Tevion tv full hd lcd
Will not turn on.changed plugs fuses,but nothing. was working fine.went to turn it on next day and nothing
    Top Expert:
  • Televison & ... Master
  • 74,136 Answers
Sounds like a power supply regulator board fault. Check its start voltage. You must have sound knowledge in electronics to repair this fault. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Posted on Oct 16, 2013
dsacco86
  • 1077 Answers
SOURCE: 42" LCD HD TV keeps blowing fuses.
A ceramic fuse stands up to heat better than a non-ceramic fuse. I'm no pro, but it sounds like your power inverter board maybe bad. There are replacements out there. Good luck
Posted on Jan 19, 2009
dsacco86
  • 1077 Answers
SOURCE: Emerson 32 inch LCD TV will not come on.
I'm sure you already checked the outlet and the surge protector bar. It's lame how the warranty only last a year on this TV.
If your lucky, it will be just the fuse that need to be replaced. It will look like a little glass tube with metal caps on the ends. Radio Shack or an Electronic supply store will have the fuse. Just show them the fuse and they should match up the type and size. It needs to be 4amps and 125volts fuse.
If this doesn't work, you'll need to replace is the power supply board. The board# is BA71F0F01042. Your power supply board should have the same number on the lower right side of this board.
The board is hard to find right now. Only three places I know of to find it.
Ebay,
Discount-Merchant.com,
and Shopjimmy.com
Sadly, nobody has them in stock.
I wish I had a extra board to sell you, because I know how to repair the power supply. I have the schematics diagrams and part# for the pieces on the board.
If you ever come across a replacement board, let me know. I would like to buy your old board. Here's my e-mail, www.dsacco86@hotmail.com
Posted on Apr 14, 2009
SOURCE: Samsung lns5296dx will not turn on center blue on but not TV
We have a 3 year old 52 inch LCD Samsung LSN5296DX/XAA and it stopped working. The blue light in the front is on but it won't turn on using the front panel ON/OFF switch or the remote.
Thanks for couple of responses on this website; I was able to fix the problem in a day and spending only $3 on parts.
- Remove the back panel cover by taking out all the screws (about 20) and 4 large screws in the middle for wall mounting.
- Remove the protective metal cover of the left side (6 small screws) and expose the main power supply board (PN: BNN-00150A).
- You can order this board for $165 from Samsung and replace the entire board and your problem will be solved (by removing about 6 small screws and disconnecting a few cables)
- Or you can look at the upper right corner of the board to see if there are bad capacitors (they are blue cylindrical ¼ inch diameter and about ½ inch tall with two wires soldered to the board. The capacitors have an X on top and if they are bad you can see the bulging top as compared to smooth surface and black resin stuff coming out). They are labeled as 10 V, 1000 uf, 105 C (M). If you cannot find the exact one, then purchase capacitors with exactly 1000 uf and higher voltage, 16V, or 25V. Make sure they say Axial (cylindrical).
- For my board, only 3 of them were bad. Order these capacitors from RadioShack (1000 uf, 35V Axial Capacitor, PN: 272-1032, about $1.60 a piece plus shipping) or go to your local electronic store. I bought several 1000 uf, 16V at about $1 a piece from “You Do it Electronics” in Needham, MA.
- Simply remove the bad capacitors using a hot soldering device with fine tip, and place the new capacitors.
- Put the board back, put the protective cover on the board, and then large plastic cover back.
I assure you, the TV will starts by just replacing $3 in bad parts and less than an hour work. If I can do it, then anyone else can do it.
Posted on Aug 18, 2009
raklein62
  • 360 Answers
SOURCE: I have a Westinghouse LCD TV model LTV 27W6 HD. TV
This resistor in conjuction with large electrolytic capacitor is responcible for the internal filtering of the high voltage side of the board. As your unit heats up( anywhere fron 5 to 30 mins) you will notice horizontal flickering and prior to that red or green or even purple pixelation. Check this 1/4 watt resistor for dark discoloration and or a bad solder joint on the solder side of the board. This resistor is directly responcible for controlling the bias current to the high voltage regulators for the 160 volts DC. At no time should you handle or troubleshoot this board with the line plug in.
Even when this board is powered down that capacitor still holds a charge for up to an hour and can knock your you know what
in your sock. If you do not feel comfortable please take the board to someone else. Hope this helps
Posted on Sep 16, 2009
  • 4 Answers
SOURCE: samsung lcd tv ltm1755b won't turn on (power light stays red)
Problem: Samsung LTM1755B with only a blinking yellow LED when you try to turn it on.
Solution: I just had one of these come in. I opened it up, and found the U501 capacitor a little suspicious looking, in that it had a deformed top. It was a 470uF 16V electrolytic 105degC 10mm x 12mm. I replaced it with a very good quality 1000uF 16V electrolytic 105degC 10mm x 16mm Nichicon UHN1C102MPD. After that repair, when I tried to turn it on, the LED was yellow for a second, then green, then I got a picture, and it appeared to work great. I then asked the owner a week later how it was working, and they said it was working just like new!
Posted on Jan 19, 2010
Tv will not turn on
sounds like you have a fried main power board in your TV... Unfortunately technician replacement of this board will cost nearly as much as replacing your tv.
May 03, 2015 | Tevion Televison & Video
TV will not turn on, 3.15amp fuse keeps blowing on power board
I have an ln40b630n1fxa and my fuses keep going out as well i took it all apart and seen nothing blown. What would be my next step
Nov 06, 2012 | Samsung LN40B630 40 in. LCD TV
42" Regza #42RV530U won't turn on. Was working
not being funny but have tried changing the fuse or the mains lead if it plugs in the t.v
Jan 24, 2011 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Tv wont turn on, changed .5 amp fuse but nothing, its a 47 inch tevion lcd tv
hello have you check the fuse inside the tv glass type it will be in the power supply
regards
shaun
Jun 14, 2010 | Televison & Video
My LG decided not to come on the day i went on holiday, i mean no power no lights nothing, come back try again, nothing so i go and buy a new 38'' LG tv, tried the old one once again, comes on fine put it...
It is not you tv its the plug on theb wall. It is probably loose, and causing the intermittent problem you are having. You may notice looseness as you plug it into the wall. Your TV is fine.
Aug 09, 2009 | LG 32LC7DC 32 in. LCD HDTV
Not Powering Up...Please Help Me!!!
This may sound silly but check your circut breaker or if you have a GFCI on your outlet because maybe you have too many things plugged into it. Plug a lamp or something into the outlet. If you are sure it is the TV check the owners manual for common troubleshooting. After that I would pursue the warranty; it should be 1 year with this model.
May 15, 2007 | Sony BRAVIA KLV-40U100M 40 in. HD-Ready...
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
Electro Med Services...
