Question about Uniden D1680 Cordless Phone
I have a D1680 system with one accessory handset. The hand set on the base is showing Searching although it is on the Base. It rings when a call comes in but when picked up it says out of range. The Accessory handset works perfectly.
  • Mark Trotman
    Mark Trotman Oct 17, 2013
    The base was the same. I followed the steps stated in the solution and the problem was corrected. Thank you.
  • Mark Trotman
    Mark Trotman Oct 20, 2013
    I posted a comment on the 17th indicating that the 1Solution sent below worked.
    Champion:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 225 Answers
1. Press & hold End and # at the same time until you see the System Reset menu.
2. If you still have the base the handset is registered to, select Deregister HS, then select the handset you want to reset. If you don't have that base anymore, select Base Unavailable.
3. To confirm, select Yes. The handset displays "Handset not registered"
Now you want to register the phone again.
1. Place the handset in the base; the display should say Handset
Registering.
2. Wait until the display says Registration Complete (about 30
seconds), then pick up the handset and press Talk/flash.
You should now have a dial tone
Posted on Oct 16, 2013
2 Suggested Answers
  • 1416 Answers
SOURCE: existing uniden 3-station dect3380; all handsets
Put of the phone for some time allow it to relax and get it memory then put it on after some time.If the problem remain then you will have to contact the service provider through another phone or visit there office. i.e the phone sensor will need to be reprogram from there office.
thank you thnaks for using fixya.
Posted on Oct 18, 2010
Why does screen indicate "searching"?
The handset cannot communicate with its base.
When the handset cannot establish its secure (encrypted) radio
link with the base it is 'paired with' or 'registered' to, it will first
say "Connecting....", then it will display "Out of Range or No
Power at Base", then it settles at the infamous "Searching..."
display.
Although rare, the registration between base and handset can
become corrupted and lost so that we must de-register and
then re-register the pair.
First, ensure that power is 'on' at the base (a more common cause)
and the cradle will charge the handset, etc.
Second, be sure the handset battery is well charged as a weak battery will interfere with the registration process.
Then try the following ( 'works for the D1680, D1481, and similar):
To deregister the handset:
1. Press and hold the [END] and [ # ] keys at the same time,
after a few seconds the display will say
"System Reset, Deregister Handset"
press [SELECT]
scroll to "Base Unavailable"
press [SELECT] (chirps) press [END]
display reads "Place in base..."
Next, to re-register the handset:
2. Set the handset into the base cradle and wait,
after ~30 seconds the handset should display
"Handset #" and be good to go...
or it will display "Registration Failed"
Mar 20, 2016 | Uniden DECT 6.0 Cordless Phone
When answering mode is on I do not want to hear the ringing(4x) tones before going to answering.I've switched off the 'call screen' option. still I hear the ringing although not recording at least.
Just set the ringing volume to off.
You can choose from four ringer volume settings (off, low, medium, and high) separately on each handset or the base.
With the phone in standby, press or on the handset or VOLUME or VOLUME on the base. The handset or base sounds the ringer at that level. Use on the handset or VOLUME on the base to make the ringer volume louder. Use on the handset or VOLUME on the base to make it softer or turn it completely off.
Note: If you set the ringer volume to Off, the handset or base won't ring. Other handsets or base will ring according to their individual settings
May 29, 2015 | Uniden DECT 6.0 Cordless Phone ID
D1680-2C How do I shut off the ringer?
On the handset, press down-arrow while in standby mode. On the base, press - while in standby mode. See pages 4 and 6 of the manual.
Apr 08, 2014 | Uniden D1680-2 Expandable DECT 6.0...
Hi, Bruce Kelly I have a Uniden DECT1480-3 That the screens on all hand set's say's SEARCHING. I can not get a dial tone so I am unable to make a call or recieve a call. Their is no dial tone and all of...
All of the handsets appear to have lost their
registration to the base and will need to
be first de-registered then re-registered.
It may be necessary to do this in three stages.
First be sure that all of the handset batteries
are fully charged.
1.
Clear one of the handsets of its registration:
hold down both the [END] and [#] keys
at the same time until the display shows the
SYSTEM RESET menu.
