Question about Vacuums
How do I repair the cord winder? - Vacuums
    Habit-Forming:
  • 193 Answers
It's best not to mess with it just replace it
Posted on Oct 16, 2013
How do I replace the power cord on an Oreck DTX 1400?
ck your local listings for an appliance repair shop that takes vac's not all do but some do . they can fix your cord 4 you
Feb 09, 2016 | Oreck Vacuums
How to fix retractable power cord
this can be tricky and dangerous if you are not familiar.The cord winder had a metal coil system that spins very fast.Sometime people pull the cord too far out causing the coil to seize.To get to the winder slide off the "Electrolux" slide off[located on the sides of the vacuum] Your best bet is to take it to a vacuum repair shop.Before trying anything take a flat screw driver and puch it in the hole where the cord comes out and push it in,sometimes this fixes the problem sorry I cant tell you more as it is hard to explain the procedure....Please be careful.
Feb 08, 2015 | Electrolux Epic 6500 Vacuum
The cord will not rewind
These get stuck all the time...I own 2 of these , and I have done this many times...Get a can of WD40 or some type of spray lubricant with the little straw in the nozzle. Try pulling and pushing the cord back inside(don't pull it too hard) while you are spraying the lubricant directly inside where the cord comes out. push the cord back in as if you were going to force all of it back inside the cord winder. You may even have to bump the back of the machine where the cord winder is located. But it will wind back up.If you are worried about getting the lubricant on something that it doesn't need to be on , then take the Vac apart and spray it directly on the the coils of the cord winder..A lot of times, that's all they do in the repair shop when they tell you they replaced the cord winder....
Jun 15, 2011 | Electrolux Epic 6500 Vacuum
CORD SPOOL WILL NOT PULL BACK
Try tilting the vacuum to about a 45 degree angle. Gently tug and release the cord a few times. This usually will release the cord. If not, the cord winder may have broken, or the spring came loose, and it needs replaced/repaired. Take it to the nearest Aerus Electrolux store for help/repair.
http://www.aerushome.com/storelocator/
Jan 19, 2011 | Electrolux UltraLux 2000 Bagged Canister...
My Miele Carina Vacuum stopped working. Does it have a fuse that can be replaced that could be at fault here?
although it might have an internal fuse on this model, I dont think that will be the problem.
The miele cord rewinder has been known to have a small fault in it where the cord winder that actually retracts the cord onto will come apart from the electrical connection in the cord winder itself.
As most of these units have a 5 year warranty anyway, I suggest that you take it to your nearest miele dealer for a repair/replacement on the cord rewinder.
Good luck.
Nov 06, 2010 | Miele Carina Vacuum Vacuum
Have a miele S546 vac. and it won't turn on. Is there a fuse? Can the on/off switch burn out? Thanks.
If you vacuum wont turn on it is most likely the cord winder. This is a pretty big repair, you wouldn't want to attempt it yourself. Most shops should be able to repair the cord winder for about $50-75. If you need a new cord winder expect to pay about $150.
Oct 13, 2009 | Miele S548 Bagged Canister Vacuum
Miele s314 red star-motor stopped working-on/off switch broken?
Most likely the problem is with the cord winder. This is the most common problem with Mieles. It is actually the most common problem with any vacuum with a cord winder. A Miele repair center should not change you to look at the vacuum and tell you what is wrong with it. The Red Star was a great model and if the powerhead is still in goood condition I would get the vacuum repaired. If it is the cordwinder they can usually be repaired and it should cost about $75.00. If you need a new cord winder this will cost about $150.00. The top piece can be pryed off, however if it feels like it is switching than it is not jammed.
Oct 08, 2009 | Miele Vacuums
Vacuum not running; do I have to replace the cord winder or just cord?
Typically, the cord and winder are supplied as a unit.  It is possible to fit new cord to an existing winder, but the amount of labour involved will make the job more expensive than simply exchanging the complete unit.  Even if you're going to do the job yourself, it's simply not worth planning to just fit new cable (unless you are a masochist with unlimited time and patience).  Pay that bit extra for a complete unit - you'll be glad you did (or you'll be sorry if you don't!).
May 27, 2009 | Miele S514 Solaris Bagged Canister Vacuum
Won't start
It is most likely your cord winder. They are a little tricky to fix yourself. A repair shop will probably charge about $50. To fix it. The contacts where the cord winder plugs into the motor need to be cleaned and adjusted. Just don't let your repairman tell you that you need a new cord winder.
Jan 22, 2009 | Vacuums
How do you access and then repair the cord winder on an electrolux canister vacuum cleaner?
Is it the long type, 2 wheels on the back, one swivel wheel on front?
Aug 02, 2008 | Electrolux Vacuums
Vacuums Logo
16 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
