Question about Dream Maker Spas Pool & Spa
My dream maker leaks but im not sure how to obtain access to pumbing
  • Dream Maker ... Master
  • 1,631 Answers
That is not easy. Since there is no access but right at the pump area only. sometimes there is a bigger access from the bottom.
Posted on Jan 29, 2014
My spa leaks but im not sure how to access the guts to make repairs
Try spa fix a leak. It is a great product that I use on fully foamed spas before I put them up on blocks and start chasing the water. Works 90% of the time.
http://spaandpooldepot.com/fix-a-leak-32oz you may find it cheaper somewhere else this was just googles first response. I sell it to my customers here in Austin for $30.00
Oct 16, 2013 | Dream Maker Spas Dream Maker Ez Spa Hot...
Just purchased a used Dream Maker X400 hot tub. It holds the water during the filtration cycles but if we attempt to use the hot tub by turning on the jets there is a major leak. Is this from one of the...
Have you opened the equipment access door and looked in it while it is running. I would look at the pumps to see if one of the seals are leaking. They will leak more on high speed and if you have a cir pump that runs the filter and an additional pump for high speed jet action it would make sense why it is leaking more while you are using it.
Oct 03, 2013 | Dream Maker Spas Dream Maker Ez Spa Hot...
Dream Maker Spas leak
This means one of your top jets is leaking. Firstly try Fix A Leak this will stop any leak up to an 1/8". If this does not help there will be more difficult work in store.
Each jet sits in a jet body, these jet bodies are behind the tubs shell, you'll need to get in behind them to see which one is leaking. This can be difficult as they are often covered in insulation foam.
Sep 05, 2012 | Dream Maker Spas Dream Maker Ez Spa Hot...
I have a dreamaker 8003 xspa that has worked perfectly over the many years that I have had it. The other day I noticed that the water had lowered 6 inches overnight an the water was coming out of the
1. Check equipment like pump, heater, blower, light fixture, for leaks.
2. Remove side panels closest to the are the leak is showing and inspect jets, plumbing in that area for leaks. If insulation is foam, remove any water saturated foam and follow it to the source of leak.
3. If the leak is in plumbing and is very slow, sometimes it can be resolved with "stop leak" products.
Aug 07, 2012 | Dream Maker Spas Dream Maker Ez Spa Hot...
I have a leak in my Dreamaker Eclipse hot tub. Within a few days, the water level drops to the bottom of the lower water jets then stops. We didn't use the tub last winter but I completely drained it...
Thats the problem with Dreammaker tubs, access can be a pain and theres no easy way of getting to the pipes.
I would usually gain acces from the underside which ensures that any holes that need to be made to gain access wont be visible in the future.
Good luck locating the leak.
Kind Regards,
Ian.
http://hottub.synthasite.com
Jun 11, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
What size shaft seal is in a dream maker eclipse spa? I need a new one to replace my leaking seal.
Your spa should have the aquaflo pump which uses a PS-200 seal.moz-screenshot-1.png
http://www.ussealmfg.com/pdfs/ChooseThe%20RightSeal.pdf
Oct 26, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
Pool & Spa Logo
168 people viewed this question
Top Dream Maker Spas Pool & Spa Experts
Ian Kime
Ian Kime
john h
The Cover Guy
The Cover Guy
Are you a Dream Maker Spas Pool and Spa Expert? Answer questions, earn points and help others
