Error c6101 for bizhub 215 - Computers & Internet
  • 884 Answers
SOURCE: How can i fix error C6101 of my BH-195?
Hi
The problem appears to be with the scanner unit
Scanner home detection failure
- When the power switch is turned ON or a scan operation is completed, detecting the home position fails. 1 Turn OFF and ON the power switch.
2 Check the connector between M3-MFPB P101 for proper connection and correct as necessary.
3 Check M3 for correct drive coupling and correct as necessary.
4 Check the connector between CIS-MFPB P102 for proper connection and correct as necessary. 5 M3 operation check. 6 Change M3. 7 Change CIS. 8 Change MFPB. You can find the page here, and it gives other error codes and their solutions as well.
Error Codes Konica Minolta bizhub 195 page 2
Hope this is helpful, if so would you please register that with Fixya
Cheers
Posted on Nov 25, 2014
  • 165 Answers
SOURCE: We have Konica Minolta bizhub 164 copier machine its showing c6101 error code how to resolve that error plz tel me
1 Turn OFF and ON the power switch. 2 Check the connector between M3-MFPB P101 for proper connection and correct as necessary. 3 Check M3 for correct drive coupling and correct as necessary. 4 Check the connector between CIS-MFPB P102 for proper connection and correct as necessary. 5 M3 operation check. 6 Change M3. 7 Change CIS. 8 Change MFPB.
Posted on Sep 15, 2015
firecontrol7
  • 6161 Answers
SOURCE: How to service konica minolta bizhub 215 error C03FF
Sir/ Mam,
Some one messed with your marketing area for the machine for example the machine thinks it a 19 paper per minute machine when it is really a 22 page per minute machine, need a tech to come out reset the proper setting or the the copier. Or the machines operating system firmware thinks it is one when it is the other, which requires the tech to download from a secure Konica Minolta Web site for dealerships and KMBS They like to protect there company's firmware. Sorry
Posted on Jan 15, 2016
rajibdip6
  • 19 Answers
SOURCE: Konica minolta bizhub 215 giving error c2558
CHANGE YOUR DRUM UNIT OR DEVELOPER
Posted on Dec 15, 2016
  • 8 Answers
SOURCE: how to reset bizhub 215 error code 3452
• The Fusing Roller Sub Thermistor does not
detect the required temperature within 30 sec.
after a warm-up cycle has begun; therefore, the
copier does not complete the warm-up cycle.
• The temperature of the Fusing Rollers does
not
reach the required level even after the set
period
of time has elapsed during a warm-up cycle.
Check that the H1[ fuser lamp] comes on when
the Main Power
Switch is set to ON, and correct or replace as
necessary.
Check that the H2 comes on when the Main
Power
necessary.
Check the installation of the TH1 and the TH2,
and
correct or clean as necessary.
Check the operation of the TH1.
Remove CN80 (4P), and then check that the
resistance
across CN80-2 and -3 on the Thermistor is
infinity.
5
Check the operation of the TH2.
Remove CN81 (4P), and then check that the
resistance
across CN81-2 and -3 on the Thermistor is
infinity.
6
Check the continuity of the H1.
Correct or replace as necessary.
7
Check the continuity of the H2.
8 Change PU1 - -
9 Change PWB-A
Posted on Apr 08, 2017
Conika minolta bizhub 215 error code c6101
The scanner is not going back to home position, have a tech come out to check this. The scanner is what moves when scanning a document on the big glass or if using a document feeder
Apr 08, 2017 | Minolta Office Equipment & Supplies
What is konica 215 Error C6101 Repair codes?
The scanner can not not detect home position, the scanner is what moves under the big glass, is it locked??? screw installed left side of machine or some one messing with it? have tech check it out
Apr 12, 2016 | Konica Minolta Office Equipment & Supplies
Sep 15, 2015 | Konica Minolta Office Equipment & Supplies
C2558
Abnormally high toner density detected TCR sensor board
- The T/C ratios detected by the TCR sensor board (TCRSB) are above the threshold for the detection of abnormally high T/C ratio for three successive times.
- The connector between MFPB to TCRSB is disconnected.
Error Codes Konica Minolta bizhub 215
Mar 07, 2015 | Konica Minolta Office Equipment & Supplies
Hi
Cheers
Nov 25, 2014 | Konica Minolta Office Equipment & Supplies
C6101 error code in konica minolta 164
scanner home position. The scanner located under the big glass to the left is not finding home check that it is not located or jammed.
Jan 30, 2014 | Konica Minolta bizhub C250 All-In-One...
Error c3452
Power off the machine wait ten seconds then holding the down the clear/stop button power on the machine. should clear the code if the code comes back replace the fusing unit the hot part!
Jul 23, 2013 | Minolta bizhub 200 All-In-One Printer
Bizhub 164 machine trouble c6101
hello sir i rajiv paramount inc in jalandhar pls send error c6101 codew
Apr 27, 2012 | Office Equipment & Supplies
Computers & Internet Logo
53 people viewed this question
David Payne
David Payne
