Question about Home
Hi I have a stylus toilet elegance model w15250, I had to pull to too off to stop it from running and now I can't get the top back on the cistern ( I thinks that's what's it called :) can you please help thanks :)
  • 2712 Answers
SOURCE: How to Install Toilet
It's not terribly complicated, assuming that by "install a new toilet" you mean where there was alredy an existing toilet. First, remove the old toilet. Shut off the water supply valve, and flush the toilet. Then use a spone to get rid of the water that remains in the tank. Remove the nuts on the two bolts at the base of the toilet where the toilet meets the floor. These are usually hidden under two plastic caps. Now gently rock the toilet until it comes away from the floor. Get help to carry it out. Clean up the old wax that's around the flange where the pipe disappears into the floor. Don't be a wuss, it's only wax. Now you'll need the new toilet, a new supply line, new mounting bolts (don't reuse the old ones) and a two wax rings. Yes, I said two wax rings. You'll see why in a minute. Assemble the new toilet according to the instructions provided. Now here's a warning: Do NOT overtighten the bolts the hod the tank to the bowl. You're dealing with ceramics here, don't break them. Now, put the new hold-down bolts in place on the flange. Read the insturctions that came with the toilet, but you have to do this NOW. Now you'll need a helper. With the toilet upsided down, unwrap a wax ring. Make sure it's room temprature or it won't seal. Press the wax ring around the outlet flange on the base of the toilet. Now you and your helper carefully turn the toilet over without crushing the wax ring. Lift the toilet and slowly lowe it so the wax ring is centered over the "flange" which is where the sewer pipe goes into the foor. Then press the toilet firmly in place. Now if you're like most people, you screwed up here and crushed the wax ring without being centered on the flange. That's why I told you to buy two. Now you know what not to do, scrape off the first one and start again. When you've got the toilet sealed on the flange, connect and tighten the nuts on the bolts. Now you may have to use a hacksaw to cut off the remaining ends of the bolts so you can get the neat little plastic caps to fit. Now connect the water supply line. Now's where you start praying. Turn on the water and let the tank fill. Check the supply line for leaks. Fix as necessary. Now flush. Is water running out from around the base of the toilet? No? Good, you got a good seal. Yes? Very bad. Time to go back to the home center for yet another wax ring. Repeat the sealing process and get a good seal this time.
Posted on Aug 27, 2008
  • 16 Answers
SOURCE: toilet cistern doesn't fill up
it sounds like one or more of your shut off valves has a glog from hard water calcium. were from indiana its a big problem here.To check this u will have to shut off main water supply and remove top of shut off valve and check for white crusty blockage, even if u see a few particals its present. It can severely restrict flow.
Posted on May 03, 2009
  • 129 Answers
SOURCE: Water flows unneccessary from the cistern in the
All you need to do is replace the tank flapper.
Posted on Sep 26, 2009
Testimonial: "Thanks for the tip.Flapper was fine,than I noticed that the round rubber seal was getting stuck.Cheapest solution - petroleum jelly...as good as new!"
SOURCE: my toilet cistern is continually hissing
Hi I have exactly the same problem, in fact it could have been me writing this - 3 toliets fine, main bathroom hisses. The Geberit flushing ciphen on the left (the smaller one) has been replaced and there is still a problem. If you look carefully,the water level needs to come up over the lip of an opening on the Geberit part and this causes the valve mechanism to shut off and stop the hissing. It is fine for about 40 minutes and then the hissing starts again if you don't flush it. The reason is that the water level has gone down but there is no obvious signs of where the water is going. It could be that the central flush mechanism is leaking slightly. I am going to replace this part next. If I were you I'd see if you are getting any water leakage into the pan when toilet not in use to see if the water level in the cistern is going down James T
Posted on Oct 31, 2009
co7196
  • 3433 Answers
SOURCE: cistern leak
The flapper valve(ball)seat is not sealing. Needs a new seat and flapperat bottom of tank. -Ned-
Posted on May 26, 2010
Hi I have a geberit cistern 222.013.00.1 with hissing noises and tank keeps topping up occasionally
wait for the new washer/ valve to settle in
or turn down the inlet water tap a bit
what does this really mean
tank topping up with water and re filling occasionally
in the wrong way or too tight or the wrong part ?
