Question about Konica Minolta bizhub Office Equipment & Supplies
I am geeting error code c6101 how to handle this
2 Suggested Answers
  • 884 Answers
SOURCE: How can i fix error C6101 of my BH-195?
Hi
The problem appears to be with the scanner unit
Scanner home detection failure
- When the power switch is turned ON or a scan operation is completed, detecting the home position fails. 1 Turn OFF and ON the power switch.
2 Check the connector between M3-MFPB P101 for proper connection and correct as necessary.
3 Check M3 for correct drive coupling and correct as necessary.
4 Check the connector between CIS-MFPB P102 for proper connection and correct as necessary. 5 M3 operation check. 6 Change M3. 7 Change CIS. 8 Change MFPB. You can find the page here, and it gives other error codes and their solutions as well.
Error Codes Konica Minolta bizhub 195 page 2
Hope this is helpful, if so would you please register that with Fixya
Cheers
Posted on Nov 25, 2014
Conika minolta bizhub 215 error code c6101
The scanner is not going back to home position, have a tech come out to check this. The scanner is what moves when scanning a document on the big glass or if using a document feeder
Apr 08, 2017 | Minolta Office Equipment & Supplies
What is konica 215 Error C6101 Repair codes?
The scanner can not not detect home position, the scanner is what moves under the big glass, is it locked??? screw installed left side of machine or some one messing with it? have tech check it out
Apr 12, 2016 | Konica Minolta Office Equipment & Supplies
We have Konica Minolta bizhub 164 copier machine its showing c6101 error code how to resolve that error plz tel me
1 Turn OFF and ON the power switch. 2 Check the connector between M3-MFPB P101 for proper connection and correct as necessary. 3 Check M3 for correct drive coupling and correct as necessary. 4 Check the connector between CIS-MFPB P102 for proper connection and correct as necessary. 5 M3 operation check. 6 Change M3. 7 Change CIS. 8 Change MFPB.
Sep 15, 2015 | Konica Minolta Office Equipment & Supplies
Hi
Cheers
Nov 25, 2014 | Konica Minolta Office Equipment & Supplies
C6101 error code in konica minolta 164
scanner home position. The scanner located under the big glass to the left is not finding home check that it is not located or jammed.
Jan 30, 2014 | Konica Minolta bizhub C250 All-In-One...
Bizhub 164 machine trouble c6101
hello sir i rajiv paramount inc in jalandhar pls send error c6101 codew
Apr 27, 2012 | Office Equipment & Supplies
Sir am geeting problem in hp all in one
Hi
Please refer the weblink provided below for the error code and work carefully with the printer to get the issue resolved.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01815748&cc=us&lc=en&dlc=en&product=1153494
This should fix the issue.
Jan 23, 2010 | HP Photosmart C6180 All-In-One InkJet...
Maytag electric stove w/ovenMODEL #-MER5750BAW I'm geetting an F1 error code after the oven heats up. Can I find out what this coad means?
F1 code is a defective electronic control(clock). There is no reset or quick fix. The EOC must be replaced.
Dec 25, 2009 | Maytag Ovens
Error code E000732-0001
This error indicates that it cant detect the scanner unit of IRC3220
Check the cable that connect the machine and scanner unit .switch off the machine disconnect the cable and reconnect it and switch on the machine again hope this will help
Jul 01, 2009 | Canon imageRUNNER C3220 Color Copier
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
