Question about Madison New York Madison - T3968-1003 - Duct Temp Probe, 12 In L, 3/16 In Dia
Need to tighten tension cable on york 1003 - Madison New York Madison - T3968-1003 - Duct Temp Probe, 12 In L, 3/16 In Dia
Is there a way to tighten the tension on a drive cable on a rear wheel drive Brute lawn mower
Has cable come off its tightener or something has come undone.
Is there a tightener that needs adjusting.?
Jun 10, 2015 | Garden
Manual for pro power horizontal and vertical multi gym
Hi I have been searching for the instructions for this gym and realised it is listed as the York multigym 1003...hope this helps!
Feb 05, 2012 | Exercise & Fitness
I need to tighten belt for the mower deck, how is that done? it is a 2004 craftsman 17.5HP 42 " deck. Can you help me
Each of the pulleys on top of the deck should have tensioners. These tensioners are usually the type which have a bolt for you to tighten while attached to the pulley. While you tighten the bolt, the pulley puts tension on the belt.
Aug 05, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a york 1003 multi gym,but have no cable,how can i obtain 1
Go to www.yorkfitness.com Click on to customer service you can contact them on purchase of the cables, Also they a downloadable manual for your unit
Jun 13, 2010 | York Exercise & Fitness
Got a York 1003 multi-gym & I need to find out the cable layout for it. Any help gratefully received.
Go to www.yorkfitness.com click on the weight icon then the upper right hand side you will see customer support, then go to instruction download and then mutli gym and your unit pdf is their
May 03, 2010 | Exercise & Fitness
The choke won't stay out when I pull it. When I pull it all the way out, the cable seems to pull it back in.
Either the tension adjustment is not correct on the cable or someone has "lubricated" the cable. Never apply any type of lubricant to this cable. It depends on friction to hold it in position.
The tension or friction is adjustable. If you look at the cable closely where it comes through the bracket that holds it, you'll see a serated plastic nut and a metal nut. The metal nut holds the entire cable in the bracket. The serated nut adjust the tension on the cable. By turning the nut clockwise, you increase the tension making the cable stay where it's put. Counterclockwise makes the cable move more freely. Carefully tighten the serated nut to get the tension you need.
You cable may already be damaged too. In the previous paragraph, I said to "carefully" tighten the serated nut. If you try to tighten the nut too much, the plastic housing at the knob will break. Once this happens, you must replace the cable in order to get it to work correctly.
Jan 08, 2010 | 2005 Harley Davidson FXDWG - FXDWGI Dyna...
How to I get a new tension arm on a 1998 Chevrolet Cavalier.
  1. Disconnect the negative battery cable.
  2. Remove the drive belt.
    1. Remove the tensioner bolts.
    2. Remove the tensioner.
      1. Install the tensioner. NOTICE: Refer to Fastener Notice in Service Precautions.
      2. Install the tensioner bolts.
        • Tighten the bolts to 50 Nm (37 ft. lbs.) .
      1. Install the drive belt. Connect the negative battery cable.
        • Tighten the bolts to 16 Nm (12 ft. lbs.) .
Oct 01, 2009 | 1998 Chevrolet Cavalier
Assembly instructions for york multi gym 1003
how do you fit the cables on a York 1003 multi gym ?
Mar 27, 2009 | York Exercise & Fitness
Where to tighten belt on reebok280 treadmill?
there should be 2 end roller caps, one on the left and one on the right. in these caps there will be an allen key bolt, turn each one a full turn to tighten the belt. continue to turn these bolts until you are happy with the belt tension.
Nov 12, 2008 | Reebok New York Giants Eli Manning Jersey
Madison New York Madison - T3968-1003 - Duct Temp Probe, 12 In L, 3/16 In Dia Logo
447 people viewed this question
Top Madison New York Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Madison New York Measuring Tool and Sensor Expert? Answer questions, earn points and help others
