Question about Grizzly Big Bear Atv Maintenance Free Battery
NEW STATOR POWER ON WHTE WIRES TO RECTIFER POWER ON GREEN AN BROWN WIRE .CHANGED CDI BOX NO POWER TO COIL . ON OFF SWITCH GOOD. NEED HELP
    Champion:
    Scholar:
  • 227 Answers
Check the wires for continuity.
Posted on Oct 24, 2013
    Champion:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 225 Answers
Can you review your question, and provide a little more information. What did you change? Did you have power before you changed the CDI? What are you using to check for power?
Posted on Oct 16, 2013
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
No fire to coil changed stator checked ac voltage with meter on 3 white and brown and green wires voltage to rectifier no power on red or white wire to cdi,changed cdi box still no voltage on coil
Do you have a teather switch ? I would suggest start by checking the resistance of the on off switch . Then procede to the cdi relay. If you do not know how to test such items let me know and I will break it down step by step.
Oct 16, 2013 | Grizzly Big Bear Atv Maintenance Free...
Mx360 cdi circuit
Hi, Anonymous all this electronic brain surgery is above my pay grade Good luck and have a wonderful day.
Jun 24, 2017 | Yamaha Motorcycles
Kawasaki zxr 750 Bad Coils or CDI??
Rarely will both coils fail. Try disconnecting blk wire with yellow stripe from cdi. Check fire again, if fire is good you !likely have a bad ign switch. If there is still no fire, you will need to test trigger, stater. Also remember the can position senor. Test denser to specs. If cambsenser can't tell cdi where number 1 piston is, there will be no fire. Let me know how it works out for you.
Aug 09, 2017 | kawasaki ZXR 750 Motorcycles
1991 ktm 250
Hi, Iain for more information about your question and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
sem stator wiring diagram Google Search
KTM EXC Repair Manual Ignition sem Check Stator sem
KTM 250 sxf 2016 Repair Manual
http://www.partsfish.com/page/oem-parts-for-ktm
KTM 250 SX EU Owner Manual
Apr 10, 2017 | KTM MXC 250 Motorcycles
1977 dt 175 e and i can't get it to fire i put a new coil and still no spark
My old 73 175 had points, I don't know if yours does. There is also the stator/ magneto. Try disconnecting the kill switch or unplug the key cylinder. There is a more detailed check in the manual. I can't find my old 175 manual but ttr125 says 1) check plug for spark- clean or replace. 2) check entire ignition system for connection. 3) check ignition stop switch. 4) check coil. a- primary coil, b- secondary coil. 5)check cdi coil. a-pickup coil. b- charging coil. Since you have replaced the coil I will only give specs for the cdi check. The picture shows a plug under the tank disconnected. It has four wires brn grn red and wht. To check pick up coil resistance set ohm meter to x 100. attach the plus lead to red and neg. lead to white. It seems to have a short wire in each jaw of the alligator clips of ohmmeter that is pushed into the disconnected plug that contacts appropriate wire color. Reading should be 248 to 372 ohm at 20 degrees C (68 degrees F). Charge coil test places the plus lead of ohmmeter to the brown wire and neg. lead to the green wire of the open plug. Meter at x 100. Reading should be 688 to 1032 ohm at 20degrees C. Of course while doing step 2 check for good grounds and tight connection at plug cap and use a new plug. Good luck.
Apr 06, 2011 | Yamaha DT 360 Motorcycles
I need to know what wire to hook the coil up to the CDI box on a 1992 KX500. Its orange and doesn't correspont to any other wires.
the manual I have is from a couple of years earlier
it shows three wires in to the CDI from the stator
a red black that also goes to the stator but is joined to a black\white connected to the stop switch
and a single black that goes straight to the coil.
a 1992 may not have the original coil, or it may have had a black sheath over the orange when new
If that doesnt help, you may need to repost the question
Jun 15, 2010 | 2002 kawasaki KX 500
I have a 1984 Honda X200R and it's not getting a
Hi and welcome to FixYa,
On Asian versions of an 84 Honda XR200R, the CDI unit has six wires:
  • blue/yellow - pulse generator
  • black - to ignition coil
  • black/white - engine stop switch;
  • green - ground;
  • green/white - pulse generator
  • black/red - exciter/charging coil at stator.
The ignition coil has 2 wires:
  • green - ground;
  • black - to CDI
Good luck and thank you for asking FixYa.
Nov 11, 2009 | 1985 Honda XR 250 R
Wiring from stator to regulator/rectifier to cdi on chinese atv
Would this help? From the stator:
  • 3 yellows to the rectifier/regulator combo;
  • blue & green from the pulser coil to the CDI.  The blue here is actually connected to the ground.  The CDI's ground wire is black/white;
  • (near the stator) single blue to the CDI.
Aug 17, 2009 | 2003 Hyosung Comet 250
No current to the cdi box,but the light comes on when i kick it over?
if theres no current to the cdi but the light works then its either the outer coil or the stator coil is bad and the lighting coil still works.
May 26, 2009 | 1994 Honda XR 600 R
Grizzly Big Bear Atv Maintenance Free Battery Logo
111 people viewed this question
Top Yamaha Vehicle Parts & Accessories Experts
Andrew Taylor
Andrew Taylor
Coss
Tom Chichester
Are you a Yamaha Vehicle Part and Accessory Expert? Answer questions, earn points and help others
