Question about Toshiba 56HMX195 52" HDTV DLP Projection TV
Plain blue still image - Toshiba 56HMX195 52" HDTV DLP Projection TV
    Champion:
    New Friend:
  • 225 Answers
What is the "input" source the TV is set on>?
Posted on Oct 16, 2013
Have a bizhub c550 printer and when printing a plain white document i get a yellow background, What could be the problem?
Sir/Mam, have you replaced the yellow image unit ? Not the yellow toner cartridge. There two seperate units. Also there are on each image unit blue/white nubs that you can pull out and push back in to clean interal image unit parts do that you do not have to pull the image units out just ensure that when done cleaning they are pushed all the way back in. Once the image units are not toner cartridge and there are four of them located below each toner cartridge .
Jan 08, 2015 | Konica Minolta Bizhub C550
Toshiba 52 inch rear projector tv has a plain blue image when on
That is a common "output" for most tvs when there is no "input" . How many devices do you have hooked up to it? DVR? Cable box? gaming console? Do any of them work?
Oct 16, 2013 | Televison & Video
There are a couple blue lines across my pictures all in the same place on every one. This is happening with all my images taken with my Diana Mini. What can I do?!
Light leaks, plain and simple. That's the "beauty" of these cameras. You can try attacking all the surfaces where the back seals with electrical, masking, or gaffer's tape (small amounts, so that it'll still open/close and function), or just live with it. These things aren't made for quality sharp well-exposed images - they're made to have these kind of quirky weird images that on any normal camera would get them sent back for a refund.
Jun 26, 2011 | Lomo Diana Mini 586 Film Camera
Xerox phaser 6110 dropouts
you need to clean image unit if you dont have any expertise dont do it
Dec 14, 2009 | Office Equipment & Supplies
Stripes on Images only - Text OK
Perhaps the CMY color heads need alignment. If you have not already done so, run a head alignment from the driver maintenance section. It will print out a page containing several lines and text, and request you select the closest-aligned images. After this is done, do another image print to check for improvements.
Normally, the printer uses the black cartridge for text and the CMY inks for images (even for black on photo and specialty paper). So when you are printing normal text pages on plain paper, only the black ink is used. A good check for this would be to print a normal text page, but select photo paper in the driver to trick the printer into using the CMY inks to make a substitute black text page. If this looks ok, then you are having issues other than cartridge alignment.
May 24, 2008 | Canon BubbleJet i560 InkJet Printer
My laptop has a faint light blue shadow appearing to the right of any black to white high contrast image or any plain black text. Is it a heat problem with my video card or is my monitor about to fail?
early warning that video is going south. could be video chip or the screen itself. happen with any other card? YOu might consider re installing the video drivers
Apr 25, 2008 | Computers & Internet
When printing, if I select any other form of paper than "Plain Paper", e.g. "Photo Glossy Paper", the print (of a photo) comes out with a distinct Magenta overhue. The true colours are...
Hello Landscapeman ,
You need to specify the paper type when the print dialog box appears. Heavy glossy paper needs to spend more time in the fuser so that the toner is fixed.
Mar 25, 2008 | Computers & Internet
Colour prints coming out with a lilac hue
check whether the printer is in proper mode or not
Feb 29, 2008 | Epson Stylus Photo 950 InkJet Printer
Too much green
It is unlikely that the sudden appearance of a green hue is due to the printhead or drivers going belly up. If the images on photo paper are OK when using the plain paper setting but have a severe green/blue hue when using the higher photo settings it is likely that the photocyan cartridge has been contaminated with cyan ink. Throw the contaminated PCyan cartridge away and fit a guaranteed photocyan cartridge (OEM or compat). Carry out a deep clean and run several plain papers through on a high photo setting. The green hue will gradually disappear.
Dec 06, 2007 | Canon PIXMA iP8500 InkJet Photo Printer
Weird problem not convergence
Mine is doing the exact same thing! have you found a fix yet?
Apr 23, 2007 | JVC AV-48WP74 48" Rear Projection...
Toshiba 56HMX195 52" HDTV DLP Projection TV Logo
15 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