Nov 09, 2016 | Home
Hissing concealed cistern
The float valve needs adjusted or replaced.
Nov 30, 2014 | Kohler Home
Dux toilet cistern problemsolving
can only be one of 2 things. the inlet valve is not shutting off properly and so the tank is overflowing into the toilet bowl or the flush valve rubber is worn out. you can find this at the bottom of the flush valve mechanisum.
Dec 04, 2013 | Home
Water running into the bowl after flush and refil
IT SEEMS TO ME THAT THE BALL-**** (FLOAT SWITCH) IN THE CISTERN IS SET TOO HIGH UP. THERE ARE MANY DIFFERENT MODELS BUT ALL SHOULD BE EASILY ADJUSTED. HAVE A LOOK INSIDE THE CISTERN AND ADJUST THE FLOAT SO THAT THE WATER STOPS AT A LOWER LEVEL. IF THE WATER IS CONTINUOSLY FLOWING INTO THE CISTERN WHEN FULL YOU MIGHT NEED A NEW INLET WASHER
Feb 08, 2012 | Saniflo & Saniplus& Macerator Pump
When I flush the tank only half empties and not enough flushing action is the result as well as the bowl does not adequately fill after the flush.
Hi, if you remove the cistern lid and flush the toilet, look at the float (back left) to see if this is rising freely when the water fills back up. Once the water has stopped filling, check the fill level lines on the large syphon in the middle of cistern. Your model of toilet has an eco flush which will be lowest line to save water, so not as much water will flush out. There is a long plastic screw on the float (back left) which you can turn to adjust the water level to the higher line on syphon (1.6 gallon flush) and turn it slowley till the water level reaches that mark. flush a couple of times to see it is filling back up to the set amount.
Jan 14, 2011 | Kohler Cimarron 2-PC Elongated Toilet with...
We have a Jacuzzi X532 toilet. Can't get the water to stop running into the bowl, causing excess water usuage and stains intoilet bowl. This started about two weeks ago. Have this toilet approx. 3-4...
I am not familiar with the model of toilet that you have, but many toilets suffer the same problem. It is usually due to the toilet cistern over-filling, as the water running into the bowl is the safety-overflow mechanism. The overfilling can be for a few reasons. The most common is that the fill valve is being held open, either due to mal-adjustment, or due to it being postioned slightly wrongly so that it hits either the side of the cistern or another part of the mechanism and can't close off properly. If you lift off the top of the cistern and watch what happens when the flush goes, you might be able to spot what is preventing the valve from shutting off entirely, and solve it. Hope this helps! :)
Jul 19, 2010 | Jacuzzi Home
After cistern refill outflow into toilet bowl continues to dribble in - and you can see a slight flow into the bowl and every so often we hear the cistern refilling a small amount to compensate.
hi i would suggest your ball valve in the cistern needs ajusting remove the top of the cistern you will see the ajustment screw at the end fo the ball **** arm hope this helps
Nov 15, 2009 | Duravit 0910100005 Happy D Toilet Cistern ...
Villeroy Boch subway toilet cistern filling up to much
On this model am not sure if it come apart. But if you have a air compressure try and blow though it. when you have it off toilet. sounds like its dirt caught in it.
hope this helped. :)
Jul 07, 2009 | Villeroy & Boch 6610 11 Subway...
Need instructions and Switch for twyford close coupled cistern
i presume with lid of u can flush toilet by pusshing switch with finger if so buttons must be spot on when replacing lid can be adjusted inside systern any probs get back
May 07, 2009 | Toto CST414M-51 Aquia Dual Flush Close...
Maybe I'm an idiot but I don't know how to get the top off of my
The cistern lid is held down by the chrome assembly (which includes the two buttons that you press to make the toilet flush) sticking up in the middle of the lid. You need to unscrew that (anticlockwise) to be able to lift the lid off, to get to the inlet valve, etc.
If the water is running in very slowly, chances are high that the small screen filter under the inlet valve is partially blocked. Working inside the cistern, you need to unscrew the inlet valve assembly (noting the order in which the various parts come out!), then unscrew the cranked fitting just under that, to get the screen/filter.
Dec 27, 2008 | Duravit 0910100005 Happy D Toilet Cistern ...
Home Logo
43 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
