Question about Nokia C203
Nokia c2-03 set restart when camera on - Nokia C203
Nokia asha 200 restarts when camera opens
My nokia asha 200 gets restart when i open camera
Jun 20, 2013 | Cell Phones
My nokia e7 stays offline mode while sim inserted
After inserting the sim card it goes restart and ask for changing the profile from offline,when i try to change the profile from offline to others it hang and restarts showing the offline while sim inserted!tried with different sim but no use.
Jul 08, 2012 | Nokia E Series E7-00 Touch Smartphone-...
My nokia x6 camera flash isn't working anymore, i restore factory settings then the flash of the camera isn't working... plz help
This can be a hardware issue, failure of the circuit, the flash unit or the LED. In this case it is best to take opinion and support from Nokia care unless you are fully equipped to open and check and evenso the spare could be another issue.get estimate and proceed
Jun 28, 2012 | Nokia X6 16GB Cell Phone
I have a problum on nokia 5310 camera on standby mode
try these steps...
* press the keypad menu
* type the code *#6984125*# , it will lead you to phone internal settings, which has the following options, admin, network, internals, etc...
* scroll down and select internals, it will prompt you for password..type the code in the message box *#9072641*# and press confirm,
* once on phone internals,select test mode
* from test mode menu; select video which is item 6, or type 6 and press ok to lead you to videos menu,
* you will see a lists, which includes your update camera firmware. (item no 3)
* type 3 and press ok and wait till it has completed its updates and says successful.
* press end key to return to your phone menus,
* you would want to restart your phone for the updates to be fully completed.
* once restarted, select camera, or press camera button and check your camera...
please be noted that sometimes, other phones may restart after updating the camera firmware..
Jul 05, 2010 | Nokia 5220 XpressMusic Cellular Phone
While opening n70 camara error is unexpected error
HI there, after turn on the phone don't open the camera.Just reset the phone from phone factory settings.After that restart the phone.When is completely ready for work then open the camera. I hope you naver face the problem.If you faced that problem again, then reinstall the phone software from net or nokia shop. Thanks.
Feb 25, 2010 | Nokia N70 Cellular Phone
Nokia n73 front camera hardware failure
Aug 17, 2009 | Nokia N73 Cellular Phone
Rebooting problame
Try a software update if there is one available for the handset, use Nokia software updater...
May 08, 2009 | Nokia 3110 Cellular Phone
Problem in using camera.
you can go to settings and restore default factory settings the phone will restart. this might be helpful.
Thanks.
Please vote.......
Jul 16, 2008 | Nokia 3110 Cellular Phone
Nokia C203 Logo
342 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