Since the handset is not recognized by its
base, select "Base Not Available".
Confirm the choice by selecting "Yes".
This handset will now display
"Handset Not Registered"
2.
With "...Not Registered" displayed, place
the handset into the base unit cradle.
The handset should now dieplay
"Handset Registering"
After ~30 seconds the display should show
"Registration Complete" and will have a
handset unit number.
If the unit shows "Handset 1" (doubtful)
then just repeat steps 1 & 2 above for each
additional handset in turn. This can also be
the route if you do not care what the numbers
are and do not exceed the maximum count
for your system ( some are 4, 5, or even 12 ).
If the handset is a number other than 1 you
may want to clear the base & re-register
all of the handsets:
3.
Using the now-registered and working handset
(number x), press both the [END] and [#] keys at the same time until the display shows the
SYSTEM RESET menu.
This time, choose "Deregister HS" and the
System Reset Menu will prompt you to
select from the list of registered handsets
which one you want to deregister: choose
one that is NOT the one you have working.
Cycle around deleting them all until only the
one that is working is left: select that one and
the system will be ready to start re-registering
all handsets again from Handset #1.
Start at process (1) above, then (2).
Good Luck!!
Apr 07, 2017 | Uniden Dect1480-3 Dect Cordless Phone, W/3...
Uniden base flashing 88 8
I just got off of the phone with Uniden for the same issue with my D1680-4. The alternating "8" - "88" code is an indication that the base is dead. They will be sending me a new base (and 2 handsets). During the call I learned that if you do not have a receipt, Uniden warrants their phones for up to 15 months. The advertised 12 months, plus 3 months for the product to get from manufacturing, through distribution channel and finally sale to the consumer.
Feb 17, 2012 | Uniden D1680 Cordless Phone
Hi I have a Cordless Uniden Dect 6.0 and also another one that sitts on a bitter base. My problem is this: the cordless with the smaller base shows the message 'Searching' and wont do anything,...
Welcome to FixYa.
Reset the units/set up by doing the following:
  • Turn OFF all the HANDSETS.
  • Remove the batteries of the HANDSETS.
  • Unplug the power source of the BASE.
  • Unplug the phone line of the BASE.
  • Let it stay that way for 30 mins.
  • Insert the battery again of the HANDSETS, make sure it is charged properly.
  • Plug back the power source of the BASE.
  • Plug back the phone line to the BASE.
  • Register any handset that is unregistered (refer to manual).
Keep me posted.
Jas247
Sep 11, 2011 | Uniden D1680 Cordless Phone
I have purchased a SL82318 Handset. I have a SL82318 system, with all three original handsets working perfectly. This fourth handset displays: "Connecting..." and nothing else. According to...
*331734#Menu Select on the handset should de-register that handset from the old base, then you can register it to the base as per the manual (put it in the base and hold down the handset locator button for 4 seconds)
Jan 04, 2011 | Vtech SL80108 1.9 GHz 1-Line Cordless...
Handset won't ring
You need to reset the main base and make sure the ringer volume is turned all the way up. Disconnect the power from the back of the main base, press and hold find hs key while reconnecting power until you hear long beep. Should reset base and handset.
Mar 17, 2009 | Uniden DECT 6.0 Cordless Telephone...
Searching....
The problem of searching.....
After trying all the technician's suggestions had failed; I disconnected the base to return it to the store for replacement. Then I decided to try disconnecting and reconnecting power and phone line, placed handset back on base and the phone reset itself and is working fine...
Recap:
Disconnect power and phone line from base for about 30 seconds and reconnect both power and phone line to base and place handset back on base; it should reset...
Linda
May 05, 2008 | Uniden DECT 6.0 Cordless Telephone...
5808 drops call and starts searching for base
Got a wireless router? Change channels on the router off Ch6, the default channel and that may help your phone communication to the base station. I have had wireless phone customers lose their wifi when their phone rings, same frequency or intereference on that frequency.
Feb 13, 2008 | Vtech 5808 Cordless Expansion Handset
Uniden D1680 Cordless Phone Logo
184 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
