Question about Smartboard Smart Board 685ix, UX60 Projector Lamp - 20-01175-20 - OEM Equivalent
UX60 lamp reset - Smartboard Smart Board 685ix, UX60 Projector Lamp - 20-01175-20 - OEM Equivalent
My Smart UX60 will show the normal light blue board color for about a minute then the screen will turn a dark purple. The color remains stable in the Hdmi mode . Cable, or something else?
If you wish to get some details; visit the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
May 11, 2017 | Televison & Video
I recently installed a new bulb in a SMART UX60 projector and now everytime i turn it on it runs for a couple minutes and shuts down i gets a solid red wrench lite. What is cusing this?
it seems that the lamp is not good
the ballast is good,I think
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel, motherboard, powersupply ... with high quality and competitive price. Jerry Lampdeng Limited
Sep 12, 2016 | Smartboard Smart Board 685ix, UX60...
How do I reset my nec projector model vt700 lamp time without remote
How to Reset a NEC Projector Lamp Timer ... - RelampIt
www.relampit.com/Projector-Lamp-Timer/NEC-Projector-Lamp.php
How to Reset a NEC Projector Lamp Timer. Make sure the projector is in standby mode; Press the Off or Help button on the remote control for a minimum of 10 ...
NEC reset lamp without remote Questions & Answers - Fixya
www.fixya.com/tags/reset_lamp_without_remote/browse/nec
My bulb warning had just recently appeared a few weeks prior, so I thought the bulbmust ... ...reset the Lamp timer o an NEC MT1050 projector. ... ...reset lamp usagetime without the remote on NEC VT490 HelloPress the MENU button on the ...
reset lamp hours nec projector without remote Questions ...
www.fixya.com > Forum > Tags
Find solutions to your reset lamp hours nec projector without remote question. ... My nec vt48 projector gets hot and turns off. It ... Question about VT700 Projector.
Replacing The Lamp - Nec VT700 User Manual [Page 58]
www.manualslib.com > ... > Projector > VT700 > User manual
Jan 29, 2016 | NEC Office Equipment & Supplies
Reset lamp time
The lamp time is the time counted after the last resetting. It is shown in the OPTION menu as the usage time of the lamp. Pressing the RESET button on the remote control or the ? button of the projector displays a dialog. To reset the lamp time, select the RESET using the ? button. RESET ? CANCEL • Please reset the lamp time only when you have replaced the lamp, for a suitable indication about the lamp.
May 13, 2015 | Hitachi CP-X505 Projector
Blinking green power light on ux60 projector
I would refer to this page to determine if you ahve an internal problem or if your lamp is bad. Make sure you buy a lamp that has an original bulb inside and not a compatible. Original bulbs cost less than OEM but more than OEM-Compatible(knock off) but they last as long as OEM bulbs. Your SMART Hub Doesnt Turn your UX60 Projector On or Off 146535 SMART...
This link goes to a highly reputable company. They have the same Osram bulb as the OEM. SmartBoard Lamp
Mar 04, 2014 | Smartboard Smart Board 685ix, UX60...
Replaced main bulb in front but lamp button on front of tv is still blinking and tv won't show picture
The lamp timer on the Hitachi projector must be reset whenever the lamp has been replaced. The "Lamp" indicator on the display will light red or the "Change the Lamp" message will display when the lamp timer needs to be reset. Hitachi recommends that the lamp timer never be reset without replacing the lamp and to always reset the timer when the lamp is replaced. The message functions of the projector will not function properly if the lamp timer is not correctly reset.
  • Turn the power on. Press the "Reset" button for three seconds until the "Lamp xxxx hr" message appears on the lamp timer on the bottom of the screen.
  • 2
    Press the "Menu" button on the remote control while the lamp timer is displayed.
  • 3
    Press the left arrow button. Select "0" and wait until the timer display clears.
  • If this was helpful a vote on the thumbs up for the free advoce would be greatly appreciated. Thanks
    Apr 04, 2011 | Hitachi 60V500 60" Rear Projection...
    How do you reset the lamp timer?
    Here's how to reset the lamp timer:
    - Press the Menu button
    - Scroll down to the LAMP TIMER RESET option, then scroll right to enter
    - Confirm that it is OK to reset the lamp timer by hitting the OK button.
    - The on-screen menu should confirm the lamp was reset correctly
    You should only reset it after you've changed the projector bulb.
    Feb 03, 2011 | JVC TS-CL110UAA Projector Lamp
    Need to reset lamp. replaced lamp and installed new lamp.
    Press RESET, <, >, ENTER keys on remote within 5 seconds to reset lamp timer.
    Jul 29, 2010 | Sony VPL-CX86 Multimedia Projector
    Lamb will not reset
    Reset The Lamp Timer.
    While simultaneously holding down (+ . >) and AUTO SYNC on the projector, Press ( I ) ON and ( - . < ) on the projector.
    "LAMP 0000H" is displayed, indicating that the lamp timer is reset.
    NOTE..... Make sure only to reset the lamp timer only when replacing the lamp. If you reset the lamp timer and continue to use the same lamp, this may cause the lamp tp become damaged or explode...
    Sinista
    Mar 18, 2008 | Sharp Notevision PG-B10S Multimedia...
    Smartboard Smart Board 685ix, UX60 Projector Lamp - 20-01175-20 - OEM Equivalent Logo
    773 people viewed this question
    Top Smartboard Office Equipment & Supplies Experts
    k24674
    Are you a Smartboard Office Equipment and Supply Expert? Answer questions, earn points and help others
