Question about Denon PMA-100M Amplifier
DENON PMA-100M - Denon PMA-100M Amplifier
2 Suggested Answers
  • 264 Answers
SOURCE: How can I connect a subwoofer to this device (denon pma-520) http://www.hifiengine.com/manual_library/denon/pma-520.shtml?destination=node%2F14208
The only safe way to do this us to connect the sub to one of the other speaker outputs using a "speaker selector" switch. For example, you would go out of the receivers left speaker output, into the selector switch then out of the selector switch into the sub and the left speaker. There really is no other way.
Posted on Jun 09, 2014
Distortion appears while trurnning up the volume on right channell
You just need to replace your volume knob for a better one , a couple of bucks 10 dollar
Jun 18, 2014 | Denon PMA-100M Amplifier
Jun 08, 2014 | Denon Pma-520 Integrated Stereo Amp...
Denon pma 250SE phono problem
Denon PMA 250SE does not have a RIAA phono preamp.
for some info about these preamp and details here;
Phonopreamps.com Home Page
Note: Choose a better quality regulated power supply,
for these preamps.
Although an updated turntable with USB can be used
without the need of such RIAA phono preamp.
Jul 26, 2012 | Denon Audio Players & Recorders
My Denon PMA-900V integrated amp has distortion in the left channel. When it is cold it is very minor, as it heats up and is played at louder volume the distortion is much worse.
The good news is that it's in one channel, which means you have the right channel parts to compare it with. Now the bad news whatever causing it and it's likely to be a semi-conductor (transistor or IC) has to be replaced. However finding it is easier than you might think. For a start it's going to be hot to touch. And you can get get it to stop being hot, while the amps on, so correcting the fault, for a while. You do this by spraying it with Servisol Super Freezer spray. You have to have the amp running for this. Find the left channel amp and wait while it goes bad. Then spray (one at a time) any part you suspect. If the sound returns to normal, you have found the faulty part! To prove it spray the same in the right channel. That shouldn't change.
You can get the freezer spray from your local electric parts shop (such as Maplin UK).
Jan 13, 2011 | Denon PMA-100M Amplifier
UDRA-F10 displays "Protect" on display- no other function is runnung.
See the link below for an explanation and post any additional questions here.
Thanks,
Dan
Link: http://www.fixya.com/support/r5390728-protector_means
Aug 31, 2010 | Denon PMA-100M Amplifier
Red power light flashing no sound avr-587
Hi...
The amp will need service
Depending on where you are I can suggest someone to fix it
Mar 28, 2010 | Denon PMA-100M Amplifier
Operating Instructions, Denon PMA-535R/PMA-735R
Hi there
You can download one from here Select the FREE download button and you will get a PDF copy of the manual. Let me know if you have any problems getting it. Cheers
regards robotek
Jan 09, 2010 | Audio Players & Recorders
Hi, I have a Denon PMA320. I would like to connect it to a Hitachi 32LD6200 TV. How do I get the sound from the TV through the amp please? Many thanks, RichT
If the TV has audio out jacks then you can connect them via a lead to the amp. If not the you can use a scart socket. You can get a scart plug with audio and video RCA jacks on the other end of it and connect that to the amp. If the TV has only one scart and you are using it for a video or DVD device, get a scart adapter with more than one socket.
Jun 28, 2009 | Denon PMA-100M Amplifier
Radio preset Denon UDRA-f10 doesn't save
1) tune in to a radiostation
2) press the Memory button
3) select a preset number for 5 Second
4 Skip "press Memory again"
Feb 04, 2009 | Denon PMA-100M Amplifier
My aplifier Denon UDRA F-10 says "protect"
Blingking Light or Protect usually means that there is DC appearing in output stage and is protecting Connected Speakers.
It can be faulty Output Stage (Bad ICs/Transistors/Resistors/Capacitors) or Faulty Power Supply.
Working on These types of Problem is not user friendly at all.
Advising to take local Authorized Shop.
Jan 30, 2009 | Denon PMA-100M Amplifier
Denon PMA-100M Amplifier Logo
43 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
