Question about Jabra GN9125 Wireless Headset
Can't do soft reset; all 3 light won't blink simultaneously
I bought sj-5501 Sharp fridge . Yesterday I have no lighting on the front panel display of the refrigerator The refrigerator works right What could be the reason ? Thanks,
You can try one of these;
1. Hold down "Energy Saving" and "Lighting" buttons simultaneously for 10 seconds (or top left & right buttons). Display panel returns immediately
2. press the Freezer and Ref buttons at the same time for 8 secs and Bam!!!! Bac 2 normal!
3. pressed the power freeze and vacation buttons for about 3 secs and it worked
4. I held the top left and top right soft touch buttons on the screen itself (which I think is the power save and the lighting buttons) and held for about 8 - 10 secs and it reset
Hope it helps. Its in the combination of two buttons pressed simultaneously. Try your luck.
May 16, 2016 | Refrigerators
Kindly assist me with tecno t380 password to unlock
A soft reset will clear pending errors and bring your mobile to its initial state by restoring factory settings. To do this, the shortcut is: *#7380# This function apparently works on almost all Nokia mobile phones. Hard Reset It may happen that despite having restored your mobile to factory settings, the error still exists. In this case, it is recommended that you opt for a hard reset. Enter the code: *#7370# and press Yes to confirm. Important: You should back up any important information before doing this. To perform a hard reset on a Nokia phone that won`t turn on, press simultaneously these 3 buttons: on/off + * + 3.
Nov 26, 2015 | Cell Phones
How to hard reset nokia 5130
You can reset it using a soft or hard reset. The following instructions provide you with information on how to reset the Nokia 5130 using both methods.
  • Soft Reset
The soft reset is often the better option if you are worried about losing data. There is a chance the soft reset will also default to the factory settings, but there is a bigger chance that it will not. With a soft reset you will enter in *#7380#. This tends to clear any pending errors and on most phones it will help your phone work properly.
  • Hard Reset
  • The code for Hard Reset is *#7370#. Enter these digits into the phone and press yes to confirm. This will start the initialization process. Make certain you have already saved all important data. You do not want to lose your contacts, memo, or other information due to a hard reset. You may have issues with a Nokia phone that is not turned on. If there are problems such as these you can try hitting three buttons simultaneously. Hit the +*+3. If you can hit these three buttons all at once you may be able to get the phone to turn on, and then you can go through the hard reset with the proper codes.
These codes work with all of the Nokia models including the 5130. You may find other options do exist such as the power button while pressing the space key and delete key, and caps/ shift button will also hard reset the phone.
It all depends on whether or not the *# keys work. Sometimes they won't work if the phone is in phone lock or key pad lock and you need to get it open first.
Oct 02, 2011 | Nokia 5130 Cellular Phone
How do i program my lexus 2001 rx300 for a gate opener
You should see three buttons on the driver sun shade. Let's name them from left to right 1,2, and 3. Start by clearing any old codes. To clear codes press buttons 1 and 3 simultaneously until the light starts blinking. Release the buttons simultaneously. Before starting to program the car remotes you must have your gate hand held remote ready with a good charged battery. Now, to program your first gate car remote let's choose button 1. Press button 1 until it start blinking (about 20 seconds). Keeping button 1 pressed, activate your hand held remote close (about an inch) from the car button 1, until the light blinks faster than before. Release both remotes simultaneously. You are done programming your car remote button 1. For two additional gates remote controls programming repeat the procedure with button 2 and then with button 3.
Nov 13, 2010 | 2001 Lexus RX 300
How to restore factory settings
You can do it two ways: SOFT RESET: To operate this function on your mobile, the shortcut is: *#7380# . this will clear pending errors. HARD RESET: Enter the code: *#7370# and press Yes to confirm initialization. To make a Hard Reset on a Nokia phone that is not willing to turn on, just press simultaneously these 3 buttons: on/off * 3.
NOTE: after performing a hard reset or soft reset, you may lose all the data on your mobile, which will be brought back to the "Factory settings" state, so better think twice before resetting your phone.
Hope your problem get solved.Great time
Oct 10, 2010 | Nokia E63 Cell Phone
CONTROL LIGHTS BLINK BUT WONT OPERATE
Anytime the lights blink simultaneously on this model, it is because of a major control fault that has occurred.
unplug the unit or shut the breaker off for 3 minutes. if the lights continue to blink after the 3 minute reset, replace the control/timer module asap.
Jun 02, 2009 | Frigidaire Dishwashers
Hp 5510 io keeps stating to check color cartridge/3 lights blinking/won t print/installed new color'' Let our Experts solve your ''hp 5510 io keeps stating to check color cartridge/3 lights blinking/won t...
hi..
try to install and reinstall the printer cartridge...and also clean the tab circuit of the cartridge and tab circuit of the printer carrier..
if the problem still exist..
rebreak the printer by full-out the power supply...to reset the settings and then turn it back...
Apr 01, 2009 | HP Officejet 5510xi Printer
Marantz SR6001 AV Surround Receiver - Blinking Standy Light
For resetting sr6001: When power lights blinking, press "clear" + "pure direct" + "7.1 ch input" simultaneously for 3 seconds.
iskender
Nov 10, 2008 | Marantz SR-7200 Receiver
Filter light won't go off
Did you press and hold the reset filter light for at least 3 seconds?
Jul 11, 2008 | Maytag MFI2568AES Stainless Steel Bottom...
Jabra GN9125 Wireless Headset Logo
23 people viewed this question
Top Jabra Radio Communications Experts
TO Lady
Greg Cann
Greg Cann
Michael Vincent Cruz
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
