound, but no picture
If before it was going rather bright red or a version of that--it is related to the circuit for the red picture tube this set uses---the tube itself or the circuit board that plugs onto the end of that tube.
If bright red, green or blue screen set will detect too much current being drawn and blank or turn tubes off; not likely a do it yourself repair and this set is prone to this and many other problems---Just Google the model number with "problems" and see what I mean.
Apr 19, 2012 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a husqvarna chainsaw 41(1994-05) is what the model number is showing the carb has been rebiult new gasgets it has fire but will not run can u help
The 41 was quite prone to blowing the crank seal on the flywheel side, remove the flywheel and check, at the same time check the flywheel key has not sheared, behind the carb fixing plate is a rubber induction tube, make sure this has not split, als check the impulse seal underneath the induction tube.
May 19, 2011 | Husqvarna Garden
My picture is blurry and discolored.
THAT KIND OF TECHNOLOGY IS PRONE TO WHAT ARE CALLED CONVERGENCE FAILURES. PROBABLY THE MOST COMMON FAILURE HAS TO DO WITH THE CIRCUIT THAT KEEPS THE 3 PICTURES FROM EACH OF THE PICTURE TUBES ALIGNED TOGETHER.
Dec 17, 2010 | Sony KP-57WS510 57" Rear Projection HDTV
TO IDENTIFY PART ON '93 FORD 302 EFI V-8 USING EXPLODED VIEW DIAG
Sounds like it is the tube to part of your emissions equipment. It usually goes to another hose that goes to a one way valve from the air pump for the air injection for your exhaust gas recirculation system. These are prone rust and can be purchased from Ford for replacement.
Mar 11, 2009 | 1993 Ford Bronco
Sony KP-57HW40 57" Rear Projection Television Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
