Bosch classix 14oo washing machine displaying fault code F18.Wont pump water out but will spin if clothes are taken out.PLEASE can you help?
  • 42 Answers
It could be that its spinning after you take the clothes out because you have given it 2 opportunities to drain/pump out.. once with the clothes in and once when you have removed them. Machines wont spin if the water doesn't drop below a certain level within a designated length of time. The problem might be a simple blockage
Check filter
Check drain hose and pipe its emptying into
Put machine on its soap box side down (very important) and powered off (very important)
Looking up the base of the machine you will see the pump right in front of you
Check wiring
The pump on these machines if I remember well have 1 screw and then you have to twist it to remove it
This will give you a chance to see if something got behind or is wrapped around the emptying propellor
Posted on Oct 17, 2013
  • sharon marie smith Oct 18, 2013
    THANK YOU so much.All working now.
4 Suggested Answers
  • 130 Answers
SOURCE: BOSCH WASHING MACHINE WONT SPIN, FLASHING RED SPIN LIGHT
check the pump clean out. sounds like something is jammed in the pump
Posted on Feb 16, 2009
SOURCE: bosch exxcel wf02465 wont spin
We had similar problem, with the spin cycle not working. We opened the 'drain' pipe (front-right bottom side). It was full of lime scale; never been opened for years. We cleaned it up and the spin cycle is now working.
Posted on Sep 13, 2009
SOURCE: bosch washing machine flashing red lights
all lights are flashing on bosch classixx express no thinh working no water intake door is locked what is the problem and can i do it myself
Posted on Jan 07, 2010
Bosch shx36l05uc/21: After running diagnostics the 'wash' button keeps flashing, can someone tell me what the problem is?
Hi Jeff, As you can see there's 3 different Bosh washing machine models, Hope you can find your error code.... CHEERS..
Bosch Washing Machine Fault Codes
F16 - Door lock error
F17 - Inlet valve error detected
F18 - Drain error detected
F23 - Anti flood device has been activated
F34 - Door lock error
F42 - Motor fault
F43 - Motor fault
F44 - Motor fault
Bosch WAE Range Washing Machine Fault Codes
F16 - Door lock problem
F17 - Inlet valve
F18 - Drain pump
F21 - Motor
F23 - Anti flood system activated
Bosch WFP Range Washing Machine Fault Codes
F01 - Water intake timeout
F02 - Heating timeout
F03 - Draining timeout
F04 - Motor fault
F05 - Uncontrolled motor startup
F06 - Short on NTC Detected on hot water intake
F07 - Open circuit NTC Open circuit wiring
F08 - Door open when program started
F09 - Unexpected heating
F10 - Communication error
F11 - Overheating
F12 - Short circuit
F13 - Mains voltage too high
F14 - Mains voltage too low
F15 - Faulty temperature sensor on motor PCB
F16 - Faulty rinse sensor Displayed only in test
Mar 30, 2016 | Bosch Dishwashers
DESPERATE..... Displays fault code F18 frequently.Have cleaned the filter 3 times now recently(in the last 3 days) and is very clean but stopped again.Just emptied ll washing out of it and spun it to
I would check that the drain pipe is also clear.
You can actually get a build up of old soap powder in the pipework.
This pipe would be on the rear of the machine (grey in colour) and would connect to your waste pipe (perhaps under a sink)
If you can pull the machine forward and check to see if this pipe is indeed blocked, or even restricted.
I found this answer that may help you.
https://uk.answers.yahoo.com/question/index?qid=20120322120919AANhp8H
May 12, 2014 | Bosch Classixx WFL 2066 Front Load Washer
F18 error code on Bosch Exxcel washer/dryer, and water pouring out the bottom - any ideas on how to fix? Filter is clean.
This might help you with the pump its on a bosch Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 04, 2013 | Bosch Logixx WFT 2806 Front Load...
Bosch Logixx 8 - unblocking pump/removing front panels
Bosch Logixx 8 Washing Machine This video will show you how to change the pump washing machine
And don't forget to like us on facebook
Aug 30, 2012 | Washing Machines
I have a Bosch Classix 6 1200 Express that stopped working 23 minutes before the end of the cycle. It has been noisier recently but this time it stopped altogether and when I tried to spin the clothes the...
Hi davidandsall,
Before it can Spin (The last part of any cycle), it would need to drain the water first. Your machine is stock on that particular position, most likely because of a clog in the Drain Filter compartment.
You will need to clean it.
Please follow my below Tip on how to do it:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER
Kind Regards d")
* If this solution helped you, please rate it
Aug 05, 2011 | Washing Machines
Error code F18
F18 error code means that the filter is blocked.
Look around for a propeller shaped part, it should be able to spin freely. If not, remove the debris so that it is unblocked.
Hope this helps (remember to rate and comment this answer).
May 14, 2011 | Bosch Axxis+ WFR 2460 Front Load Washer
Bosh Washing Machine F18 fault
I also had this problem - the machine was full of water and it flashed up F18. I had to drain the water out of the machine using the small pipe located next to the drain filter. There was loads of water to drain out. I used my oven roasting tray which was perfect for the job. Then I undid the screwcap filter. There was a lot of really black water that came out, along with about two pounds worth of coins and some hairgrips. Now my machine works perfectly !
Sep 01, 2008 | Bosch Logixx WFT 2806 Front Load...
Why is the fault F18 error code on my bosch washing machine flashing?
Open the small flap at the front bottom right of the machine. DONT unscrew the circular white knob yet!!! Use the small black hose to drain the machine into a tray, by removing the small cap on the end of the hose. You will have to use a tray, rather than a bowl because the hose is only short, and keep emptying the tray.(put a washing up bowl next to the machine, so you don't have to carry the tray.) If water does not come out of the hose, then gently unblock it with a piece of wire or fine knitting needle. When water finally stops coming out of the hose, it is time to gently unscrew the white knob anti-clockwise, and pull it forwards. Now you can clear the debris out of the pump rotor, which is behind the white knob. Check with your finger that it can rotate freely, then replace the white knob firmly. Make sure the small cap is replaced on the end of the hose, clip it back into place and put back the cover panel. If this doesn't work then there is a blockage deeper in the machine, and dismantling will be required. Good Luck!!
Feb 03, 2008 | Bosch Logixx WFT 2806 Front Load...
Washing Machines Logo
62 people viewed this question
Top Washing Machines Experts
