Question about Konica Minolta Magicolor 5670EN Color Laser Printer
I have a magicolor 5670en and replaced the imagining unit and toner after the imaging units failed. Now I have a blue offset shadow on my black text!
SOURCE: Cartridge advancement to replace toner
It's done via the printers internal menu system: On your Menu Select button press the arrow down once, then press the right or left arrow until it displays Menu Engine, then press down arrow again, then arrow right or left until it displays Engine Replace Toner (not Engine change toner SZ), then arrow down again, then arrow right/left till it shows the toner color you need to change, then hit the Menu Select button in the middle. The cartridges rotate until the one you selected appears, open the door and voila!
Posted on May 09, 2007
  • 5 Answers
SOURCE: Toner Not Installed - After replace black
This is actually a desigbn fault on the magicolor printers. Underneath the toner rack is the 3 pin chip reader - normally white and plastic with 3 metal contacts sticking out.
it is at the bottom of the printer so very often toner drops onto it and the sensors dont work, it also takes a bit of a beating as the cartridges rotate. Its very easy to replace - but you need the part,
Minolta should have put it at the top rather than the bottow where it gets covered in dust.
these guys helped me a lot
http://www.zinetic.co.uk
Posted on Feb 22, 2009
  • 12 Answers
SOURCE: Imaging Unit Problem with bizhub C450
On the end of the image unit you will find a white bit of plastic with a small screw in the middle, make sure this screw is tight and then reinstall the units(give the units a bit of a shake too)
Posted on Apr 06, 2009
  • 192 Answers
SOURCE: After replacing black toner cartridge printer displays Drum Low
Ask you companey that surives you printer to look at it
Posted on May 20, 2009
SOURCE: How do I reset the Unit Life after replacing black imaging unit?
Just reset the chip. More details you can find here: http://www.chipreset.eu
Posted on Aug 23, 2009
Magicolor 2300DL toner all over left of paper
what color toner? cleaned how? might have bad image unit
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Mar 02, 2015 | Konica Minolta magicolor 2300DL Laser...
Blue Streaks & "Shadow Prints" on everything?
Mam, try replacing the cyan (blue) image unit may have a bad cyan image unit.
Jan 15, 2015 | Konica Minolta Magicolor 5450 Printer
Error 0502 on magicolor 16090 mf
replace the fuser unit
try this site for parts as a start Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Apr 14, 2014 | Konica Minolta Magicolor 5670EN Color...
Message states i unit low/ just replaced black i unit, which unit is it requesting
Will tell you CMYK
cyan yellow magenta and black or the toner is low for the black
Mar 16, 2014 | Konica Minolta magicolor 4750EN Laser...
Red filter on images
replace the color image units with OEM cartridges
Apr 29, 2012 | Konica Minolta magicolor 2300DL Laser...
Printer is saying black toner is out but i just replaced it with a brand new one from Staples
I've been having this problem and it turns out (and here's that bit that makes me look stupid) that I had been supplied with the imaging unit and not the toner cartridge so you may wish to check you've changed what it is you think you've changed. Toner carts are the top row, image units the middle and waste on the bottom.)
Aug 05, 2010 | Konica Minolta magicolor 4650DN Laser...
Yellow deposit
Remove the Yellow Drum unit, Check the drum for any toner. The drums should be clean and I believe a Green color. If you see any toner on the yellow unit replace the unit. Some models have a charge cleaner built into the image units, if that is the case with yours you will see a light blue knob on the front of the unit. Pull this knob in and out about 5 times to clean the units charger this may correct the problem without replacing the yellow image unit.
Mar 09, 2010 | Konica Minolta Magicolor 5670EN Color...
Konica Minolta Magicolor 5670EN Color Laser Printer Logo
54 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
