Question about Baumatic BWE40 Wine Cooler
Replacement of door spring T-49 - Baumatic BWE40 Wine Cooler
How do I repair the door spring?
I believe you need to buy and install new door hinges.
Apr 21, 2015 | True T-49 Side by Side Refrigerator...
Change springs on garage door
It's is straight forward. Select a replacement spring with the same tension color as the original spring. The color is applied to one of the hooks. Above all thread the safety wire through the center of the spring.
Feb 02, 2014 | Stanley Hardware 730610 110 Lb Garage Door...
One of the doors will not close
The top hinge has a spring to close door. You can see a pin in a hole on top against a stop pin. Removing pin and winding up the hinge spring helps, find an Allen wrench that fits the other holes to assist. If winding one direction makes worse go the other direction. A new hinge may be in order. I can get you one if you need it. Wmontg5988@yahoo.com
Oct 27, 2013 | True T-49 Side by Side Refrigerator...
How to replace door spring T-49
very easy unless the old spring is blocked /or stopped for the foam insulation , you have to take both hinges and than with needle nose plplies pull it out , unless the FOAM STOPPED IT , than use different approuch you have to take the pannel off and cut around the spring . good luck,
Jul 19, 2012 | True T-49 Side by Side Refrigerator...
How to install new door spring on portable dishwasher
Things You'll Need:
  • Owner's manual
  • Screwdriver
  • Replacement spring (optional)
  1. Turn off the power to your Kenmore dishwasher before attempting any repairs. If you have a portable Kenmore dishwasher, you can just unplug the power cord from the wall. Built-in dishwashers are hard-wired into the cabinet, so you will have to turn off the breaker switch at the home's circuit breaker box to cut the power.
  2. 2 Remove the screws that hold the kickplate onto the lower front of the Kenmore dishwasher. Take the kickplate off to access the door springs.
  3. Check the door springs to make sure they have not come loose from the door support or the adjustment holes on the dishwasher. Re-attach any ends that have slipped off their connections.
  4. Replace the springs if they are connected at both ends but still do not have enough tension to support the weight of the door. Once a Kenmore dishwasher door spring is stretched out, it cannot be restored to its original condition. Unhook one end of the old spring from the adjustment hole. Unhook the other end from the door support and discard the spring. Insert one end of the replacement spring into the adjustment hole and the other end into the hook on the door support.
  5. Open and close the door a few times to make sure the spring is now working properly. The door should not bounce up and down or sag on the hinges when it is in the open position.
  6. Restore power to your Kenmore dishwasher by plugging it back in or turning on the switch at the home's circuit breaker panel.
Dec 21, 2010 | Maytag Dishwashers
My maytag glass lid shattered and I need to find A replacement and how to install
Unplug the machine. Pop the top using a putty knife to release spring clips between the top and front panel. Remove the hinge screws with phillips head screwdriver, pull the hinge straight out as seen on page 49 of this Maytag Bravos Service Manual
Jun 27, 2010 | Maytag Bravos MTW6600T Top Load Washer
The light bulb burnt out. It is located in the center of the fridge between the two doors. I'm not sure how to remove the bulb in order to replace it.
Unplug the cooler to avoid a shock. Try pulling bulb up and then out from bottom. The bulb should be resting in spring loaded receptacles.
Nov 13, 2009 | True GDM-49-RC Refrigerator
Microwave Oven Door Spring Replacement
Remove the front panel by removing the screws located on the inside of the door (note hold door inplace, since it is heavy and will fall out after screws removed). Unscrew screws located on bottom of plastic retainer (2 each) Remove tension spring. Note 2 are included right and left. Note color of spring on end, different springs for different door types, stainless, black,beige or white. Replace all in reverse order.
Mar 26, 2009 | KitchenAid Microwave Ovens
Canon PC950 Copier
Hi -- The springs at the 'feeder" door broke. Now the copier wont feed, are there replacement parts? A new door perhaps? I have the same problem.. Need help or place to purchase parts.
Sep 02, 2008 | Canon PC-950 Black and White Copier
Door closer pin
You can make one or order one through "Coldparts.com" if the part is available individually.
Apr 30, 2008 | True T-49 Side by Side Refrigerator...
Baumatic BWE40 Wine Cooler Logo
16 people viewed this question
Top Baumatic Refrigerators Experts
Sal DeAngelo
Colin Stickland
Colin Stickland
Electric Dime
Electric Dime
Are you a Baumatic Refrigerator Expert? Answer questions, earn points and help others
