Question about Bosch HBL8450UC Electric Single Oven
OVEN WONT HEAT CORRECT TEMP - Bosch HBL8450UC Electric Single Oven
  • 296 Answers
Should be procedures to test/adjust temp in owner's manual
Posted on Oct 16, 2013
Gs445lems wont ignite
The oven valve can be the problem if the coils in the oven valve are bad, even if only one side of the valve is bad the bake and broil will not work. If I remember correctly there should be somewhere around 50 ohms across the coils. if it is much more or much less this is probably the problem.
Mar 16, 2014 | Ovens
Temp shows 400 but oven is at 300
Is it continues to heat up then its working fine...if it continues to heat pass 400 then your have a thermostat problem and the oven is out of control. I do believe that the display is not an actual reading of the oven temperature, instead it is a reading of where the operator has set the temperature to . I have yet to see an oven with a actual reading temperature display.
Dec 01, 2013 | GE Profile JTP18 Electric Single Oven
Ge gas oven jgbp28dej3ct.. oven pre heats good to right temp but wont maintain temp during cooking.
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Jul 29, 2011 | GE 30 In Freestanding Gas Range ...
The oven wont heat up above 50
HI, this is not a serious issue here. you will need to test the resistance of the oven temp senors. it seems to be defective. also, check the wiring harness from the oven temp sensor to the control. make sure the wiring harness is in good condition. replace the oven temp sensor if found to be defective.
May 30, 2009 | Hotpoint SY36 Style Line Stainless Steel...
Flashed F5 when temp is heating up
HI, this code is signaling that your temperature sensor is malfunction. it will result in major damage to the control board and sensor wiring harness if it is not corrected soon. the will allow for high temps during the cleaning process that will ruin the ovens control circuit board.
replace the oven temp sensor soon.
May 19, 2009 | Kenmore 47834 / 47832 / 47839 Electric...
Gas oven not heating
Hi, the oven temp sensor is not registering correct temp signals. i recommend replacing the oven temp sensor asap.
Mar 24, 2009 | Frigidare FGB24S5DC Gas Single Oven
Oven wont heat up to temp set
You will need to have the thermostat looked at or replaced, it may be defective and not reading the correct temp, also try using a manual oven thermometer to check the actual temp in the oven to give you a better idea of what the actual temp is inside
Jan 20, 2009 | Maytag 30" Built-In Single Electric Wall...
Oven not heating
you could have lost one of your 120v leads to the machine. that could cause it to work only half way. go turn the breaker off and then turn it back on and see if that corrects the problem.
Dec 07, 2008 | Hotpoint SY36 Style Line Stainless Steel...
Bosch HBL8450UC Electric Single Oven Logo
70 people viewed this question
Top Bosch Ovens Experts
ashburton
reliableservice
Are you a Bosch Oven Expert? Answer questions, earn points and help others
