Question about Unico : C826H - Sames as above Porta-Spin 6 Place with 18 Place Tube Holdster Rack
Autoclave syl 280b
Wire on safety valve snapped
Looking for a users manual for a Mcculloch 280B blower
Try Googling (McCulloch)(280B)(manual) without parens.
Jun 19, 2017 | McCulloch Garden
After connecting new 20 lb. LP gas tank to the fire pit and turning on the gas, I find that gas is not being delivered to the pilot, thus making it impossible to light a fire. Any suggestions?
tank safety valve. turn it off, turn it on several times with burner off.
if you hear a definate little snap,, thats when it activates the internal safety cutoff valve. when you get the valve on without the snap your good to go. I have had some bottles that I had to jar the bottom of bottle on the ground to get the valve to drop and to give out the gas. Then when all else fails take it back. always keep it upright..
Jun 12, 2015 | Heating & Cooling
Why is my autoclave not heating its water?
If you are not using purified or distilled water, most likely the heating element or sensor has become encrusted with lime or calcium and gives a false reading which will not allow the heating element to engage. (safety stuff you know) All you could try is a fill with a limeaway solution of 20%, cycle, drain and refill with distilled water, or disassemble and clean the components.
Jun 03, 2014 | VWR As12p Autoclave Accu Steam Sterilizer...
Divide the word Dangerous into syllabes
(sounds like a school assignment to me) ;-)
-count (& save) the 3 characters (1st syllable).
-start at position 4 (3+1 chars) in the string.
-count (& save) the 3 characters (2nd syllable).
-start at position 7 (6+1 chars) in the string.
-count (& save) the 3 characters (3rd syllable).
Logic:
-Initialize syllable-counter (x) to 1, position-counter to 1 (z).
-Initialize syl(x) strings to Null, where x = 1 to 3.
-Assign "dangerous" to string variable.
z = 1
y = 1
x = 1
string = "DANGEROUS"
For x = 1 to 3 DO
*Comment. read 3 chars (in a loop), add them to Syl (x).
For y = 1 to 3 DO
read a char(y) from the string at position-counter(z)
syl(x) = syl(x) + char(y)
z = z + 1
END DO
END DO
NOTE: not 100%, but close.
May 13, 2014 | Computers & Internet
Autoclave syl 280b
Replace the wire..
Oct 16, 2013 | Science & Laboratory
Sun series autoclave
The connect wire might be broken or the print.....
Jul 17, 2013 | Science & Laboratory
Errors in euronda autoclave
You have a leak. verify door seal; some valvs; pump damage or you have obstruction in some tube...
Jul 02, 2013 | Science & Laboratory
What are some different ways to remove air from the autoclave?
downward displacement, steam pulsing, vacuum pumps, superatmospheric cycles, subatmospheric cycles. http://en.wikipedia.org/wiki/Autoclave
Apr 29, 2013 | Science & Laboratory
3870EA autoclave
Check the rubber door (safety locking device) bellows. If it is cracked it will leak
Aug 23, 2012 | Health & Beauty
Unico : C826H - Sames as above Porta-Spin 6 Place with 18 Place Tube Holdster Rack Logo
104 people viewed this question
Top Unico Science & Laboratory Experts
William McMath
ray gallant
Are you an Unico Science and Laboratory Expert? Answer questions, earn points and help others
