Question about Dream Maker Spas Dream Maker Ez Spa Hot Tub
My spa leaks but im not sure how to access the guts to make repairs
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 38 Answers
Try spa fix a leak. It is a great product that I use on fully foamed spas before I put them up on blocks and start chasing the water. Works 90% of the time.
http://spaandpooldepot.com/fix-a-leak-32oz you may find it cheaper somewhere else this was just googles first response. I sell it to my customers here in Austin for $30.00
Posted on Oct 26, 2013
Do I remove the wood side panels to fix a leak in a dimension one spa or go from the bottom?
in most cases, the sides of the spa are removable to fix leaks and service the unit. going from the bottom will not give you access to anything important
Nov 04, 2015 | Pool & Spa
I have water leaking out of left hand corner of water fall and steps going into hot tub i think it is leaking only when pump is on
Sounds like maybe the clamps have given way on your water fall return line and maybe your ozonator return. You will unfortunately have to take down the wall to get access. Check all of your unions and make sure they are tight, and then look for pools of water to show where the leaks are. If your completely insulated with spray foam look for saturation that will lead you to your leak. Once you fix the leak make sure to spray foam over your repair. How To Fix Leaking Hot Tub
May 20, 2015 | Pool & Spa
My dream maker leaks but im not sure how to obtain access to pumbing
That is not easy. Since there is no access but right at the pump area only. sometimes there is a bigger access from the bottom.
Oct 16, 2013 | Dream Maker Spas Pool & Spa
Leaking lay z spa pump
Firstly try some Fix-a-leak spa leak repair.
If the suspected leak is less than 1/8" that should fix it.
Or remove the paneling to find where it is coming from, there is no easy solution.
Jul 25, 2012 | Pool & Spa
Someone brought me a Toro CCR 2450 Snow Thrower. This appears to be leaking oil from the muffler. My gut tells me bad mixture- too heavy on the oil- but I'm not an expert and can't say for sure....
Yes, your gut may be right on the fuel mixture. It may also be the piston rings are worn and need replaced. But you should definitely try the right fuel mixture first! Another way to back up the gut is to take the muffler off and look into the cylinder that way. If there is a lot of carbon build up in there, then you know that that is the problem. There will also be carbon build up in the muffler too.
Good Luck!
Jim
Aug 08, 2011 | Briggs & Stratton Tools & Hardware -...
Pump surging, air bubbles in return
You have a leak in the suction allowing air to enter and emasculate the pump - find it and fix it!
Jan 19, 2011 | Sta Rite Pool & Spa
My Hayward Sand Filter Tank has sprung a leak on the side of the tank not near where it looks like the tank might have been molded together. What can I use to patch the tank that will hold and not leak?
They are fiberglass ... fiberglass repair kit should do it ...
Im not so sure I would fix it ... if it is broken ... there are probably problems you cannot see ... might be cheaper to replace the tank when you consider what might happen if it breaks while you are not around.
Aug 29, 2010 | Hayward SAND FILTER, PRO SERIES
My filter is leaking at the housing where the pump bolts on at the bottom of the housing when under pressure?i need help on how what to look for or at thanks.
Thank you for posting your question here on Fixya.com.
Your pump seal is leaking. They wear out over time and need to be replaced. Separate the pump at the big steel band. Turn off the breaker and disconnect the electric feed. You can now move the motor and pump guts to work on it. Remove the diffuser and impeller and you will see the seal. Replace it, reassemble and reinstall the unit and your all done. For parts or if you need help with the repair, contact a local electric motor and pump repair shop. Depending on the age of the pump it is one of two seals and may need a new heat sink.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Jun 12, 2010 | Sta Rite Sta - Rite Dyna - Glas Pool Pump...
How do i replace the gasket 2hp
better to just replace whole pump motor will start to squeal soon after
Jun 02, 2010 | Waterway 5 Hp 230 Volt 2 Speed Side...
Rewiring 84 s10
black wire will came out from the fuse box. red one will run the motor and bule will the collecthe power
May 03, 2008 | Computers & Internet
Dream Maker Spas Dream Maker Ez Spa Hot Tub Logo
208 people viewed this question
Top Dream Maker Spas Pool & Spa Experts
john h
Craig Butler
Craig Butler
wadingriver
wadingriver
Are you a Dream Maker Spas Pool and Spa Expert? Answer questions, earn points and help others
