Question about Sony PS3 DualShock3 Wireless Controller for PlayStation 3
PS3 Controller Keeps Flashing
Whenever I switch on my controller (or try to) the four lights keep blinking and flashing. - I have tried reseting it but it just stays flashing. -I have tried plugging it into my laptop but it just flashes. -I have tried to charge it but it just keeps flashing. Please help?
    Problem Solver:
  • 5 Answers
Does the controller actually turn on and if not you have to connect it to the ps3 or whatever your connecting it to
Posted on Nov 10, 2013
  • 79 Answers
SOURCE: my ps3 controller just keeps on flashing
reset it with the small button on the back
Posted on Mar 20, 2009
SOURCE: controller not working
I had the same problem, so I called customer service and had me do this:
1) with the USB cable plugged into the controller, power down the ps3 and turn the on/off switch in the back to "off".
2) hold your thumb down on the front button (where you normally can turn it on) while turning the switch on the back to "on" again. keep your thumb or finger on the front switch.
3) You will hear the normal "beep" that you usually hear when the PS3 boots up, but after a few seconds later, you will hear a secondary beep. Remove your thumb or finger after this second beep and the PS3 will reset itself after a few seconds. I have a projector connected to it, so I had to set the display screen back to HDMI afterwards, but when I disconnected the USB cable the controller worked wirelessly again. The customer service rep said that this allowed the controller to pair with the PS3 again. Note: You probably do not have to have the controller plugged into the USB cable at all while doing this. I just happened to have it plugged in. Hope this helps.
Posted on Jul 02, 2009
  • 10 Answers
SOURCE: PS3 Controller wont turn on?
mine sometimes does that, just try pushing and holding it until the options come up on the screen, then turn off controller. Then try turning it back on. If that doesn't work, turn the ps3 off when its done charging, then unplug it while its off. This should work.
Posted on Aug 20, 2009
Vahn84
  • 99 Answers
SOURCE: PS3 controller keeps scrolling down on its own,
The controller may need to be taken apart and cleaned with isotopic alcohol.
Posted on Nov 22, 2009
Vahn84
  • 99 Answers
SOURCE: My ps3 controller just keeps scrolling down
The buttons are sticking inside the controller. The only thing that will fix this problem is a good cleaning with isotopic alcohol and a Q-tip.
How I fix the xbox 360 controller blinking and sync light problem,when the sync button doesnt work?
My only guess would be that you disconnected the cable to the sensor while cleaning your Xbox. Have you checked all the connections before reassembling it? Check out the video I linked, maybe it'll help you!
Dec 16, 2014 | Microsoft Xbox 360 White Console
Yes, this can be tricky sometimes.
Be close to your console when synching your controllers. As always make sure the controller is on.
You will need to press both the synch button on the console and on the controller approximately the same time. If you have done this correctly. The controllers should have synched to the console in a few seconds.
Here is a link to show you how to do it for the Xbox 360.
Connect controller to your Xbox 360
To synch a Xbox One Controller go to link below here.
Connect wireless Xbox One controller to your console
Also just in case the light is flashing the and the controller is already synched, that means the battery is low and you need to change it out for new batteries.
Hope this has helped and good luck.
YT-9014A1 The four lights keeps on (not blinking) and is not being recognized by my PS3
look beneath your controller and there is a small pin hole there that looks like it has no use.put in a pin and it should reset your controller and ask you to re-connect to your console.hope this helps
Sep 23, 2010 | Sony Wireless Controller for PS3
YT-9014A1 will not sync
i just sync both of mine to my ps3 it was giving me difficult at first, but i noticed the when u first put in ur usb wireless thing it starts to blink really fast and when u push the p3 button on the controller twice it flashes really fast. so i took out the wireless usb thing then put it back in so the light on it would be flashing really fast like it was searching for somthing, then press the p3 button twice to make the lights flash really fast aswell so it will sync with it. Thats how i got both of my controllers synced we my ps3. the lights on on the wireless usb thing and the controller lights must be flashing fast at the same time to sync.
Mar 06, 2010 | Sony Wireless Controller for PS3
My ps3 it goes green beeps twice then goes red and flashes on/off
you might be holding the power on button to long. you hold the power on button until it beeps to reset the video output. try turning it on by using your controller. just press the ps3 button and if the red light is on then it should come on.
Oct 14, 2009 | Sony Playstation 3 (PS3) Console
Wireless Les Paul guitar light keeps flashing after I sync to 360
I had the excact same problem with a Microsoft wireless controller. It just showed it synced fine and the controller dropper off the rig right after, keeping blinking idly as always when unconnected.
Solution: When you power the console on with the X button on the controller, try pressing the connect button on the controller then, apparently the console looks for controllers when it's just opening the user interface. Had to try it twice but it synced fine just as I was giving up hope, and has been working ever since!
May 29, 2009 | Video Game Consoles & Games
Controller not working
Mar 29, 2009 | Sony Wireless Controller for PS3
Controler issues
Sounds like theres some sort of interference between your bluetooth controller and receiver. Something in your house, maybe another device may be interfering. However, there is an option you can try. Reset your settings/console to default and see if it fixes the problem. If you dont care for that idea and losing your settings you could always do this.
Shutdown your PS3, shut off the power completely too it by the rocker switch on the back. Wait a few minutes, then flip the rocker switch back to on, power up the ps3 with the bluetooth controller attached via the USB cable, once loaded, remove the controller and press the reset button on the back of the controller in, holding it for atleast 10 seconds, then release. If all goes well, the controller should resync with the ps3, you should be able to press the ps3 logo on the controller and see flashing lights followed by a solid. If this doesn't yield better connectivity, once again check your house for interference and if there is none. You may want to send it in to have the bluetooth/wireless combo board replaced. Or fix it yourself :)
Jan 18, 2009 | Sony Playstation 3 (PS3) Console
Controller still wont work
Hmm. I think i'll need a bit more info please.
When you reset your PS3 and the system's light goes red and you hit the PS button your controller the four lights just flash? Is that right? The only time your controller will "connect is when you plug it in with USB?
Try this. Turn your PS3 on. Press the reset button on the back of your controller and hold it for a few seconds, then press the PS button to see if it connects then. If it doesn't you could try removing the internal battery from the controller and putting it back in. That might clear up any settings that were saved in it.
Let me know how it goes.
Jun 24, 2008 | Sony Playstation 3 (PS3) Console
Sony PS3 DualShock3 Wireless Controller for PlayStation 3 Logo
191 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
