Question about Plantronics BackBeat 903 Bluetooth Headset
Change battery plantronics 903 - Plantronics BackBeat 903 Bluetooth Headset
My iphone 4s can not find my 903
Once you make your iphone discoverable, then put the Plantronics 903 headset into pairing mode by pressing the power button until it flashes red and blue. If it's not flashing red and blue, it's not in the pairing mode. Below is a link for the user guide which has the pairing instructions:
Plantronics BackBeat 903 Pairing Instructions
Good luck from Headsets Direct!
Nov 25, 2011 | Plantronics Backbeat 903 Bluetooth...
I can not configure Backbeat 903 + with android LG Optimus 509
It sounds like you need to prepare your phone to connect to the headset. Remember that newer phones are like small computers, so they may become corrupt over time and you may need to reset them every so often. Simply turn your phone off and remove the battery for a few seconds, then replace the battery and turn it back on. Make sure there isn't any other bluetooth interference and then pair the two devices following the instructions from the user guide in the link below for the Plantronics Backbeat 903+.
Plantronics Backbeat 903+ User's Guide
Aug 30, 2011 | Plantronics Backbeat 903 Bluetooth...
I cannot turn on my brand new plantronics headphones. please help me!
Can't turn on the Plantronics BackBeat 903 headset:
The power button for the Plantronics BackBeat 903 headset is on the back of the ear piece. Please take a look at the user guide, it has a diagram. Here is the link:
http://www.headsetsdirect.com/pdf/backbeat903-906_ug_en.pdf
Good luck from Headsets Direct - 800-914-7996.
Aug 18, 2011 | Plantronics Backbeat 903 Bluetooth...
MPlantronics Backbeat 903 Bluetooth Wireless Stereo Headphones Headset red light flashing problems
The red flashing indicates a low (or check) battery. The instructions on page 4 in the link below for the Plantronics Backbeat 903/906 will show you how to charge it up. On page 8 you'll see how to power down and then up the headset to reset it.
Plantronics Backbeat 903/906 User's Guide
Aug 02, 2011 | Plantronics Backbeat 903 Bluetooth...
I cant sink with my iphone 4?
Once you make your iPhone discoverable, then put the Plantronics Backbeat 903 into pairing mode. With the headphones powered off, press and hold the Power / Pairing button until the LED Indicator flashes blue and red. Here is the link below for the Backbeat 903 user guide that has the pairing instructions as well.
Plantronics Backbeat 903 User's Guide
Jul 26, 2011 | Plantronics Backbeat 903 Bluetooth...
Will not charge the built in battery
The battery in the BackBeat 903 is not replaceable. If your headset is not charging and less than a year old, return it to your retailer for warranty replacement or call Plantronics at 800-544-4660 x5 x5538 for warranty service.
Jul 24, 2011 | Plantronics Backbeat 903 Bluetooth...
I am not able to connect the headset and my BB
Remember that newer phones are like small computers, so they may become corrupt over time and you may need to reset them every so often. Simply turn your phone off and remove the battery for a few seconds, then replace the battery and turn it back on again. If this does not resolve the issue, delete any pairing information for your BackBeat 903 headset and pair it again with your phone, carefully following the instructions on the link below for the Plantronics BackBeat 903.
Plantronics BackBeat 903 User's Guide
Mar 12, 2011 | Plantronics Backbeat 903 Bluetooth...
I have a Plantronics Backbeat that I use with my iPhone 3G. Many people complain that it is difficult to hear me when I speak on the phone. The say there is a lot of drop out and that it isn't clear. ...
again the battery for a few seconds, then replace the battery and turn it back on again. Delete any pairing information for your BackBeat 903 headset from the phone and pair it again with your phone, carefully following the instructions on the following link for the Plantronics BackBeat 903.
That should get the cobwebs out of the connectivity between the headset and the phone.
Dec 31, 2010 | Plantronics Backbeat 903 Bluetooth...
Will not fast forward a song and when i pause it it only mutes the music and keeps playing the song on my phone
Typically with the Plantronics Backbeat 903 Bluetooth headset, you should be able to move forward or backwards one track. Press and hold the volume/tracking/mute button forward or backwards for each track. You should hear a single low tone for each track change. Below is a link for the Backbeat 903 user guide.
Dec 26, 2010 | Plantronics Backbeat 903 Bluetooth...
Plantronics BackBeat 903 Bluetooth Headset Logo
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
shaun taylor
Michael Vincent Cruz
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
