Question about Staples OXO GOOD GRIPS Desktop Stapler
How to fix a oxo good grip stapler - Staples OXO GOOD GRIPS Desktop Stapler
Why do the numbers on the oxo digital food scale appear only in half?
Sounds as though the LCD display is faulty and only half is lighting up. I would have thought the cost of replacement is greater than the scales are worth. May be a bad connection that needs resoldering, but usually they are not serviceable.
Aug 03, 2015 | Oxo Good Grips 11-pound Digital Kitchen...
How do i set the time on my oxo digital timer
OXO doesn't provide a link to download the instruction booklet for this model, but I own it too, and this is what I've learned:
To set clock:
  1. Press and hold clock/timer button for 3 seconds (clock icon will appear on left side of screen).
  2. Input time using keypad then quickly press clock/timer button to save.
To set timer:
  1. Press and release clock/timer button.
  2. If necessary, press clear/memory so timer reads all zeroes.
  3. Enter desired time using keypad (to a maximum of 99hrs:99mins:99secs).
  4. Press stop/start to begin countdown.
  5. Pause countdown by pressing stop/start; resume by pressing button again.
  6. When countdown is complete, timer will beep continuously for 30 seconds and display will flash. Timer will then beep every 10 seconds for 10 minutes until the stop/start button is pressed.
  7. Press clock/timer button to return to clock function.
To time activities:
  3. Press stop/start and plus (+) sign will appear on right side of screen as timer begins counting up.
  4. Pause count-up by pressing stop/start; resume by pressing button again.
  5. When you're finished timing, press stop/start to end timing function.
  6. Press clock/timer to return to clock function.
Mar 10, 2015 | Oxo Good Grips Digital Timer
How to change the hour on the OXO triple grip timer.
The instruction booklet for OXO's Triple Timer Model ## 1071501 can be downloaded here:
http://www.oxo.com/download/556_gg_1071501_booklet.pdf
Mar 10, 2015 | Oxo Good Grips Triple Timer
Need to set clock on oxo timer
I also own this model, and the manual isn't availble on OXO's site. But this is what I've learned over the years:
To set clock:
To set timer:
To time activities:
Sep 30, 2013 | Oxo Good Grips Digital Stainless Steel...
OXO food scale shows erh code
I am having the same problem with the 5lb scale. Turned it on for the first time about 5 days ago and was ok. This morning when I went to use it it gave the ErH code. Would appreciate if any person has an answer. I am waiting for OXO to respond my e-mail.
Apr 14, 2013 | Oxo Good Grips 11-pound Digital Kitchen...
How to unjam the lid to an OXO Good Grip Pop Container
replacement parts can be found easily on amazon. here: Amazon com OXO Good Grip Pop Container parts I hope this was helpful. Cheers
Mar 20, 2013 | Oxo Good Grips POP Rectangle Storage...
Serice code 792
E721 Sorter stapler bin lift sensor E722 Sorter stapler jogger sensor E723 Sorter stapler grip sensor E792 Sorter stapler error
Mar 20, 2009 | Office Equipment & Supplies
Staples OXO GOOD GRIPS Desktop Stapler Logo
97 people viewed this question
Top Staples Office Equipment & Supplies Experts
Saleem Baig
Saleem Baig
Randy Schumann
Randy Schumann
Are you a Staples Office Equipment and Supply Expert? Answer questions, earn points and help others
