Question about Toshiba 52HMX84 52" Rear Projection HDTV-Ready Television
Blue still image when on. - Toshiba 52HMX84 52" Rear Projection HDTV-Ready Television
    Sniper:
  • 52 Answers
Usually that only appear when there are no video input, its better than that flickering/raining/scratching image.
Posted on Oct 16, 2013
My Lexmark 7100 prints documents with color images with blue lines running through the images. How do I get rid of the blue lines? Thanks.
Hi there
It would be more convenient to do that if you own an image processing tool.There are many image tool which supports to process lines in image You can just google one of them to help you out.Best wishes
Imaging Line Annotation Guide in NET
Jan 08, 2014 | Lexmark International Lexmark 7300 Series
It is leaving heavy blue streaks on everything printed
Hey, blue streaks could be a few different things. The first thing I would check is the image unit. Try swapping out the cyan(blue) image unit with another color, such as magenta. If the streaks change from cyan(blue) to magenta in color then you know the image unit is bad and must be replaced (part # 108R00581). If it is not the image unit then it most likely is the developer. The developer takes about 40 minutes to install and really should be done by a service technician.
Here is a video that shows you how to remove the image unit and where you can purchase one.. Just go to 57 seconds in the video. Hope this helps, good luck!
May 17, 2011 | Xerox Phaser 7750GX Laser Printer
Hp 5400c scans blue images
sounds like a faulty scanning head to me......
when images are scanned they are normally imaged in 3 colours red blue and green these are then combined to give a full colour scan. sounds like you are only getting the blue pass.
not alot that can be done here, if it is in warranty (check with manufacturer for duration of warranty as sometimes this can be more than a year) they should repair or replace this for you
Apr 23, 2009 | HP Scanjet 5400c Flatbed Scanner
Images has a blue color across the center
Wow, 3 in a row. As described on 2 other projector issues this is very similar to those others. I'll repeat the info here.
I assume this is an LCD. I don't remember the s4 being a DLP projector.
This sounds like the LCD panel used for the blue color has gone out. The image is made up of red, green and blue images layered upon the screen. If the blue panel has gone out then there is nothing filtering out the red light in the image.
It looks like yours has just a secone of the panel dying or comming loose from it's connector.
It could be a simple open and reconnect fix. I personally have never opened a projector, so I'm not going to walk you through it as I do not know how hard it would be to tinker with. It should eb a cheap fix for a true repair man though.
Mar 14, 2009 | Epson PowerLite® S4 LCD Projector
Hit 53UWX10BA
convergance ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Dec 14, 2007 | Hitachi 57SWX20B 57" Rear Projection...
Blue shadow
call tech ...suggest to ck. blue coolant..and c-chips.
Oct 30, 2007 | Sony KP-53V75 53" Rear Projection...
Samsung HCM5525W TV red blue outlines on images
The Samsung has bad convergence IC's most likly. This should be repair ONLY by a trained technician as a TV set is not a place to experiment or tinker with because of the extremly high voltage inside. This repair should cost you in the range of 250 to 400 bucks . Good Luck
Jul 31, 2006 | Samsung HCM5525W 55" Rear Projection...
Blue and red squares over my image
A histogram is a graphic representation of the distribution of brightness values in an image. The C-5500 has two histograms. One displays a real-time graph on the LCD screen as you compose your images and during the Quick View of images after they are shot. The DIRECT histogram displays potentially over and under-exposed areas in the image with a grid of squares—red for over-exposure and blue for under-exposure. You can set the histogram to OFF to prevent the histogram from appearing.
Sep 04, 2005 | Olympus Camedia C-5500/C-55 Sports Zoom...
Toshiba 52HMX84 52" Rear Projection HDTV-Ready Television Logo
13 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
