WD has a internet-page where you can find more info about the "flashing".
SOURCE: Flashing light on WD 500GB External Harddrive
This may sound silly,but sometimes if you put the drive in the freezer overnight it will work long enough for you to retrieve your data.Make sure you are ready to copy the data to another as it will likely fail again once it warms up.
SOURCE: My PC is not recognizing my WD Passport 120GB USB external drive.
I had the same issue. Its not a power issue because it shows up in device manager. Heres what I did.
Right-click on my computer and click Manage>Disk Management
Your drive should show up there. Right-click on it. If explore is not grayed out, assign a drive letter to it and you should then be bale to see it in my computer.
In my case explore was grayed out. I had to click on the option to format the drive. After re-formatting the passport explore was available. I then assigned a drive letter to it and I have access again.
I guess somehow using it on multiple computers srcewed up the file-system on it. I was using it between windows and linux.
This fixed my problem.
I had a similar problem with my WD passport 320GB. When I connected it to my laptop it never showed up on My Computer even though the blue light on the hard drive came on.
Here is what I did:
Right click on "My Computer" and click on "Manage" and then "Disk Management",. you should see your WD hard drive listed. then click on "change driver letters and paths" and change it from the listed to another drive. I changed mine from G to F drive and it worked for me.
SOURCE: My I Mac doesn't recognize the WD 500GB external drive anymore
it must be initialised /mounted 1st for osx
SOURCE: Flashing blue light on external WD hard drive & not recognised
sounds like you are using the wrong power supply. Check the amp output on the power plug you plug into the wall make sure its the same as the amp input of your external harddrive
I recomended you to use ULTIMATE BOOT CD 4.0 and to write HDD it will take ca 3 hours but u have to wait and checking for error i will post some pics some i hope will help you
http://img511.imageshack.us/img511/1614/14770099ga2.jpg
http://img511.imageshack.us/my.php?image=14770099ga2.jpg
http://img239.imageshack.us/img239/2526/35680833oz9.jpg
http://img239.imageshack.us/my.php?image=35680833oz9.jpg
or open cmd console and start with cmd
http://www.imagehost.ro/viewer.php?img=11234653470e8bbd44f2d
