Question about Weed Eater Weedeater 26" Riding Mower
Is this the worst design ever made for a lawn mower or is there a secret to maintain the chains and tires
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
It ranks up there... no secret besides a recycle bin
Posted on Oct 20, 2013
Mover sometimes does not move and other time moves real slowly
ck belts that run hydraulic pumps for tire drive , it might have slipped a bit with chain caught , now belts skid instead of transferring power to pumps , also these pumps might have a manual pressure relief reset , I was thinking they only used them on bigger units , but you might have one as well ,hey its possible , this will need to be reset prior to continuing mowing (refer to manual for location )
Jun 23, 2015 | Husqvarna Rz4623 46" Ztr Lawn Mower Zero...
Tip
Carberators run to lean
Allot of engines are designed to be fuel efficient and run horrible a short time after purchase.You notice most have no adjustments.Well the secret is to soak your air filter in 10 w 40w motor oil then wipe excess and re install and its running like new again.This concept I developed works very well on motors that are running lean.
on Oct 19, 2010 | Mtd 22" Yard Machine Push Mower
Snow chains
  1. Tire chains should be installed on the drive wheels of the vehicle following the chain manufacturer's instructions, To retain as much of the normal handling characteristics of 4WD/AWD vehicles as possible, tire chains should be installed on all four tires, requiring the purchase of two pairs of tire chains.
  2. Buy chains that are the correct size for the tires. A proper fit is key to receiving the desired performance and durability. Do not deflate tires to install tire chains. A correctly sized tire chain will fit over a properly inflated tire. Additionally, because there is typically no source of compressed air to refill a deflated tire, driving with low tire pressure may cause permanent damage to the tire. Snow chains may not be available for all tire sizes.
  3. Use only SAE Class "S" chains. The restricted wheel well clearance in most of today's down-sized and front drive vehicles require tire chains to operate in an envelope that is no greater than 1.46-inches vertically and .59-inches laterally around the tire. These minimum clearances must be maintained between the tires and the vehicle's fenders, suspension, struts, brake lines and braces.
  4. It is important to pre-fit chains prior to actual use. Being faced with the choice of either damaging their vehicle or not completing a journey if the tire chains didn't fit is not a choice many drivers would want to have to make. Pre-fitting the chains will also allow the driver to become familiar with their installation. Since tire chains will only be required when the weather is at its worst, who would want to learn how to install them during a blizzard?
    You may want to buy a tire chain installation helper. These small ramps are designed to prevent slipping and allow you to lay a cross chain in a pre-formed indentation. Once you drive onto the ramp, the chains are positioned under your tire for easier installation following the manufacturer's directions.
  5. Tire chains should always be carried in the trunk during the appropriate times of the year and only mounted on the vehicle when warranted by driving conditions or required by law.
Dec 11, 2013 | 1992 Chevrolet S-10
I drained my oil in my toro and it had gas in it lx420
the float in the carb is stuck open allowing the cylinder to flood with fuel. Clean or replace the carb and try it again
Feb 03, 2013 | Toro LX Lawn Tractor Rear Tire Chains (20"...
Craftsman 42", 18.5 lawn tractor: blades are hitting in the mower deck. Blades are new and deck is balanced. Is it wear on the Mandrel - Shaft? Mandrel bearing?
Oh boy!!! Welcome to the craftsman worst design of their mower decks CHEAP!!!!! I had to replace my mandrel on the right side, side where the grass shoots out several times!! Cheap aluminum casting ****, one or more of your ears on the mandrel probably snapped, if you have an air wrench they are not too bad to replace, the screws that go into the mandrel are self threading and is easier to work on with air wrench but can be done with socket set, hope this helps!!!! good luck!
Aug 23, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Honda lawn tractor
There are very few, if any, grease points in the steering of any lawn tractor. Since I have no idea what model tractor you have, the best I can tell you is look for grease fittings on the main pivot points on the outer ends of the front axle and on the inside of the front wheels. You will only find 1 or 2 for each side.
If you are experiencing difficulty steering, the primary cause is improper inflation of the front tires. Maintain them at 14 PSI and you should find that it steers a lot easier
Sep 17, 2009 | Garden
My deck cuts shoter on the rt,ie uneven
Check your tire pressures:
10 psi. for rear tires.
14 psi. for the front.
Note that according to MTD:
Making sharp right hand turns. Twin-blade mower decks are designed with the discharge on the right side and two side-by-side blades. The side-by-side twin blade decks have the left hand blade positioned slightly forward and in front of the right blade. This provides cutting overlap when traveling in a straight line. As a result, the tractor should mainly operated making primarily left hand turns when cutting. During left turns this cutting overlap is maintained. If turning right when, it is possible to negate this overlap and leave an uncut strip.
May 31, 2009 | Mtd LAWN MOWER PART # 683-0439A DECK...
Where can i get a user guide for sanli lawn beetle ohv 350
I have a Lawn beetle ohv 350 lawn mower and it won't start. Is there any particular way or a secret way of starting it ?
Ben
Apr 02, 2009 | Garden
Weed Eater Weedeater 26" Riding Mower Logo
112 people viewed this question
Top Weed Eater Garden Experts
David Payne
David Payne
Lawrence Oravetz
Bonard Allen
Are you a Weed Eater Garden Expert? Answer questions, earn points and help others
